Wizcrafts
Moderator
  1. I have been able to find some new parts, but no old stock, or used parts. Someone must have extra parts for a Union Lockstitch machine that they can spare. I would like to buy the following items: #1, #1.5 and #3.5 needles #4 and #4.5 or #5 awls Any pressor feet for the ULS, including standard and the adjustable stepper feet and brackets Raised throat plates for holsters and stirrups, with and without slot for edge guide Short-ended throat plate to sew cases close to the post, upside down. Fixed face edge guide and hardware Bobbins T-wrenches, any size Thread guides Loopers Main take-up spring Main pressure spring and post for top of machine Take-up mechanism parts Pressor foot lift parts Various 4-sided drive screws Bobbin winder assembly Bobbin cover plate Bobbin compartment cover Misc gears 5 and 6 cord, left twist, glazed linen thread Super Cyroxiline (spelling?) clear stitching wax #346 and larger bonded polyester thread, in black, white, brown and natural.
  2. Wizcrafts
    Wiz's Leather Stamping Tools
    These photos are of my various hand stamping and carving tools.
  3. From the album: Wiz's Leather Stamping Tools
    These are all of my stamping and carving tools, as of January 27, 2010. They are mostly by Craftool, with a few Midas tools I bought online.
  4. From the album: Wiz's Leather Stamping Tools
  5. From the album: Wiz's Leather Stamping Tools
  6. From the album: Wiz's Leather Stamping Tools
  7. Photos of my hand stamping and carving
  8. From the album: Wiz's Hand Stamped and Carved Projects
    This is one of the name belts I made, with opposing eagles and a geometric stamped design. The project was antiqued with Fiebing's Hi-Liter, sealed with acrylic base sealer and pulled through a carnuba wax rag to slick the edges.
  9. From the album: Wiz's Sewing Machines
    Despite worn out parts and its age, my Union Lockstitch machine is still capable of sewing 3/4" of belt leather with #277 thread, top and bottom. Once I replace the needle bar with a new old one and get the proper needle set screw, and obtain #3 needles and #4 awls, I expect to be sewing with #346 bonded nylon thread through the same thickness.
  10. From the album: Wiz's Sewing Machines
    This photo shows the take-up mechanism on my Union Lockstitch machine. There is suppoed to be a little lever attached where the flat spring is. That lever is used to release extra thread when skipping dees and buckles. I need that lever and its mounting washers!
  11. From the album: Wiz's Sewing Machines
    This photo shows the worn parts in the needle and pressor foot area. They need replacing. The needlebar screw was removed and replaced with a hex drive screw that is stripped inside. The pressor foot was welded together and does not make good contact with flat work. It also fails to reach the throat plate.
  12. From the album: Wiz's Sewing Machines
    The T-handle on the top of the machine can be turned so that the needle bar engages it on the upstroke and causes the foot to lift when the needle lifts. This allows you to move the work to any position where you want it, then continue to sew. It also allows you to manually stitch any desired stitch length, by hand, rather than pressor foot adjustment.
  13. From the album: Wiz's Sewing Machines
    This is my Singer 29K172, long arm patcher, complete with the cast iron base and treadle drive. It features a darning mechanism that lifts the pressor foot off the material as the needle comes up. Coupled with the front tension disks, one can do free hand darning on boots with this machine.
  14. From the album: Wiz's Sewing Machines
    This is my heavy duty, industrial, National brand, triple feed walking foot sewing machine. It uses large M size bobbins, series 135x16 or 135x17 industrial needles and can sew over 3/8" of belt leather, using #207 thread on top in the bobbin. I have swapped out the original clutch motor for a SewPro 500 GR servo motor. Nothing stops this machine from penetrating the material!
  15. From the album: Wiz's Sewing Machines
    This is the Union Lockstitch (ULS) machine I acquired in a trade for an Adler 204 flatbed machine, in early January, 2010.
  16. That is my dream machine. If only I had the money! Maybe someday...
  17. Bob; I'll take a pack of each size. Now, does anybody have awls 1/2 or 1 size larger than these needles? (Sizes 3, 4, 5)
  18. I definetly need replacement pressor feet for my Union Lockstitch machine, including the basic foot that is supposed to ship with the machine. Also, raised throat plates to sew holsters and cases and other plates and guides. Some of the screws need replacing, some nuts are missing, and I can use most sizes of needles and awls. Any replies will be appreciated.
