I have 2 juki lu1508nh and the clamp that holds the gear that operates the bottom shaft keeps coming loose. I have put it back several times but it keeps coming out of both the new machines. I have an older one that It has never happened to and they all do the same job. Does anyone know what causes it and how to fix it?
It has a set screw that is on the outside of the pulley.You might have to take the belt off to get to it.Part#43 on page 10 in the parts manual.
Juki_LU-1508N,_-1508NH.pdf
Edited by CowboyBob
Page 10 is just a parts list
That set screw #43 is what locks the offset adjustable pin that is loosening that you are having a problem with.
Edited by CowboyBob
Ok I will try this on Monday and give you an update. Thank you
I went ahead and loosened the oblong screw and tightened the screw in the gear. Then retightened the oblong screw. Hopefully it will hold now
The Juki 1508 Engineer’s Manual (lu1510n.pdf ) describes how the adjustment of the safety clutch torque works, on page 32/33. Here’s a screen shot of the relevant section:
Edited by Uwe
It worked fine today. I'll update if it happens again
