7 hours ago, StickHer said:
i dont have the tools to sharpen it atm, idk if weaver sends out dull chisels. any recommendations on sharpening sets/tools
We don't know your location so we don't know what terminology you'll understand best. But I think you may be in UK or Europe?
Get some different grades of 'wet & dry' abrasive paper, available from a car accessory/parts shop, eg Halfords, costs about 60p/£1 per sheet. Get 320, 600, 800, 1200
Glue strips of these to lolly sticks (available The Works for about £1 per packet)
use these on the bevels of the chisel teeth/prongs, working from 320 to 1200. But also do all four of the sides of the teeth/prongs. Spend time doing this. A couple of hours or less, not just a minute or two
You should be able to get the chisels really sharp, sharp enough that with a very light pressure they will cut slots into a sheet of writhing paper
and, a personal thing to me; I don't like that sort of mallet. I gave mine away. I prefer a similar one but it has an 'ordinary' shape with flat round faces. Like this one; https://www.amazon.com/Leather-Carving-Hammer-Leathercraft-Cowhide/dp/B07H8BH9JR/ref=pd_rhf_d_dp_s_pd_sbs_rvi_sccl_2_13/143-2905049-6470749?pd_rd_w=VK8cg&content-id=amzn1.sym.a089f039-4dde-401a-9041-8b534ae99e65&pf_rd_p=a089f039-4dde-401a-9041-8b534ae99e65&pf_rd_r=ZGVW9JPVPPPCMSQJG7YJ&pd_rd_wg=Vg0YA&pd_rd_r=c2c5f3fb-02a8-4177-8940-f75a10c8369e&pd_rd_i=B07H8BH9JR&psc=1
I find I can give a better whack with it than the other
  • Replies 43
  • Created
  • Last Reply
Top Posters In This Topic
thank you for the responses. will go to harbor freight to pick up sand paper and potentially a crocus cloth.   should i also invest in some sort of creams , gels, oils, wax, etc ?
StickHer,
I like to use a Stanley or box cutter knife with premium blades. I strop the blade often on a strop made from a wooden paint can stir stick. Always strop the blade and you won't have to change it often. I use the Harbor Freight Green Compound stick on my strop....it's good and inexpensive at HF. Also, pick up a poly hammer with the screw in heads at HF. Good tools to start with.
Oh, don't buy sand paper from HF. It is pure junk. Get good 3M sandpaper.
-JOE
Edited by AlamoJoe2002
Harbor Freight Sand Paper Sucks
  • CFM
:17: HF is great for a lot of things, but their sandpaper is garbage.
