Anyone know where I can find a blue gun or other molding prop for a classic model 29 S & W 44 magnum with a 4” barrel? I’ve tried my regular sources, with no luck.
I would appreciate any help. Phil
Boise Foundry has a 629 with 4" barrel and several other N frames that should work.  Probably as close as you are going to get.  N frames are hard to find.  I have one plastic molded and another inbound from Boise.  Boise is a little tricky to order from, but they are responsive to calls if you need to talk to them.  Dave has called me twice on this order because it got messed up in their system when I tried to order 2 molds.
https://www.boisefoundry.com/holster-molds
Edited by chiefjason
On 11/5/2020 at 11:59 AM, WolfteverGunleather said:
@chiefjason Thank you very much! I’ll contact them.
That is what I would do. I just got my first two guns from them one being a 629-1 and it worked perfect for what I was doing. Their website can be confusing for a first time user and is not exactly user friendly but give them a call and tell them what you want. Its much easier.
