Have you tried leaving a little bit extra room say an extra 1/8th inch on the border and trimming and sanding the edges?
Yes I have my issue is that I seem to always have a point at which I lose concentration (or my hand slips, or...)  I even tried applying painters tape to the edge, but the frizzies that occur when removing the tape created a different issue.    I am working somewhat in the blind on finishing edges of the bands as the leather working club has been shutdown since early in the COVID problem.  I have made straps off and on for several years, but it has only been in 2020 that I worked on burnishing the edges (and using veg tanned leather).  Before that it was finished leather usually with a pronounced pull up and the edges were left raw as the band was for a TOOL watch.
use masters all purpose cement and a good hair brush...it dries fast and is perfect for watch straps
get a good container for it and buy the thinner..you will need it
Greg Spitz MD,FACS Custom Watch Straps
922Leather
Gregspitz@922Leather.com
  • 5 months later...
Similar problem, except I would like to not glue at all, even with tape. For easier fixing of mistakes (I come from textile crafts where stitching can easily be ripped and redone) and better recycleability of pieces I no longer like to use (still making dog collars).
Is anybody out there who clips or pins the leathers together or even basts with a few stitches here and there?
I have been known to staple pieces together before sewing. On soft leather drawstring bags I staple along the sewing line then try to get my thread spacing so it goes through the staple holes. On some other items, I cut the leather oversize by about 6mm, staple in that excess, sew the item, then cut off the excess with the staples
"Staple" as in one of these office things to clip two pieces of paper semi-permanently together? Interesting thought, wouldn't have occurred to me... Thanks!
Maybe a simplistic answer but have you considered Rolled inward edges so both the top and bottom are skived & rolled between both sides
Mi omputer is ot ood at speeling , it's not me
