Contributing Member MedusaOblongata Posted December 28, 2020 Contributing Member Report Posted December 28, 2020 I bought a lot of old, used leatherworking tools. Most I identified, cleaned up, and put to work. These few left me with some questions. #1 has this pattern, not sure what it would do. #2 might be a creaser(?) but it would leave a line pretty far from the edge if so. #3 has three curved sides heading towards the point. The edges aren't sharp, but they seem sharpenable, though I wouldn't see why. #4 has a point like a scratch awl, but the barrel is textured like a file, and the wire wrapping on the handle seems a bit like overkill since awls are simpleish. Maybe just homemade? #5 Is has a 1/8" hole from the end of the handle all the way through, though I don't know why #6 is flat on the back/top end, though it's textured around the sides of the top. The lower half is rough enough that side is uncomfortable to hold. I have rasp dremel bits similar in structure. #7 is well worn, but could has a curved and sharpened end #8 is round on both ends, knurled in the middle. It could be a pin punch for very large pins. #9 could be a very wide edge beveler, though it's so dull it would take an hour on a grinder to get any kind of edge on it. Thank you for taking the time to look over these for me. Quote
Contributing Member fredk Posted December 28, 2020 Contributing Member Report Posted December 28, 2020 quick look #1 is a counter sink maker, for woodworking, turn it to cut a countersink hole for screw head #9 is an upholstery tack lifter, push the v under the tack head to lever the tack off #6 looks like a tapered hole-reamer, for enlarging holes slightly #4 looks like a parallel hole reamer, for cleaning holes already made #8 looks like a nail setter - for the final whacking of a broad-head nail to set it flush with woodwork Quote Al speling misteaks aer all mi own werk..
Members zuludog Posted December 28, 2020 Members Report Posted December 28, 2020 (edited) I suspect these are some woodworking tools that have been mixed in, though they might be used when wood & leather are combined, perhaps a saddle or furniture, and I go along with FREDK #1 is a countersink bit, used to set a flat headed screw below the surface of wood. It fits into a carpenter's brace, as in brace & bit #2 is a tack lifter, for use on furniture and carpets #5 could be a turnscrew, used to fit grub screws and bushes that have just a couple of holes instead of a slot #8 is a wide diameter nail punch, used to set the head of a nail flush or just below the surface of wood Edited December 28, 2020 by zuludog Quote
Members ryano Posted December 28, 2020 Members Report Posted December 28, 2020 #2 is an edge wheel for shoe making or repair. #3 is a metal deburring knife used in machining, etc. #5 looks like a spanner screw driver. #6 has me baffled as I have never seen holes drilled in the flutes like this tool???? Quote
Members Aven Posted December 28, 2020 Members Report Posted December 28, 2020 #2 is a glazing iron. Used on the welt of shoes. They come in different widths. It doesn't leave a groove, it gets heated up and smooths the welt. The lip rides the edge of the sole so that you don't burn the upper. There are ones without a lip that are used on the heel. Quote
Members ryano Posted December 29, 2020 Members Report Posted December 29, 2020 22 hours ago, Aven said: #2 is a glazing iron. Used on the welt of shoes. They come in different widths. It doesn't leave a groove, it gets heated up and smooths the welt. The lip rides the edge of the sole so that you don't burn the upper. There are ones without a lip that are used on the heel. Aven, I knew that it was used to go around the edge of soles, so the wheel just aides the tool by creating less friction as it goes around the edge of the sole? Why do some of these tools have different coarse straight knurl lines on the wheels? Also why does the part of the tool that smooths out the welt have a small edge landing, almost like the edge guide has an edge guide? I have seen these tools with different wheels patterns (more like knurlings) on them and also have seen them heated and used as decorative markings on the soles of shoes inbetween the stitching and edge of the sole, which is not be the proper use of the tool. Thanks, Quote
Contributing Member fredk Posted December 29, 2020 Contributing Member Report Posted December 29, 2020 I'm not sure #2 is for a shoe sole, I think its a book binders edger Quote Al speling misteaks aer all mi own werk..
