Members Davm Posted January 26, 2022 Members Report Posted January 26, 2022 Okay, I know you are supposed to use a fine tipped brush to dye background areas but the dye can drip and destroy the work. In tight corners, etc.- have any of you used a brown felt tipped pen? Any help for such areas- keep the dye from getting where you don't want it. Quote
CFM chuck123wapati Posted January 26, 2022 CFM Report Posted January 26, 2022 26 minutes ago, Davm said: Okay, I know you are supposed to use a fine tipped brush to dye background areas but the dye can drip and destroy the work. In tight corners, etc.- have any of you used a brown felt tipped pen? Any help for such areas- keep the dye from getting where you don't want it. use a resist on anything you dont want dyed first. i use a small brush wipe the excess off so it doesn't drip. Some folks do use the fillable markers Quote
Members DJole Posted January 26, 2022 Members Report Posted January 26, 2022 I mostly use black markers for those hard to reach corners, and I have some colored alcohol markers for edges. I could use a brush, or a resist, but a fine-tipped marker just makes the whole process easier. Quote
Contributing Member LatigoAmigo Posted January 27, 2022 Contributing Member Report Posted January 27, 2022 12 hours ago, Davm said: have any of you used a brown felt tipped pen? Sure. Here is a marker that you can fill with your own dye to match your work, for less than $4.00. https://www.amazon.com/gp/product/B005KJJ8FO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Quote
Members Davm Posted January 27, 2022 Author Members Report Posted January 27, 2022 Thanks, still learning and appreciate the help. Quote
