Members Parfektionisto Posted December 11, 2020 Author Members Report Posted December 11, 2020 On 12/10/2020 at 10:07 AM, Constabulary said: if you can´t hold down the spring and tighten the set screws at once ask someone for a helping hand or DIY a tool - f.i. a tube with a cutout lengthwise. Length: measure from end of the flange sleeve the to shaft bushing on the right. Just an idea. Still can’t figure out how to put the spring and disk back in place. Might need an adjustable clamp or some sort of plier to compressed it. Quote
Members Parfektionisto Posted December 11, 2020 Author Members Report Posted December 11, 2020 Hi guys, Thanks for all the help and advices, really appreciate it. Anyway, I found a local repairman and he managed to revive the machine back to working condition. Problem resolved . Quote
Members chrisash Posted December 11, 2020 Members Report Posted December 11, 2020 So what was the problem and how did he solve it? Quote Mi omputer is ot ood at speeling , it's not me
Members Parfektionisto Posted December 11, 2020 Author Members Report Posted December 11, 2020 1 hour ago, chrisash said: So what was the problem and how did he solve it? There are couple of issues, the main issue be it the feed driving flange and the feed driving eccentric adjusting disk alignment was off, as I mentioned earlier I notice the screws on the flange were loose. Then I actually created more problem by removing the clutch belt pulley and didn’t put it back in the right alignment. This repairman is very patience and professional. He took his time and patiently put back the eccentric disk and spring which I didn’t know how to put it back after dismantling it and start inspecting the rest of the issues patiently. It took him around 3 hours to fine tune all the alignments. I’m so grateful for that. Quote
