Members Chelan Posted August 23, 2021 Members Report Posted August 23, 2021 (edited) Note: I apologize for wasting anyone's time if this topic has already been covered. I did a general search, but did not get any specific results. Background: I recently purchased a Consew 146 RB-A1 from a company that repairs high end outdoor gear. The machine looks brand new, ran like a dream during demo and was at a price I couldn't pass up. It was one of the ones built in Japan. I replaced the clutch motor with the Sailrite Workhorse servo motor, changed out the thread to V92 and the needle to a #18 for the sail work I will be doing. Questions: 1. The balance wheel is small in diameter and I find that it takes quite a bit more 'umph' to rotate it (compared to my non walking foot machines) when I go to raise the needle bar. I don't hear anything binding, nor does it matter if I have the belt to the motor on or off. Is it just a function of this being a walking foot machine and it just takes a bit more to move the lever arms and whatever else? Or, is there something I need to loosen? 2. In setting up the tension, I am real close, but I do sometimes miss a stitch. I also have more luck picking up the bobbin thread when the needle moves to the left position (zig zag) and less at the right position. I wanted to make sure I was adjusting the timing between the hook and needle properly, but there is a woeful lack of instructions (or hard to understand instructions) in the archaic Consew 146 manual. Email messages to Consew go unanswered. Is there anyone out there who can give me good, clear instructions for setting the hook timing on this particular machine? And, has anyone found an actual manual for the 146 RB that might have been updated since it was first printed in the 1960's or 70's? Heck, they still sell this machine. Thank you. Paul Denny Edited August 23, 2021 by Chelan Quote
Members trash treasure Posted August 25, 2021 Members Report Posted August 25, 2021 I looked at the manual for this machine, and the timing instructions seem "odd". It looks like they're telling you to time the machine at the right zig zag position, but having the hook cross the needle while the needle bar is stationary, at the bottom of it's stroke , NOT after the needle has begun upward travel by 2mm, or whatever. I have NO experience with this machine, but I don't understand a timing instruction like that - The slight upward travel of the needle is what forms the loop that the hook catches on any machine I know of - That's just the way it works. But, that's not much help, as like I say, I have no experience with this one - Hopefully someone that does will chime in....... Quote The model number giveth, and the subclass taketh away ......... Sometimes
Members Chelan Posted August 25, 2021 Author Members Report Posted August 25, 2021 Hello TT: That's exactly what I am running into: The old manual (actually the old, new, new-old) manual is hard to decipher on many topics. It sounds like you understood it about as well as I did...and I have experience with other Consew sewing machines! Apparently Consew figures the timing should be so intuitive--no matter the skill level of the owner--that few instructions are needed. I'd like to know: Do you time the hook/needle with the zig-zag set to the widest stitch or the width of stitch most likely to be used; should it be timed with the needle fully to the left or to the right? I am sure I will be able to figure it out through much trial and error, but what a pain. As I mentioned before, I got no help from Consew. Now, on a bright note, I do find that Sailrite has a very good manual for their Professional Sewing Machine which looks very similar to my Consew 146 RB. I am going to make some adjustments based on their manual and see what happens. There is nothing to lose at this point. I do appreciate your response! Quote
Members nylonRigging Posted August 25, 2021 Members Report Posted August 25, 2021 (edited) I got this machine and book , I always remembered it as being a little paininAss to get the timing just perfect . Tuning to get strait stitch and zigzag stitching threw all the stitch lengths, and plus all doing it all in reverse . That is a real Good quality straight/zigzag combo stitch machine and yours in the Pic. is made in Japan model to . I remember that when it say's .. " set Hook Gib 0.5mm " .. that there for me .. was just a tiny plus\minus to get it all to clik . also I remember 1st to set the needle center and to se the zigzag width all proper adjusted, before start on the needle-hook timing . - Edited August 25, 2021 by nylonRigging Quote
