Width: 20/18mm, Thickness: 4-2.8mm
Exterior: French goat (Alran)
Lining: French Calf (Haas Zermatt)
Stitching: 2.7mm/10spi, Xiange twist 0.3mm
Edited by Danne
Tongue holes? Don't use that wheel punch, get a vertical punch.
I've just started using a digital caliper against a 1/4" steel edge to get the exact center, it has stepped my precision up to an immaculate degree, keep the dividers for equal spacing along the centre line, then a spring punch to define the hole centre.
Very nice leather work and great photography.  Wonderful way to display your work.  Thanks for sharing.
I didn’t do any holes yet, might give it to someone and just make one hole. That ”wheel punch” give good results though. And alignment is made with a paper template. But a vertical punch set is on my list also :)
Thank you :)
@Rahere I thought I show you how I do. Don't get me wrong here, your solution is also a good solution, the important part isn't how we do things as long as it gives us a good result, but I really like this.
I align it with my wing divider and hold it in place (you can tape it in place depending on leather) then I make an impression with my hole punch, remove template and align to my impressions and make holes. It would be a little less finicky with regular vertical punches though.