Members Aven Posted December 29, 2020 Members Report Posted December 29, 2020 Ryan, it is entirely possible I am wrong. I didn't see a wheel, but I'm viewing the forum on my phone. Quote
Members Sheilajeanne Posted December 29, 2020 Members Report Posted December 29, 2020 (edited) I'm guessing #9 is a tack/nail puller. Oops, Fred said that already! Edited December 29, 2020 by Sheilajeanne Quote
Contributing Member MedusaOblongata Posted December 31, 2020 Author Contributing Member Report Posted December 31, 2020 Thank you so much. You guys are smart and helpful. I appreciate it. Quote
CFM Frodo Posted December 31, 2020 CFM Report Posted December 31, 2020 #6 4-3/4" COTTON GIN SPINDLE SURVEY SPIKE usually used in asphalt Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles Stand your ass up during the National Anthem
CFM Frodo Posted December 31, 2020 CFM Report Posted December 31, 2020 # 8 is a drive pin punch also know as a drift punch here is a glock with a roll pin and punch used to remove it Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles Stand your ass up during the National Anthem
Contributing Member fredk Posted December 31, 2020 Contributing Member Report Posted December 31, 2020 2 hours ago, Frodo said: #6 4-3/4" COTTON GIN SPINDLE SURVEY SPIKE usually used in asphalt well, there ya go. who would have thunk you'd find one in amongst leather working tools. In the UK the survey people use a rather plain slightly raised head brass pin/nail thingy Quote Al speling misteaks aer all mi own werk..
Members MarlinDave Posted December 31, 2020 Members Report Posted December 31, 2020 # 6 for sure spindle off the Head of a cotton picker. Twists and pulls cotton out of bolls. I use them as a stamp and punches. Quote
Members ryano Posted December 31, 2020 Members Report Posted December 31, 2020 On 12/29/2020 at 11:47 AM, fredk said: I'm not sure #2 is for a shoe sole, I think its a book binders edger I have a tool like the #2 tool where the wheel height is adjustable. Whether it is used on soles or books, I think the wheel itself is used to mark the leather. I have seen this wheeled tool used, by 2 shoe makers on youtube, to mark the sole of high end shoes like Allen Edmond's. With having an adjustable wheel height/depth of just over 125", I wonder if it is used for something else other than marking the leather? ?? Quote
Members Aven Posted December 31, 2020 Members Report Posted December 31, 2020 7 hours ago, Frodo said: #6 4-3/4" COTTON GIN SPINDLE SURVEY SPIKE usually used in asphalt Frodo, I have never seen such a spike, but I surveyed on the other side of the country. We always just used Magnails or a railroad spike. From what I can see #1 comes to a definite point. I think Zuludog is correct, it's probably a countersink. Quote
CFM Frodo Posted December 31, 2020 CFM Report Posted December 31, 2020 https://www.karaco.com/marking-supplies/nails-and-tacks/4-3-4-cotton-gin-spindle-survey-spike/ Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles Stand your ass up during the National Anthem
Members Aven Posted December 31, 2020 Members Report Posted December 31, 2020 Thanks for the picture of it in it's natural environment. As I said, we used Magnails. Almost as long, but cheaper, running about 32¢ for the 3 1/2" long ones. But as I said, I surveyed on the other side of the country. Different place, different norms. Quote
Members ryano Posted January 2, 2021 Members Report Posted January 2, 2021 (edited) On 12/29/2020 at 11:47 AM, fredk said: I'm not sure #2 is for a shoe sole, I think its a book binders edger I finally found what #2 tool is I have a tool like the #2 tool where the wheel height is adjustable. Whether it is used on soles or books, I think the wheel itself is used to mark the leather. I have seen this wheeled tool used, by 2 shoe makers on youtube, to mark the sole of high end shoes like Allen Edmond's. With having an adjustable wheel height/depth of just over 125", I wonder if it is used for something else other than marking the leather? ?? #2 is a Slide Box Seat Wheel Tool for shoe and boot heal patterns. Here is a link: https://www.carreducker.com/shop/shoe-making/tools/slide-box-seat-wheel/ Edited January 2, 2021 by ryano Quote
Members seabee Posted January 2, 2021 Members Report Posted January 2, 2021 Hi, #6 is spindle from a cotton picker machine. I operated on in Buttomwillow, Ca. in my youth. They make great pin drive punches. Howard Quote
