Members eddo Posted September 3, 2021 Members Report Posted September 3, 2021 I've dismantled and repainted a singer 29U171 (the earlier Japanese made singer, not the 'A' subclass). When I've put it back together, the needle plunge and walking foot are completely out of sync - i.e. the foot is trying to walk the material when the needle is at full plunge). I'm struggling to find out why. I've not internally touched the head components as all was fine and tight, and on reassembly I've put the main drive pulley on as removed.The main drive pulley seems the logical place where the problem can be fixed- i.e the relationship between the drive shaft and the needle bar driving lever has been compromised by the pulley position on the shaft. I am unsure about the rear side elements of the head (i.e. how they work exactly- any help there appreciated) but pretty sure they are installed OK, and the only other thing taken off there to paint was a single screw (locking screw?) at the base of the foot pressure spring. Please see attached images. Yes... colour is a tad over the top... paint supply/ location issue! Quote
Members Constabulary Posted September 4, 2021 Members Report Posted September 4, 2021 (edited) I assume you have the manual for this machine and have followed the timing instructions, right? If yes and it did not help then most likely you have installed the cam / pulley it in the wrong position. I´d remove it, rotate it by 180° and reinstall it. But I cannot judge what you did so I only can guess. Edited September 4, 2021 by Constabulary Quote
Members eddo Posted September 4, 2021 Author Members Report Posted September 4, 2021 Thanks.. Yes I think I Answered my own question as I wrote.. I rotated the main pulley 180 and the problem was immediately solved... Foot and needle in sync and sewing beautifully.. And what a pleasurable sound. Thanks for responding. Quote
Members mooies Posted February 22 Members Report Posted February 22 hello, I have a black vintage singer that's out of sync and I've no idea how to sort it as I don't even have a manual. any help? Quote
Northmount Posted February 23 Report Posted February 23 23 hours ago, mooies said: hello, I have a black vintage singer that's out of sync and I've no idea how to sort it as I don't even have a manual. any help? What is the model number of the machine? A picture or 2 could also help members identify your machine and be able to provide you some help. Lots of old black singers around. Not all the same model. Quote
Members DavidMM Posted 18 hours ago Members Report Posted 18 hours ago Hi I have just purchased a 29u171, and need a manual, and also if possible where I can find some info on on the machine. The serial no is UY80401014 Many thanks David Quote
CowboyBob Posted 18 hours ago Report Posted 18 hours ago 20 minutes ago, DavidMM said: Hi I have just purchased a 29u171, and need a manual, and also if possible where I can find some info on on the machine. The serial no is UY80401014 Many thanks David Singer 29K71 72 73 Manual hi res.pdf Quote
