I managed to buy a Singer class 7 machine last week.
The machine is a 7H501 built in 1905 according to the serial number. The machine is in good condition, being stored in a heated shop for the last 20 years or so.
I have cleaned all the bearing points and the sliding surfaces and given it a good oiling. It runs very smooth and I have made it sew, but the upper thread pulls too hard on the lower thread , and I am not sure that I have threaded it correctly.
Does anyone have a manual or a similar machine that they can take a picture of so I can see the routing of the upper thread through the tension devices?
Thanks in advance
@Mulesaw Please post pictures of your machine from front, back and face plate side.
Edited by Constabulary
@Constabulary
Sorry, I forgot to post some pictures in the heat of the battle :-)
I was frustrated that I couldn't figure it out. The machine seems to be a bit older than the 7-33 that I was able to find a threading instruction for.
There is a regular tension device with two discs at the upper part of the machine, at the bottom of the end there is something that looks like a tension device, but it is just a pulley that is held in place by the spring. The hairpin spring is what puzzles me, I am not quite sure when the thread should go through that one.
I messed around a bit and made it sew, but it jumped off the lower pulley after sewing for a bit (It did make a nice stitch with even tension on the upper and lower thread)
I also tried another routing of the thread, and that gave a lot of tension on the upper thread compared to the lower thread.
I suppose that I could also tighten the lower thread, but I figured that it was best to make sure that I had the other things correct before starting with that.
Brgds Jonas
This comes from an Adler 20 manul but the machine is very similar. Hope this picture is helpful:
@Constabulary Thanks a lot. This is perfect.
I can see now that all my previous attempts were wrong :-)
Best regards
Jonas
  • 1 year later...
hello, i am planing to buy a class7h501, can you tell me the difference between this machine and a 7-33 please?
Edited by pierre2171
Best regards
Jonas
On the second tension unit marked #23 wrap the thread around it 1 & 1/2 times.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Main differences are the 7-33 has a larger bobbin & 2 feet that walk,this model has a single jump foot & they thread different.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Bob thanks, do you think it can be used to sew leather wallets or stuff like this even if it was for sails making...? its what i red somewhere.
jump foot is easy to handle to sew, or what?  i wanted a class 7 and i rather pay a 7h501 600e than a 7-33 at 2k.
The thinnest leather this will handle is 10 oz or 4mm using size#138 thread,it should sew up to 1/2",32oz or 13mm
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
