Members chrisash Posted September 25, 2021 Members Report Posted September 25, 2021 Often wondered about how much strength is required to break a row of say 69 thread, as I assume the strength would not be just one stitch but spread over a few stitches each to a lesser amount. So whilst 69 bonded nylon has a breaking strain in the region of 11 pounds, what force would it take to break say a one inch length of stitches (ignoring the material and tensions etc) Quote Mi omputer is ot ood at speeling , it's not me
kgg Posted September 25, 2021 Report Posted September 25, 2021 3 hours ago, chrisash said: So whilst 69 bonded nylon has a breaking strain in the region of 11 pounds, what force would it take to break say a one inch length of stitches (ignoring the material and tensions etc) From the information I have see I think it would be be based on the number of stitches per inch. The formula would be the number of stitches per inch X the breaking strength of the thread X the thread loop factor: Example would be: stitches per inch: 5 V69 breaking strength equal: 11 lb thread loop factor for 301 stitch (lockstitch) type: 1.5 and thread loop factor for 401 (chainstitch) type: 1.7 Lockstitch Seam strength = 5 X 11 x 1.5 = 82.5 lbs. Chainstitch Seam strength = 5 X 11 x 1.7 = 93.5 lbs. The reason a chainstitch seam has more strength for the same thread size with the same seam length but there will be about twice the amount of thread used. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Gunnarsson Posted September 25, 2021 Members Report Posted September 25, 2021 This agrees with kgg, if I remember the content right. https://www.sailrite.com/How-to-Sew-Webbing-Loops Quote
Members chrisash Posted September 25, 2021 Author Members Report Posted September 25, 2021 So 8 stitch per inch would have a staggering 132 lbs = 60 kilo, boy does that put things into perspective Does it still apply if the pressure is at one end of the row, which would maybe be the normal pressure point on many items Toledo gives the 11lb breaking strain for bonded 69, what sort of variance do you think there is for other makes of bonded 69 Quote Mi omputer is ot ood at speeling , it's not me
Moderator Wizcrafts Posted September 25, 2021 Moderator Report Posted September 25, 2021 9 minutes ago, chrisash said: Toledo gives the 11lb breaking strain for bonded 69, what sort of variance do you think there is for other makes of bonded 69 It varies more with other base materials. Bonded polyester has a lower breaking strength and Nomex is almost half as strong. I do a lot of sewing with Nomex and nylon, but only a little with polyester. I find it much easier to cut through Nomex, or cotton/linen, than nylon or polyester. When I do have to cut something off, I go inline with a seam ripper (up to b92). The strongest seams I have sewn were on an old Singer 28 stitch bar tacker, using b69 thread. The entire item would dissolve before those sewn items would come off! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted September 25, 2021 Report Posted September 25, 2021 1 hour ago, chrisash said: Toledo gives the 11lb breaking strain for bonded 69, what sort of variance do you think there is for other makes of bonded 69 I would say that all the brand name threads are probably within a certain tolerance of one another. The cheaper quality no name brands who knows. 56 minutes ago, Wizcrafts said: The strongest seams I have sewn were on an old Singer 28 stitch bar tacker, using b69 thread. The entire item would dissolve before those sewn items would come off! The strength would probably be in the far north of a 1000 pounds. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members bj139 Posted September 26, 2021 Members Report Posted September 26, 2021 Kevlar has twice the thread strength of nylon or polyester for an equivalent size. I used V92 Kevlar to sew my tree saddle since I didn't want to fall out of a tree. With all the stitches in it I calculated the main seam would break at around 13,000 pounds. Cutting it with scissors is surprisingly difficult. Now I know why it is used in bulletproof vests. Quote
