Homemade Modified Arbor Press For Border Stamping. Video Link.
Hi. Several years ago when I first started working with leather I modified an inexpensive arbor press to become both a border stamping machine and a drill press for a hand grinder style tool. The adjustable fence works very well, and the accessory table removes quickly to let the circular press table be used as the press was made for. I also made a return spring for the spur gear stud by using a leather strap, a tension spring and a small head bolt drilled and tapped into the spur gear stud. The fence is a strap of scrap stainless steel, the base and other wood parts are scrap oak. A cutting board section was mad into the new table surface.
Hope the link works. Just now learning to upload to Youtube. Thanks for looking. Don
Edited by Tallbald
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
That's pretty handy. Thanks for posting. I am sure my one ton arbor press is too big but been wanting a small one.
Thank you. I hope that my design will help some other leather crafters here who might have disabilities like mine. I built it because I have a spinal injury, can only set for rather short times, and also have prsoriatic arthritis in my joints. Hammering a border stamping is very difficult because of the needed movements. My hands also go numb after a few inches of decorating. This modification have been wonderful for me, allowing me to stamp an entire line in one setting. It is, I seem to recall, a one ton press from Harbor Freight. Don.
I like your set up. The one question I have is on the fence why do you have your contact point against the fence so small? Don't you have an issue of keeping your work square? I bought my arbor press for mainly setting snaps, do you do use yours for snaps also? I'm trying to improve my setup for snaps.
If I were to guess, it'd be to make it easier to put a border around and inside curve. I noticed when he was doing the demo on that bit of scrap that he had no issues transitioning along that odd compound curve. I don't think a flat fence would work for such a task.
It'd probably be easy enough to make a flat faced guide to do up a continuous straight edge, like a belt. He might even have one that just got camera shy, too.
Truthfully I "eyeball" the perpendicular to the fence. If a customer desires a "perfect" line they need to buy from an import CNC embossing setup. I point this out. My arbor press is an adjunct to hand stamping. This may not be for everyone, but as a physically challenged (hate to be PC) fela it has worked well and I hope it helps another crafter.Don.
Edited by Tallbald
I have been thinking about making a similar setup for a while so I could border stamp at night without a noise issue. Thanks for the post.
Very nice!
Thank you all. My press is indeed nice and quiet in the evening when I work after Miss Penny must rest. it easier too on my arthritic hands and arms. And I can set snaps precisely and quietly. I even made a drill press attachment for it to use my Proxxon rotary tool for drilling small holes for hand stitching before I bought Bertha Jo, my Cowboy 3500 sewing machine. Don.
