Members Orangestencil Posted August 8, 2020 Members Report Posted August 8, 2020 Hi all, this is a very elementary question but I am seeing a lot of “customizer artists” paint initials on leather bags and am wondering how they get it so neat without stencils? Can anyone give me insight into the process? Quote
Members Handstitched Posted August 8, 2020 Members Report Posted August 8, 2020 Got any examples, pics ? Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Contributing Member fredk Posted August 8, 2020 Contributing Member Report Posted August 8, 2020 I believe the likes of Louis Vuitton uses a heat embossing method. A special metal foil is used and the letter stamp is heated and pressed into the leather with the metal foil between the stamp and leather. Then the part of the metal foil not used is peeled away leaving just the letter foiled. One of our Australian members uses this method on things he makes and on their packages Quote Al speling misteaks aer all mi own werk..
Members Spyros Posted August 8, 2020 Members Report Posted August 8, 2020 Heat embossing or screen printing. And for LV specifically it's possibly some proprietary method used only by/for them. The whole point of the LV surface (which is basically a glorified plasticised canvas) is to make is as difficult as possible to copy, so they might have also used the most complex printing method. Anything to be even slightly different and visually distinguishable. Quote
CFM chuck123wapati Posted August 8, 2020 CFM Report Posted August 8, 2020 painting Initials without stencils takes practiceeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee....... A ton of it. Start with basic calligraphy on regular paper then advance to script liner brushes on smooth surfaces. then you can use regular acrylic paints on leather. Many books on the subject it is a very old form of art. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted August 8, 2020 CFM Report Posted August 8, 2020 Or you can try printing out your font then case your leather as you would to tool it, use a stylus to outline your font lightly onto the leather then either emboss it and paint it or just paint it without embossing. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
