Members BenjaminKortz Posted November 13, 2021 Members Report Posted November 13, 2021 How does one get the effect of dyed leather, where the tooled area (the stamped impressions) remain natural leather color? Ex: Quote
Contributing Member fredk Posted November 13, 2021 Contributing Member Report Posted November 13, 2021 Generally you use a 'resist' on the bits you don't want dyed Use Resolene or 'Mop & Glo' varnish. Other on here have their favourites. Run the resist into the area, flood it mostly, using a fine paint brush, several coats are best. Then after its dry dye, but apply the dye lightly around your lighter area Quote Al speling misteaks aer all mi own werk..
Members YinTx Posted November 13, 2021 Members Report Posted November 13, 2021 @fredk's method is one way, another is block dying. The example you show appears to be done with block dye method. Do a search on this site for a better description of the process than I will be able to provide! YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members RiverCity Posted November 20, 2021 Members Report Posted November 20, 2021 Block dying is the correct answer, but you dont need a block. I use a piece of tshirt (I buy tshirt rags by the box/lbs) folded over a few times, and go very lightly from there. The main trick is, you need to get most of the dye off the cotton before you touch leather. So have another piece of cloth there to blot off excess dye. Another tip is to make sure your impressions are clear and deep. Another tip on the stamping. Wet the leather and then stamp. Do not case the leather, do not wait for it to lighten in color. Stamp when it is too wet. The reason for this is to avoid the stamp burnishing the impression as best as possible. It will stay pretty much the color of the hide. Here you can see the difference in appearance on a light brown (the burnish from the stamping is close in color), black, and a medium brown. Hope this helps. Quote
Contributing Member Samalan Posted November 20, 2021 Contributing Member Report Posted November 20, 2021 wow very cool Quote
Members BenjaminKortz Posted December 23, 2021 Author Members Report Posted December 23, 2021 On 11/19/2021 at 11:21 PM, RiverCity said: Block dying is the correct answer, but you dont need a block. I use a piece of tshirt (I buy tshirt rags by the box/lbs) folded over a few times, and go very lightly from there. The main trick is, you need to get most of the dye off the cotton before you touch leather. So have another piece of cloth there to blot off excess dye. Another tip is to make sure your impressions are clear and deep. Another tip on the stamping. Wet the leather and then stamp. Do not case the leather, do not wait for it to lighten in color. Stamp when it is too wet. The reason for this is to avoid the stamp burnishing the impression as best as possible. It will stay pretty much the color of the hide. Here you can see the difference in appearance on a light brown (the burnish from the stamping is close in color), black, and a medium brown. Hope this helps. What exactly is the hardware you've used to tack the lid to the wood block? Those small button head nails... are they upholstery tacks? Quote
Members RiverCity Posted December 23, 2021 Members Report Posted December 23, 2021 30 minutes ago, BenjaminKortz said: What exactly is the hardware you've used to tack the lid to the wood block? Those small button head nails... are they upholstery tacks? Brass escutcheon pins 3/4" Quote
Members Bruce H Posted December 24, 2021 Members Report Posted December 24, 2021 Very Kool!!!! Cue Case = On my bucket list Definitely going to have to try some block dying Quote
