Members Danne Posted July 12, 2021 Members Report Posted July 12, 2021 (edited) I have Ksblade in 3mm/9spi, and another good brand for 2.7/2.45mm. I don't need to mention the other brand, it's good. But the downside is that most brands don't center to a line like Ksblade. and this is what can happen :/ Hours of work going straight to the trash can. This is NOT Ksblade Edited July 12, 2021 by Danne Quote
CFM Hardrada Posted July 12, 2021 CFM Report Posted July 12, 2021 Sinabroks? Mentioning it is probably a public service, specially if it's expensive. Quote
Members chrisash Posted July 12, 2021 Members Report Posted July 12, 2021 What makes you think its the tool and not the skill of the operator? Quote Mi omputer is ot ood at speeling , it's not me
Members Tugadude Posted July 12, 2021 Members Report Posted July 12, 2021 In the end, quality is the result of both tool and operator. At least most of the time. The average pro golfer could walk into any department store and buy the cheapest set of clubs and still beat most any amateur. Lee Trevino made a living off of hustling members at a golf course. He showed up with a single, old, rusty club and would proceed to beat the dickens out of them. KS Blade makes both diamond-shaped chisels and pricking irons that are more of a straight, rectangular tooth. Each will penetrate leather, so the pricking irons can be also be used as stitching chisels as well as for marking holes. They have a very slight taper to them. They make round ones too, for what it's worth. The "double line" irons are interesting! Quote
Members Danne Posted July 12, 2021 Author Members Report Posted July 12, 2021 12 hours ago, Hardrada said: Sinabroks? Mentioning it is probably a public service, specially if it's expensive. Yes, I haven't tried Sinabroks, but they might also be a good alternative. Quote
Members Danne Posted July 12, 2021 Author Members Report Posted July 12, 2021 (edited) 11 hours ago, chrisash said: What makes you think its the tool and not the skill of the operator? I don't say it's not possible to get a perfect result with irons with "flat prongs" I have done a decent amount of straps with 10-11SPI with those tools and with really good results. I mentioned this because I see it as a big benefit from Ksblade. It would be the same to compare a manual creaser you heat over an alcohol lamp with an electric creaser. We all know that a manual creaser can give you perfect results, but what do I see as a benefit with an electric creaser? the fact that it will keep a consistent temperature. I also like that Ksblade have a nice weight distribution, and are ergenomically awesome in my opinion. The downside with Ksblade is that they cost more than a lot of the alternatives. And of course the reason for my failed holes here wasn't because of bad tools. It was me who failed to use the tool in the correct way. I just wanted to share why I prefer Ksblade, I personally find it easier to use. Edited July 12, 2021 by Danne Quote
Members Danne Posted July 12, 2021 Author Members Report Posted July 12, 2021 7 hours ago, Tugadude said: In the end, quality is the result of both tool and operator. At least most of the time. The average pro golfer could walk into any department store and buy the cheapest set of clubs and still beat most any amateur. Lee Trevino made a living off of hustling members at a golf course. He showed up with a single, old, rusty club and would proceed to beat the dickens out of them. KS Blade makes both diamond-shaped chisels and pricking irons that are more of a straight, rectangular tooth. Each will penetrate leather, so the pricking irons can be also be used as stitching chisels as well as for marking holes. They have a very slight taper to them. They make round ones too, for what it's worth. The "double line" irons are interesting! I was talking about the European version, with the slightly rounded prong tip. In my opinion they really shine when it comes to leather where it can be hard to see a scribed line, because they are so easy to align. Quote
CFM Hardrada Posted July 12, 2021 CFM Report Posted July 12, 2021 21 minutes ago, Danne said: they really shine when it comes to leather where it can be hard to see a scribed line, because they are so easy to align. Please describe your aligning method, because I had a helluva time getting straight lines with them when I first got them! I've found a way by now, but every now and then I still get the occasional crooked line. Quote
Members Danne Posted July 12, 2021 Author Members Report Posted July 12, 2021 (edited) 40 minutes ago, Hardrada said: Please describe your aligning method, because I had a helluva time getting straight lines with them when I first got them! I've found a way by now, but every now and then I still get the occasional crooked line. I use my wing divider (which I have made sure have the correct sharpness, not to sharp to cut into leather, but to make a "groove/impression" then I just lay down my prongs in that groove with very little weight, and I can feel how i'm in the centre (Because the prongs have a radii too them. Next step is to make a very light impression, if it would be a little off I can realign. Once it's good I push down my iron (by hand) to make a little larger impression. When it's finished all around my project it's easy to put my iron in those holes and punch through. 9/10 situations with my Ksblade I only punch through one layer before assemble, and open them with an awl (Because I like to punch wallets and card holders from the outside, and since my inside have skived edges it would be hard to punch a straight hole. Also a tip, if you make a wallet/card holder and just punch the exterior. If you print or make your template on paper, and tape it onto your leather, your can pre-punch your paper template. Tape it in place, push your iron by hand through your holes in your template. cut out your exterior. And you have your holes in the correct place. Edited July 12, 2021 by Danne Quote
Members Tugadude Posted July 12, 2021 Members Report Posted July 12, 2021 If you look closely at what KS Blade refers to as their pricking iron, it does have a slight radius to the teeth. I can see how they might sit down in a groove that way. Otherwise, you just have to look down at an angle and straddle the line. Doable, but certainly not easy. Quote
