LomaeArts Report post Posted January 27, 2022 (edited) A singer 31k20 popped up locally with the advert saying "the needle wouldn't pick up the bobbin thread". Upon inspection, the mechanism was smooth, the bobbin shuttle a little rusty and the needle in the machine was a really fine domestic D shank. I determined it was worth the super low asking price, so it is now in my garage. The machine came with many domestic spares including what looks like a fancy foot to convert a straight stitcher to a ZikZag Most of these will go to a friend that does domestic machines. first task is to source correct needles and replace the dreaded rubber main wire flex. Cheers Matthew Edited January 27, 2022 by LomaeArts spelling Quote Share this post Link to post Share on other sites
Handstitched Report post Posted January 27, 2022 That would make a nice restoration project. Love the foot pedal, " Made in Australia" HS Quote Share this post Link to post Share on other sites
Wizcrafts Report post Posted January 27, 2022 It takes System DBx1 needles. Quote Share this post Link to post Share on other sites
LomaeArts Report post Posted January 28, 2022 Well I'm impressed with the machine. After running a bit, oil ozzed out from the head and made a suitable mess. But I found when running at full speed ( yes, I rewired the motor and switch to make somewhat compliant) I found the machine would stall. Initially I thought the needle plate was binding on the feed dogs, but us became clear the bobbin case was not as free as it should be. A good rubbing with scotch bright, removed a reasonable amount of surface rust and grime Now it runs freely again. New replacement bobbin cases #20756 are on order as is new feed dogs and needle plate. When I place some material under the lowered presser foot, the material feeds through nicely. I am still waiting for needle to be delivered. That is when I try it out properly. So far this machine has cost me $AU 90. I am happy the purchase. Quote Share this post Link to post Share on other sites
DrmCa Report post Posted January 28, 2022 5 hours ago, LomaeArts said: $AU 90 That's 8x cane toad skins, which sets you back 8 wallets. Quote Share this post Link to post Share on other sites
LomaeArts Report post Posted March 28, 2022 Finally got some parts in. The shuttle body #20757 would appear to be impossible to source. One I sourced from a local supplier sent #12393. I have since ordered a new Hook # 12444 and a complete Shuttle Race #24415. ( all these fit on a 31k15) When I attempted to remove the original drive hook I noticed two bumps on it as if there was a pin going through the hook and shaft. a picture is attached. the parts manual show holes in the approx. position. Before I start whacking and thought it would be better to ask "Would this be a pin I need to tap out? " Thanx. Matthew Quote Share this post Link to post Share on other sites
