Contributing Member fredk Posted September 20, 2020 Author Contributing Member Report Posted September 20, 2020 Now with improvements I used the divider point to scribe a line at about 12mm ( 1/2 inch) and 20mm ( 3/4 inch) from the centre. I went over the lines a few times to make it deep enough to take some black paint. I painted the whole line then wet sanded the excess off. Its on a 40mm wide strap in the picture. It doesn't look even because of its angle in the photo but in the hand the 20mm circle touches both sides of the strap. The black lines are neat too but show kinda broken up due it being a digital photo Thanks, @chuck123wapati, I was over thinking the problem. A simple scribed line does the job well. K.I.S.S. it is Quote Al speling misteaks aer all mi own werk..
CFM chuck123wapati Posted September 20, 2020 CFM Report Posted September 20, 2020 42 minutes ago, fredk said: Now with improvements I used the divider point to scribe a line at about 12mm ( 1/2 inch) and 20mm ( 3/4 inch) from the centre. I went over the lines a few times to make it deep enough to take some black paint. I painted the whole line then wet sanded the excess off. Its on a 40mm wide strap in the picture. It doesn't look even because of its angle in the photo but in the hand the 20mm circle touches both sides of the strap. The black lines are neat too but show kinda broken up due it being a digital photo Thanks, @chuck123wapati, I was over thinking the problem. A simple scribed line does the job well. K.I.S.S. it is perfection Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members dikman Posted September 20, 2020 Members Report Posted September 20, 2020 Yep, even better! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
CFM chuck123wapati Posted September 21, 2020 CFM Report Posted September 21, 2020 16 hours ago, fredk said: Now with improvements I used the divider point to scribe a line at about 12mm ( 1/2 inch) and 20mm ( 3/4 inch) from the centre. I went over the lines a few times to make it deep enough to take some black paint. I painted the whole line then wet sanded the excess off. Its on a 40mm wide strap in the picture. It doesn't look even because of its angle in the photo but in the hand the 20mm circle touches both sides of the strap. The black lines are neat too but show kinda broken up due it being a digital photo Thanks, @chuck123wapati, I was over thinking the problem. A simple scribed line does the job well. K.I.S.S. it is 15 hours ago, dikman said: Yep, even better! amazing what a guy can do without a computer, a special cad drawing app, a 3d printer........ Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members dikman Posted September 21, 2020 Members Report Posted September 21, 2020 Another possible mod to it. Use it to mark the first hole, slide it along so the circle is over the mark and mark that point on the circle with the awl. Drill a small hole and put another small pin in it, then once you've marked your first hole on the belt slide it along so the pin sits in the mark and you've got perfect spacing for the next hole. Just a thought. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members paloma Posted September 22, 2020 Members Report Posted September 22, 2020 another good idea; Quote time does not respect what is done without it https://tradisign.blogspot.com https://www.instagram.com/tradisign/
