Do I want a a bench or desk mounted splitter ?
  • Ambassador
I do occasional belts and have begun to tinker with other items that require splitting. I don't want to invest in a large expensive 8" $500.00 splitter either but it is way to difficult to get good results on wide leather using an EZ Skiver or safety skiver.
Does anyone have information on the availability of say a bench or desk mounted splitter that could handle 10-12 oz or less?
If there isn't one out there some of you machinists could do real well making one for crafters like me.
Just a blade 4-6" (MAX) wide and a control arm to adjust for consistent splitting. Small and desktop/workbench mountable.
ANY information( or used one) would be appreciated.
thanks
pete
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Pete,
Good topic on one of those things a guy trades around/up until he finds the one that works for him. TLF has a little bench one for around $200. I got one thrown in with a tool set several years ago. The blade was not very good. I got one of the "Professional" model ones from TLF on an end-of-the-month inventory reduction deal a few years ago. It was pretty good, but only split down to about 4 oz due to a design issue. Several others on another forum had the same experience, but that may have been fixed in the meantime. The blade on mine held an edge pretty well. They do well for splitting, easy to adjust depth, and the "stop" makes repeated depths easier. Only issue I had was having a strap "ride up" the blade and chop off sometimes. Not something that happened often, just at bad times. You can do lap skives with these easily.
My old tool refurbishing buddy sold me an American 6" handcrank splitter. Great for firmer leathers like skirting, strap, or firm latigo. Softer leather tend to ball up between the feed wheels and the blade. If you keep some tension the piece by pulling, it does alright on soft stuff.
My far and away favorites are Chase pattern splitters. These are simple old relics, and I haven't heard of any made in the last 50 years (and probably a lot longer ago than that). I have an 8" and a 10" CS Osbornes. They have top and bottom feed rollers, and when adjusted properly, the blade can be set just inside these wheels. The leather has no place to go but into the blade, and can't ride up or down. If they get out of level, they are easily adjusted by loosening one side and moving the gearknob a tooth or two either way. They are pretty handy for thinning a strap end to go around a buckle. I can't do a lap skive out to a feathered edge easily with the Chase. Doesn't matter to me, they split better for me, and I've got two skivers anyway. The Chase splitters show up on ebay pretty often, and normally don't go for huge prices. Bob Douglas usually has some too. A couple of us were discussing these. They are so different looking than the old Randalls and Osborne 84 and 86, that it must just scare people off.
Bruce Johnson
Malachi 4:2
neel's saddlery has splitters that handle up to 4" wide material for about $169 & they inclide a strap cutter that also mounts to a bench. I just got one recently but haven't used it yet, but it looks to be of pretty good quality. Other members here have the same one.
Neel's Saddlery & Harness
12712 South ave.,
North Lima, ohio 44452
email: neelre@comcast.net
i have the neels splitter - borderline worthless, well it is better than that - but it is not what I would characterize as "excellent and a must-have" - it slips out of adjustment easily (adjusted only on one side of the blade....)...if you have to have a splitter, make sure you get one that allows the height adjsutment to really "lock" in place.....
the strap cutter on the other hand is very useful and I use it all the time
YMMV
steveb
I've got the neel's splitter. Have been satisfied, but not sure how the more expensive splitters work. Is it really worth paying $300 for the Tandy or osborne 8" splitter?
The Neel's splitter has a 6" blade. Does that mean it can really only do 4" effectively, because 4" or wider is pretty difficult to pull through?
ed
Pete,
TLF has a small economy splitter that works pretty well, it is called a "Craftool High-Tech Leather Splitter." I bought mine about seven years ago for $80.00 and still have it on a bench in my shop. There are a lot better splitters out there but for what your trying to pull down, this one would work great with a small investment. I have to file on the blade about once or twice a month but other than that it works great.
Hope this helps.
12712 South ave.,
I'm sorry. it IS 6", not 4" as I said before (, although it would be difficult to pull a 6" piece through, because the blade is 6" wide). Probably 5"or 5-1/2" would be more practical. Again, I have not set it up nor used it yet, so I can't tell how good it really is.
I like the handle, unlike some of the ones being sold on ebay currently that have no handles to hold the blade to the leather.
Edited by whinewine
I have one of those, too, and it works okay for pieces up to 4" wide. The blade does not hold its edge quite as well as the higher quality (read, "more expensive") models, but if you're willing to strop the blade after each use, it works well for occasional use.
Kate
The 8" twist handle copy of the Osborne that the TLF sells is a poor copy and the bevel on the blade is only about 1/2 of the blade where as if you look at the origanal osborne twist handle the bevel goes clear back to where the blade flattens out for bolting to the frame. The longer the bevel the easier the pull. If this is the type of splitter you are looking for either buy an original Osborne or the copy that Campbell-Bosworth makes are both worth the money. Like I said the TLF model is a poor copy geared to hobby use. Greg
