Members n866 Posted August 12, 2021 Members Report Posted August 12, 2021 So I stumbled into a deal I couldn't pass up on a 205-370. It belonged to a friends grand father who passed 3 years ago. The story goes that he got it as a replacement for an older singer machine that he had modified to run on air when his shop burnt down. His insurance replaced it with this one because it was the only pneumatic machine they could find. I'm embarrassed to say how cheap I got it, but they were very happy to see it go to someone who could use it because he set it up & supposedly it has less than one hour of run time on it. I never thought it would be in my price range to own a real 205 so I have never done much research on one. I'm VERY inexperienced with any machines much less one of this caliber. Of course I was not looking for a pneumatic machine, so I plan to set it up with a servo at some point, but I am planning to grab a pressure regulator & set it up in my garage just for giggles. I've been reading several threads on here about 205's & watching a lot of youtube videos. If anyone has any suggestions, (or any other resources or recommended threads on here about set up, maintenancing, tips or tricks, etc) I would really appreciate the support! I'll be slowly chipping away at it because its hotter than hades out in the garage right now, and I've got some other work to get caught up on in the next month or so anyway. I'm really excited to get started playing with it & look forward to learning a new skill set. I'm positive I'll be investing in some more hardware, guide plates, different style feet, etc if necessary. thanks in advance! Quote
Members Silky Posted August 12, 2021 Members Report Posted August 12, 2021 Nice machine ! Those (Gast ? ) air motors tend to be a bit of an air hog, can be rough on a small compressor. BTW, what is that coupe in the background ? Cheers, Quote
Members jrdunn Posted August 12, 2021 Members Report Posted August 12, 2021 When you get ready for a servo motor, I suggest Toledo Industrial Sewing Machine. He's a great guy to do business with. JM2C Jim Quote
Members n866 Posted August 13, 2021 Author Members Report Posted August 13, 2021 18 hours ago, Silky said: Nice machine ! Those (Gast ? ) air motors tend to be a bit of an air hog, can be rough on a small compressor. BTW, what is that coupe in the background ? Cheers, Silky, I've got a 60 gallon Snap-on that should handle it just fine, especially for the small volume I plan to run on it, but like I said I'll likely go to servo especially since I plan to move it inside. The coupe is my 47 Plymouth coupe. It's just a dirty old hotrod that's been in the family for a long time. Small block Chevy & a Ford 9" It's running and driving but long over due for me to go ahead & really blow it apart & start the lengthy task of the sheet metal repair! 16 hours ago, jrdunn said: When you get ready for a servo motor, I suggest Toledo Industrial Sewing Machine. He's a great guy to do business with. JM2C Jim Thanks Jim. He's on my list. I'd like to try & support an Ohio business if possible & of course its great to have a resource for questions too! Quote
Members Ken Nelson Posted August 14, 2021 Members Report Posted August 14, 2021 If you put a servo or clutch motor on it for that matter, you will want to also put on a speed reducer. Quote
Members n866 Posted August 17, 2021 Author Members Report Posted August 17, 2021 On 8/13/2021 at 8:00 PM, Ken Nelson said: If you put a servo or clutch motor on it for that matter, you will want to also put on a speed reducer. Thanks Ken. I'll be looking into that as well. Quote
Members Handstitched Posted August 19, 2021 Members Report Posted August 19, 2021 Can't say I've seen too many pneumatic sewing machines. It would get pretty noisy I'm guessing ? HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members shoepatcher Posted August 19, 2021 Members Report Posted August 19, 2021 Pneumatic motors used mostly by the Amish. I would remove and replace with servo and speed reducer unless you are Amish. If not, I would then sell the pneumatic motor to he Amish. They cost more than servos. Not so noisy as the compressor is usually outside in Amish establishments. Great machine. I have one with all the toys on it. It needs a good cleaning and going over. Take your time and do it thoroughly. Bob at Toledo or Allen Burkholder at Weaver can answer any questions you may have. glenn Quote
Members n866 Posted August 23, 2021 Author Members Report Posted August 23, 2021 On 8/19/2021 at 3:27 PM, shoepatcher said: Pneumatic motors used mostly by the Amish. I would remove and replace with servo and speed reducer unless you are Amish. If not, I would then sell the pneumatic motor to he Amish. They cost more than servos. Not so noisy as the compressor is usually outside in Amish establishments. Great machine. I have one with all the toys on it. It needs a good cleaning and going over. Take your time and do it thoroughly. Bob at Toledo or Allen Burkholder at Weaver can answer any questions you may have. glenn Thats a good idea! Quote