Members Chelan Posted August 27, 2021 Author Members Report Posted August 27, 2021 Thank you, Nylon Rigging!. I have these illustrations in one of the manuals I downloaded, but your explanations help a lot. I will be giving the hook timing another go (along with proper alignment of the inner and outer presser feet) on Saturday or Sunday. I might be able to guess, but what is the Hook Jib? The hand drawing leaves a little bit to be desired... Chelan Quote
Members nylonRigging Posted August 28, 2021 Members Report Posted August 28, 2021 (edited) 7 hours ago, Chelan said: Thank you, Nylon Rigging!. I have these illustrations in one of the manuals I downloaded, but your explanations help a lot. I will be giving the hook timing another go (along with proper alignment of the inner and outer presser feet) on Saturday or Sunday. I might be able to guess, but what is the Hook Jib? The hand drawing leaves a little bit to be desired... Chelan ( Gib ) .. not, Jib . and I know . the factory book illustration looks like they hired a chimpanzee to do there drawing ...LOL the Gib is ( plate-part ) sits behind the Hook, that is part of the outer bobbin assembly, and the Gib hold the basket on it's guide track that spins inside the outer Assembly . The outside bobbin assembly Hook and Gib . the Basket that spins inside it, is what you snap your M-size bobbins into . It is something that I am not an expert in at doing because I might only 'Time' do it every 2 or 3 years on the 146RB , but I remember it all gets a lot clearer when you start doing and watching the needle plunge on that stroke on the bobbin assembly . And, to show you ... I just dug out an 'older' used , complete bobbin assembly for 146RB1A , that I keep in case I need to rob a screw or part . KEEP all old bobbin assembly's, when you repair. because all those screws on bobbin assembly are all obnoxiously tiny and very easy lost if dropped . ... LOL , And I already have robbed a screw off this old Gib . Popping a Pic. of it and try to point to ( Gib ) . and if you look at yours on your machine . You will see it is held on with 3 screws . The tip of my pencil is what the manual picture is showing , in relation to the needle plunging past end of Gib . .. also, everyday of sewing, put a tiny drop of oil on that little guide track the basket spins on . - - Edited August 28, 2021 by nylonRigging Quote
Members Chelan Posted August 29, 2021 Author Members Report Posted August 29, 2021 Hello Nylon Rigging: Thank you so much for the further explanation and the photo! In fact, I just finished printing it out and will put it with my "manual." I have to agree with you: The illustrations in the owner's manual are probably worse than what I could draw and the saddest thing about this all is that this is the same instruction manual you will get (maybe) with any of the Consew 146 RB machines you can buy today! Come on, Consew...get with the program. Unfortunately, I only have one, complete bobbin assembly (the part that the bobbin and bobbin holder sit into and contains the hook), but spare bobbin holders and bobbins (of course). I even bought a few of the M size Hembobs to save me some time. Anytime I take apart something like this, I usually do it inside a baking pan so in case I drop a screw... O.K. I was up at the sail loft yesterday and spent quite a bit of time replacing a couple of things on my table--new drawer and a new treadle peddle. The new drawer is a total pce o'crap and the new pedal is barely acceptable. Waste of time. Then, I got into the timing of the hook. Unfortunately, I started off by using the Instructions I took off Sailrites Professional sewing machine, which is fairly close to Consew 146. Getting to the screws that hold the hook assembly to the shaft was a major pain and things kept shifting. When completed with the timing, things were going fairly well, although it took me 5 or 6 rotations to hook the bobbin thread. About the time I was satisfied with my zig zag stitches and ready to get to work, I started to miss a stitch here and there; always on the right down stroke. Needless to say, I need to give the timing another go. This time, I am going to start with the Consew instructions and, now that you have explained the parts better than the manual. If that doesn't work, I will just go back to doing 'my thing' which seemed to work with my Consew 99 as well as the Pfaff 138. On a bright note, I did discover that the needle