Members Karburization Posted September 15, 2020 Members Report Posted September 15, 2020 Hello, I am new to leather braiding and am attempting to braid a leather handle cover for a walking stick. I chose the "Six thong multiple braid" from Bruce Grant's encyclopedia ( Paracord example visual) but am concerned that the leather handle will move around if I do not glue or attach it in some way. I've read affixing the leather lace with nails could help but was wondering if anyone else had any suggestions. Any advice is much appreciated! Quote
Members rodneywt1180b Posted September 15, 2020 Members Report Posted September 15, 2020 I can't help but would be interested in seeing the stick please. Quote
Members Karburization Posted September 15, 2020 Author Members Report Posted September 15, 2020 Sure thing, we got these from Brazos Walking Sticks (see pic), because of the finish they are very smooth which is why I am a bit concerned with slippage. Quote
CFM chuck123wapati Posted September 16, 2020 CFM Report Posted September 16, 2020 maybe drill a hole or holes and run some of your braid material through the holes. Just a thought and i just noticed it already has a hole drilled lol. Quote
Members RevMoore Posted September 16, 2020 Members Report Posted September 16, 2020 I have done some knot work with paracord on a walking stick in the past. If I remember correctly, I used really small finishing nails to anchor them in place and then hid them under a turks head knot. A thought, (PLEASE CORRECT ME IF I'M WRONG) you could try soaking the leather. then braid it. when the leather dries it will shrink a bit and form to the stick. I would like to see the finished project either way.. Quote
Members Karburization Posted September 19, 2020 Author Members Report Posted September 19, 2020 On 9/16/2020 at 2:45 PM, chuck123wapati said: maybe drill a hole or holes and run some of your braid material through the holes. Just a thought and i just noticed it already has a hole drilled lol. This is a great idea! Quote
Members Karburization Posted October 19, 2020 Author Members Report Posted October 19, 2020 On 9/16/2020 at 4:09 PM, RevMoore said: I have done some knot work with paracord on a walking stick in the past. If I remember correctly, I used really small finishing nails to anchor them in place and then hid them under a turks head knot. A thought, (PLEASE CORRECT ME IF I'M WRONG) you could try soaking the leather. then braid it. when the leather dries it will shrink a bit and form to the stick. I would like to see the finished project either way.. I believe soaking and stretching helps but when I tested my knot I realized this WILL slip especially as you put your weight on it when walking. I am considering finishing nails but with this knot the length adjusts itself slightly due to the variance in circumference so nailing the leather too soon would prevent me from tightening properly. My current plan of action is as follows: soak and stretch the leather, braid it, add two securing knots to the ends which I found in Bruce Grant's encyclopedia, plate 58 to be exact, and only then after tightening everything add a few finishing nails. Wish me luck LOL Quote
Members RevMoore Posted October 19, 2020 Members Report Posted October 19, 2020 Good luck. And post some pics of the finished result. Quote
Members curlyjo Posted October 25, 2020 Members Report Posted October 25, 2020 Raise each end with a piece of tape and that should anchor the end of the multiple string button. Or a ring button out of rawhide on each end. The rawhide will cinch down better than leather. Then wrap a piece of light leather between ring buttons and tape over that. A lot of bosal nose buttons are built like that. Quote
Members bucksnort Posted October 26, 2020 Members Report Posted October 26, 2020 (edited) I had the same thought as Brad. I would put a ring knot at each end & glue it in place, then work your finish knot over them. Just like a hackamore nose knot. You can find directions for a multi string nose knot in Grant’s book. Edited October 26, 2020 by bucksnort Added to it Quote
CFM Frodo Posted October 26, 2020 CFM Report Posted October 26, 2020 6 plat braid is 6 piece of cord drill 3 holes in the stick thread each hole now you have 6 cords ends , braid the walking stick Quote