  19. A Singer 29-4 is an old cobblers' machine designed to repair shoes, boots, handbags and jacket zippers. It will sew approximately 1/4" thickness, using 29x3 or 29x4 series needles. Thread capacity is up to size T90 cotton, nylon or polycore. The bobbin is tiny in these machines, which date back to the early 1900's. Patchers do not have feed dogs at all. They move the work via the pressor foot, which has sharp teeth and can be turned 360 degrees. The teeth will leave permanent marks in vegtan or harness leather. The 29 series are known by their common use name: "Patcher" - as in shoe patcher. They are not designed for production, but for footwear repairs. A 29-4 is not going to sew 3 layers of 8 oz leather. If you really push it you might get 5/16" under the foot. Stitch length varies with the thickness of the work and is limited to about 6 to the inch, maximum (rebuilt 29-4's may yield up to 5/inch for a while). If the mechanism driving the foot is badly worn you will probably get less than 7 stitches to the inch, on 1/8" of leather and 8/inch on 1/4". The condition of the inner moving parts depends on how old the machine is and how well it was maintained by all owners who used it. Certain parts are known to wear out and will need to be replaced with new-old stock, or made/beefed up in a metal shop. Bob Kovar, at Toledo Industrial Sewing Machines - 866-362-7397, has replacement parts, needles and bobbins for Singer Patchers.
  20. It turned out that my new-old Union Lockstitch machine came equipped with a custom modified stepping foot, set to about 6 wide, ugly steps to the inch. Does anybody have a flat bottom, standard pressor foot they can spare? I also need a raised throat plate for holsters and cases. Anybody???
  21. You're welcome! Here's a link to just one of the new walking foot machines offered by one of our dealers, Cobra Steve. Bob Kovar, in Toledo, has all kinds of new and used industrial sewing machines, including Cowboy leather stitchers, at very reasonable prices. He has no website, but his phone number is 866-362-7397. He can mail you brochures for Cowboy machines. Other brands represented by members of the leatherworker.net forum include representatives of Artisan, Campbell-Bosworth, Boss and Techsew (and probably more). You won't find a better place to get help online for your leather sewing problems and questions than right here. BTW: here is a picture of my National walking foot machine. It sews just over 3/8" of leather, Naugahyde, or nylon strapping, flawlessly, with up to #207 nylon thread. It uses Consew parts, which are available everywhere industrial sewing parts are sold.
  22. Pretty much any compound feed, walking foot machine, that can sew up to 3/8" with a #22 needle, will sew dog collars, using #138 bonded nylon thread. You can take your pick from these brands: Consew, Juki, SewPro, Cowboy, Cobra, Neels, Artisan, Singer, National, Adler, Pfaff, Mitsubishi, Seiko, Sailrite, Morse, Rex. You should get a machine with a swing-away edge guide and a reverse mechanism. If you plan on making a lot of collars try to get a large M bobbin machine. A variable speed servo motor is going to be necessary to sew the box stitches at the ends, because they are more controllable at slow speeds than clutch motors. Check with our dealers before you buy elsewhere. Most of them have excellent used machines in stock and unbeatable followup service.
  23. The following parts are from the Union Lockstitch parts list and pictures. Looks like I will need some replacement 4-sided screws, # 5 and # 117, some shuttle screws #253, a few awl set screws #86, and maybe a needlebar and definitely a new needle set screw # 133. Other screws needed are for the brake: 2 #19, with 2 #20 nuts. I'll need a new knockoff stud #12 and these springs: #148, #241, #292. I could use a spare pickup thread point #276, and throat plates #250F, 250N and 250G. Also, small and a large four-sided wrenches in good condition. I can use needle sizes 2, 3 and 4 and awl sizes 2, 3, 3 1/2, 4 and 5. Any leatherpoint awls would be a treat! I'll post more requests as I find more worn out parts. BTW: my machine serial number is 42xx. Does that indicate that it was built in 1942, or that it was the 42xxth machine built? Thanks in advance. I hope someone has spare ULS parts they can let go of. PM me if you have parts to sell!
  24. Thanks to Andrew Wood, I now have a manual for a Union Lockstitch machine. I only need everything else in my previous post!
  25. A trade for a ULS machine has been arranged. See my post looking for spare parts, needles, awls, bobbins, springs, etc, in the Leather Sewing Machines section of the forum.
