pengkegu
Everything posted by pengkegu
  1. I think this thickness is too difficult for the 563. You’ll need a 244 or 246 to handle it.
  2. I don't know what tool you use to apply edge paint. I'm used to using an awl. My method is: after covering it with paint, I hold the awl at a 45-degree angle downward and scrape the edge paint onto the leather.
  3. thank you for you sharing
  4. I would like to ask politely, how much does the tote bag cost?
  5. I just wanted to say that your work is incredibly beautiful and elegant. It’s clear that your skill level is very high—especially your leather carving, which is truly impressive. I’ve recently started learning how to make ring binders too, and from my experience, it’s best to make the inner leather about 2 cm shorter than the outer layer so that the fold looks neater. Also, it’s better not to use materials that are too stiff for the lining—leather fiber works best, otherwise it can look wrinkled.
  6. Amazing! nice job!!
  7. very nice!
  8. pengkegu
    notebook
    Notebook made for a friend, hope he likes it
  9. 你好。通常我不会使用加热方法来平滑边缘涂料。首先,我使用此工具涂抹一层,然后涂抹与颜色匹配的边缘涂料。
  10. Recently, I received a shoulder bag from a customer, and the hardware had fallen off, so they asked me to repair it for them. The customer requested that the repair be seamless, so I first removed the edge paint from the bag and then took out the stitching, but I didn’t cut it because I would need to sew it back later. After removing the edge paint, I could see that the screws inside had come loose, so I tightened them and applied some screw glue to prevent them from falling off again. The following steps are to reattach, paint the edges, and restitch.
  11. You’ll find that cleaning is quite troublesome.unless your production volume is large
  12. I think you could try adding some yellow, preferably lemon yellow
  13. I think you need to remove the stitches above the rivet, but not too many—about 5 stitches should be enough. Try to remove the rivet with a tool without causing damage. Make a piece of leather in the same shape and sew it on. I believe using a French round pricking iron with a spacing of around 3.85 mm should achieve the same effect as the original. The difficulty lies in finding leather of the same color, which is challenging because your bag has oxidized. Additionally, the edge paint will also need repair.”
