kgg Posted November 5, 2022 Report Posted November 5, 2022 1 hour ago, ChipperBags said: I hope my pictures make it. Once you get the other photo's sized down please post so we can see the full thread path. We maybe able to offer some more suggestions. What I see so far in the photo: i) The top thread needs go in the top hole of the pin as you have done but it also needs to wrap around the pin and come out of the bottom hole so as to make a "S" shaped wrap around on the pin. This will help in getting the coils out of the thread and add a very slight top thread tension. It appears you are using a 8oz spool of white polyester thread and I assume the little 4 oz spool on the top cover is your N66 bonded nylon. ii) Are you trying to use the little 4 oz spool of thread on the top of the machine or are you replacing the white polyester thread with the black N66 bonded nylon? iii) The base of the top thread spool needs to be better secured so as not to move around on the table from machine vibration or accidental bumping of the spool. The center of the thread spool should be directly under the thread support arm. As the amount of thread on the spool reduces the easier it is for it to wander off and explore the floor. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members ChipperBags Posted November 5, 2022 Members Report Posted November 5, 2022 (edited) I got the Image Size app. Sailrite Use Video The video above is where I got my threading instructions. What other photos do you want? Chip Edited November 5, 2022 by ChipperBags Quote
Members ChipperBags Posted November 5, 2022 Members Report Posted November 5, 2022 Okay, here is another photo. Quote
kgg Posted November 5, 2022 Report Posted November 5, 2022 3 hours ago, ChipperBags said: The video above is where I got my threading instructions. The instructions are good basic instructions. When doing the bobbin tension as the method shown in the video their method is a good starting point but the drop test will provide a better method or you could use a bobbin thread tension gauge to be even more accurate. To check the top thread tension a top thread tension gauge can also be used to adjust / set the top tensioner. In the end it is really going to come down to what and how thick/tough a material/leather you are trying to sew and choosing the right thread needle combination. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Straycat62 Posted November 13, 2022 Members Report Posted November 13, 2022 I started out on a Sailrite LS1. Bought used off CL. It had been sitting for a minute and had dried oil(varnish?) on the guide rods/needle bar and it wasn't functioning right. After a cleaning, started working well. Like others have said-They are good for what they are, a portable walking foot. Good for someone who doesn't have the space for a full size machine. They have it locked down customer service wise. Call and can talk to a person. Their owners manuals are spiral bound and easy to navigate. Nice glossy pictures for descriptions. Webste is easy to navigate to order replacement parts and accessories. I ordered smooth presser feet and feed dog for mine to sew leather. The day they arrived, I received a link for a Sailrite video depicting how to change out the parts. I thought that was classy. I moved up to a full size industrial triple feed but kept Sailrite also for now. Quote Seiko LSWN-8BL flatbed walking, Seiko CW-8B-1 cylinder bed walking, 1903 Singer 31-15, Singer 29K71 (Sutton Landis SL71), Juki DDL 5550, Sailrite Ultrafeed LS1, 1967 White domestic
Members ChipperBags Posted November 18, 2022 Members Report Posted November 18, 2022 I need the left smooth foot and feed dog or the left zipper foot. I wish the Leatherwork came with all the feet. I’m trying to make 1/4” piping for my current project in vinyl, but I can’t get close enough to the cording… I might have to do that job on the Singer 128 with a zipper foot and some tape on the bottom of the foot so the vinyl feeds adequately. I tested the Sailrite tonight using a #18 needle (leather) and #69 black nylon thread. I sewed a test strip similar to the actual cording strip I’m gonna make. The machine was flawless… the operator caused two alternating missed stitches.. I was pulling the fabric through and trying to turn it… Whoops! I’m learning! Quote
Moderator Wizcrafts Posted November 18, 2022 Moderator Report Posted November 18, 2022 3 hours ago, ChipperBags said: wish the Leatherwork came with all the feet. I’m trying to make 1/4” piping for my current project in vinyl, but I can’t get close enough to the cording Sailrite sells piping foot sets for their machines. Since you are using vinyl, feet with teeth won't be a problem. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted November 18, 2022 Report Posted November 18, 2022 (edited) 10 hours ago, ChipperBags said: I need the left smooth foot and feed dog or the left zipper foot. This link to Aliexpress my help with finding odds and ends for your portable walking foot machine. The Chinese versions of the Sailrite are called 106-rp, the quality???. I just type in 106-RP in the search line: https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20221118042012&SearchText=106-RP&spm=a2g0o.productlist.1000002.0 kgg Edited November 18, 2022 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members ChipperBags Posted November 18, 2022 Members Report Posted November 18, 2022 Do you think I should get that one (for the last-1, of course) or the left zipper foot? Quote
Members ChipperBags Posted November 21, 2022 Members Report Posted November 21, 2022 Okay, I’m ordering the left zipper foot and the standard foot for the LS-1 (when I get a few bucks). As of right now, I’m making a sewing machine cover out of vinyl. Chipper Quote
