Members Memphis514 Posted August 21, 2020 Members Report Posted August 21, 2020 Cobra 26, 9-10z veg, 207 on top and 138 in the bobbin, stitch length set at 3.... Quote
Members Constabulary Posted August 21, 2020 Members Report Posted August 21, 2020 (edited) A too small needle size or not enough top tenstion / too much bottom tension. But I bet your needle is too small for the 207 thread What needle size are you using? Edited August 21, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
RockyAussie Posted August 21, 2020 Report Posted August 21, 2020 As the knot is pulled in on some places I would suspect that you have a badly wound bobbin with tight spots or a bobbin that is catching inside the case somewhere. Other than that you may resting your foot down occasionally on the foot lifter that also loosens the top thread tension. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Handstitched Posted August 21, 2020 Members Report Posted August 21, 2020 Theres certainly tension issues somewhere. Have a look at the thread , bottom left, with the tail, you can see the top thread has ' looped' , or as RockyAussie suggested the thread is catching somewhere. It'll be a process of of elimination . I always have the same size thread top & bottom , 180/24 needles , no issues ( touchwood ) . Just a thought. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Memphis514 Posted August 23, 2020 Author Members Report Posted August 23, 2020 On 8/21/2020 at 3:34 AM, Constabulary said: A too small needle size or not enough top tenstion / too much bottom tension. But I bet your needle is too small for the 207 thread What needle size are you using? I’m using SCHMETZ NM 160 size 23 135x16 Quote
RockyAussie Posted August 23, 2020 Report Posted August 23, 2020 It would be better with a NM 180 or 200 leather point needle. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Memphis514 Posted August 23, 2020 Author Members Report Posted August 23, 2020 (edited) 2 hours ago, RockyAussie said: It would be better with a NM 180 or 200 leather point needle. thank you for the info... can you recommend a brand with the specific numbers or is this acceptable? i am not that good at just knowing what all the numbers mean LOL Edited August 23, 2020 by Memphis514 Quote
RockyAussie Posted August 23, 2020 Report Posted August 23, 2020 Sorry I am not familiar with the Organ brand needles and numbers. The 180/24 indicates how thick the needle is but the numbers above refer to the system type. I think the ones above made not be leather points either. If the needle comes to only a sharp point then it would be for fabric use. A leather point needle in the Schmetz that I use are LR needles which looks like this when it cuts into the leather \. If the Organ needles are the same length and the holes and scarf are all looking the same as the other Schmetz needles you have then I would say to give them a try. IF they are shorter or worse longer do not even try them. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Bert51 Posted August 24, 2020 Members Report Posted August 24, 2020 I just had a quick look at the spec's for 62x59 needles and they are 41.4 mm , while 135x16 is 38.9 mm long. I don't know if you have you needles set at the right height for those needles. Bert. Quote
Members Memphis514 Posted August 24, 2020 Author Members Report Posted August 24, 2020 16 hours ago, RockyAussie said: Sorry I am not familiar with the Organ brand needles and numbers. The 180/24 indicates how thick the needle is but the numbers above refer to the system type. I think the ones above made not be leather points either. If the needle comes to only a sharp point then it would be for fabric use. A leather point needle in the Schmetz that I use are LR needles which looks like this when it cuts into the leather \. If the Organ needles are the same length and the holes and scarf are all looking the same as the other Schmetz needles you have then I would say to give them a try. IF they are shorter or worse longer do not even try them. 1 hour ago, Bert51 said: I just had a quick look at the spec's for 62x59 needles and they are 41.4 mm , while 135x16 is 38.9 mm long. I don't know if you have you needles set at the right height for those needles. Bert. ok so i found these on amazon...will they work? Quote