bar does have timing marks located on the shaft and those do seem to be accurate, as does the needle bar height itself. I was also able to better 'mesh' the feed dog and the outer presser foot.. One last question (for now): I find that it takes a lot more umph to turn the balance wheel on this Consew 146 than it does on any of my other non-walking foot sewing machines. Is this just a function of it being a walking foot sewing machine, or am I missing something? My 146 is in pristine condition and I have even gone through and oiled every single thing that is supposed to be oiled and I have checked to make sure all the gears are greased as required. This thing has been beautifully maintained. I just can't get the dang hook-needle timing done correctly. ARRRRRGGGGGGGGHHHHH! Thanks again for the help. Best regards, Chelan Quote
Members nylonRigging Posted August 29, 2021 Members Report Posted August 29, 2021 (edited) 1 hour ago, Chelan said: One last question (for now): I find that it takes a lot more umph to turn the balance wheel on this Consew 146 than it does on any of my other non-walking foot sewing machines. hey noticed that you up North of me . Did you pick that Consew up off craiglist ? , I noticed a couple of RB146's on there for sale few months back and one was cleam machine and a good pricing . II was even mulling over doing the long drive up and back I-5 to buy it . --- With you drive belt off the hand wheel . And with the Presser Foot in UP position off the dogs . Your machine should spin pretty free by hand . 1st look, easy pretty Common ---> Is the Needle Plate binding/rubbing against the feed dogs, when you rotate by hand ?? . after screwing down the needle plate look and see and 'feel' with turning machine over by hand that the Dog not being the friction spot . If you have removed the dogs and needle plate to service . When replace them back with leaving your 2 Dog screws not tight . then when screwing the plate down, you can align the feed dog for clearance . The 2 screw heads on Dog, easy seen and just tighten down . . Edited August 29, 2021 by nylonRigging Quote
Members chrisash Posted August 30, 2021 Members Report Posted August 30, 2021 Have you tried a larger needle for #92 thread like size 19 or 20, size 19 is the recommended size size 18 is a bit small Quote Mi omputer is ot ood at speeling , it's not me
Members Chelan Posted August 31, 2021 Author Members Report Posted August 31, 2021 Nylon Rigging: Yes, I am the one who picked up the Craigslisted 146 about a month ago. It was just a stroke of luck that, on a whim, I looked on Craigslist for the 146 knowing that I couldn't afford a new one (nor could I justify it). When I saw this one on Craigslist and looked at the photos, it almost seemed too good to be true. So, I took a chance, drove down to Seattle from Camano Island--during rush hour--and it was, indeed too good, but it was true. It looked like it had hardly ever been used. Bought it on the spot because they said another person was thinking of coming to look at it that next Monday (maybe you?). I will take your suggestions and see if I can get the balance wheel to turn more easily. I know the feed dogs are centered properly on the needle plate and I don't hear anything rubbing anywhere. Thanks again for the suggestions. Chrisash: Thank you for the comments. I have tried timing the hook/needle using needle sizes 18-20, with the same unsuccessful results (so far). I have had good success using the #18 needles with V92 and, as long as I can easily thread the needle, I prefer the smaller size. Even though it is negligible, my mind tells me that punching smaller holes is better than big holes. I do have some size 19 needles, so maybe I will throw that into the mix as well. When I get to the point of sewing really long seams--10 feet and beyond (see attached photo)--or if I am sewing many layers of material at a time, I will sometimes switch to the larger, size 20 needle as it seems to deflect less when I have less control over what I am pushing through the machine. BTW: I usually try to time the hook depending on what size needle I am using. Maybe what I will do the next time I attempt to time the hook is to start off using a size 18 needle. With that setting, I will test again, but insert the #19, then the #20 just to see if I get better results. If the timing gives me better results with the larger size needles, it may indicate what my next adjustment should be....or, if I should just stick with the larger needle and call it a day! Quote
