Members chrisash Posted November 21, 2020 Members Report Posted November 21, 2020 Does anyone know the size of the shaft the hand wheel sits on as looking to replace it with larger pulley At present all is well, and i understand it may be hard to remove the hand wheel after being on for years, so don't want to remove to measure until i need to Quote Mi omputer is ot ood at speeling , it's not me
Members sandmanred Posted November 21, 2020 Members Report Posted November 21, 2020 (edited) Not sure on that model but every industrial Singer I know it's a little over a half inch, my caliper says 0.545 inch. I made a larger pulley for my 31-15 of aluminum that replaced the hand wheel. It worked great to slow it down but unfortunately it threw it off balance at higher speeds because the hand wheel has a counter weight built in that I ignored when I made my oversized pulley. My solution since has been to turn an over size pulley that bolts on the the hand wheel. The add on pulley leaves the handwheel in place so it doesn't throw off the balance at higher speeds. It requires a large bore in the add on pulley that pilots on a surface where the belt normally rides. Once fitted I drill and tap into a meaty part of the handwheel to fasten the over-sized pulley with a screw or two. The pic below is a 78-1 that I added this pulley but I also have it on my 31-15 and a Consew 28. In the case of the 78-1 I was able to pilot the add on pulley on the right end, the nub that sticks through provided enough of a shoulder to center the add on pulley. Edited November 21, 2020 by sandmanred add comment about pilot hole on right side Quote Have Consew 255RB-3, Pfaff 545 H4, Chandler 217, Pfaff 138 and Merrow 60W. Had a Singer 132K6, Singer 78-3 Consew 28, Consew 18, Singer 31-15 and regret selling each and every one of them
toxo Posted November 21, 2020 Report Posted November 21, 2020 1 hour ago, chrisash said: Does anyone know the size of the shaft the hand wheel sits on as looking to replace it with larger pulley At present all is well, and i understand it may be hard to remove the hand wheel after being on for years, so don't want to remove to measure until i need to If Constabulary doesn't come along with the correct answer I'll eat my hat. But in the meantime I'll throw this in, my Durkopp 239 and the 111s share a lot of components but that won't help much. The inside dia of my original Durkopp handwheel is 12.22mm. I would advise you to measure yours properly. When I did my Adler 69 I measured it at 14mm but I couldn't tighten the taperlock bush (the best way to do this). On measuring again I found the shaft was 13.5mm. Fortunately the shop where I bought it was just a 5 min drive and they were more than helpful so I was able to change it. I did a post on this inc a link to a short vid but I can't find it in my profile. IIRC apart from the 40mm pulley on the servo I think the whole lot (I posted the invoice) inc the 250mm pulley and the taperlock bush cost around £30 Quote
Members Constabulary Posted November 21, 2020 Members Report Posted November 21, 2020 I never measured it. I have to take off my hand wheel to measure... so... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
toxo Posted November 21, 2020 Report Posted November 21, 2020 3 hours ago, Constabulary said: I never measured it. I have to take off my hand wheel to measure... so... I'm gonna make a marzipan hat Quote
Members Constabulary Posted November 22, 2020 Members Report Posted November 22, 2020 hope you have a small head size otherwise your blood sugar level may explode Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
