toxo Posted December 7, 2021 Report Posted December 7, 2021 Does anyone make snaps with a domed bottom for when the underside is seen? Quote
Members mike02130 Posted December 7, 2021 Members Report Posted December 7, 2021 I have a small snap anvil that is convex which will dome the backside. I bought it at Tandy years ago. Left domed right flat. Quote @mike02130 Instagram
Members Constabulary Posted December 7, 2021 Members Report Posted December 7, 2021 (edited) Maybe use use the cap part as bottom stud. Know what I mean? Other than that DOT makes this cap: https://www.dotfasteners.com/durabletm-caps-2267.html Edited December 7, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
toxo Posted December 7, 2021 Author Report Posted December 7, 2021 Thanks guys but my bases are not as nice as those Mike and I've just realised that I don't have the caps for the nickel ones. Just ordered some smaller ones and the missing caps. Was just trying to avoid using Sam Brown studs but for this project the studs will be the way to go. Quote
Contributing Member fredk Posted December 7, 2021 Contributing Member Report Posted December 7, 2021 I've never found any of what you want. What I've done is to super-glue the cap part of a ready-rivet on to the popper back plate. The short stem of the rivet cap fits well into the hole on the popper base Quote Al speling misteaks aer all mi own werk..
toxo Posted December 7, 2021 Author Report Posted December 7, 2021 (edited) On 12/7/2021 at 10:41 PM, fredk said: I've never found any of what you want. What I've done is to super-glue the cap part of a ready-rivet on to the popper back plate. The short stem of the rivet cap fits well into the hole on the popper base Expand I did think of something like that Fred , How did they hold up? I'll see what the smaller snaps look like when they arrive. Don't like Sam Browns much but my clicker die punches out the hole with the slit. Edited December 7, 2021 by toxo Quote
Contributing Member fredk Posted December 8, 2021 Contributing Member Report Posted December 8, 2021 On 12/7/2021 at 11:46 PM, toxo said: . . . How did they hold up? Expand They've held up very well indeed. If you fit the rivet cap down tight there is no stress on the glued joint. Even if you try to get the rivet cap off you need to wreck the popper. btw, I used super-glue gel which fills gaps better On this shield guige strap the poppers are on the tan part. I hid the base with rivet heads. I did this on all the shields I made and nary a one ever came off even though those shields were used in 'battle' Quote Al speling misteaks aer all mi own werk..
Contributing Member fredk Posted December 8, 2021 Contributing Member Report Posted December 8, 2021 On 12/7/2021 at 1:46 PM, toxo said: Does anyone make snaps with a domed bottom for when the underside is seen? Expand Just quoting to get your attention; How many, what size and what colour of snap / popper do you need? If its only a couple or few, I may be able to sort out some from my stock, with rivet caps to match and send them to you. FOC Quote Al speling misteaks aer all mi own werk..
toxo Posted December 8, 2021 Author Report Posted December 8, 2021 On 12/8/2021 at 2:06 AM, fredk said: Just quoting to get your attention; How many, what size and what colour of snap / popper do you need? If its only a couple or few, I may be able to sort out some from my stock, with rivet caps to match and send them to you. FOC Expand Thank you Fred for the offer but I have some on way from Batchelors in London. It's people like you that keeps me monitoring this forum. Quote
toxo Posted December 8, 2021 Author Report Posted December 8, 2021 Batchelors came through. The snaps are a smaller size and to get a cap in the bottom is very tight. I'll have to use a copper rivet type punch with the hole in it over the post to get it in. If it goes I don't think I'll be needing glue. Quote
