CFM Tim Schroeder Posted January 7, 2021 CFM Report Posted January 7, 2021 (edited) Finally worked on my last stand. A week before Christmas when I put my daughters boots together I couldn't even put last with a 7/16" bushing on my stand. I had a piece of wood closet rod so I drilled a 7/16" drill bit into it and left it in the rod and dropped it in the main tube and used that to build that last pair of boots. Now I have 3 different size pins that screw in. Their made out of a 5/8" stainless all thread. The base is a fly wheel I knocked the gear ring off of so the eye bolts screw in and are removable. If I'm building boots I'm working in my wife's formal dining room so I'm barefoot or in socks and kicking those eyebolts would hurt. Now I can leave rubber soles strap down over night while the glue dries. The shiny pipe for the toe support and the interchangeable piece are from an old Delta table saw fence somebody stole the fence too. I have a longer set of rails I'm gonna build a stand that will bolt on to the fly wheel to hold the heel while you tie a cable to the small hole in the last and the toe support bar to use like a lever and pull those hard to remove last. I saw the idea on a Lisa Sorrell video. I can drop the wood peg breaker/rasp into the stand and it's pretty steady. I'm making the regular last puller that will drop in the main tube. An 1 1/8" solid round bar with a 45 degree bend at the top. I saw this one in the fourth picture on You Tube. The boot top stretcher in the background sits on the stand as well. There is one waxed thread catcher when sewing on the welt but if I have problems with it I will just put a bolt in it and have to use a wrench to adjust it. Edited January 7, 2021 by Tim Schroeder Quote
Members Aven Posted January 7, 2021 Members Report Posted January 7, 2021 Well done Tim. I like that a lot. I would love to have it in my shop. Quote
Members DrmCa Posted October 31, 2021 Members Report Posted October 31, 2021 Project "Anti-crutch" Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
CFM chuck123wapati Posted November 1, 2021 CFM Report Posted November 1, 2021 nice indeed!!! Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
