Do you have a user's manual and/or parts list. Have you watched it in slow motion while hand-wheeling it? Loosen the needles and reset them all the way up into their mounting brackets. If that doesn't fix it, one of the loopers may be bent, or pulled out of alignment. Also, make sure that it's threaded correctly and all the tensioners are set right. Sometimes, it helps to rethread these a-hole machines to get things working again. For me, it's a love/hate thing with sergers.
What material, thickness and diameter is the piping? Are you using a properly matched piping foot set? If it's thin leather, try rubbing Carnauba Creme on the area that's going to make the sharp turn before it gets to the feet. Or, apply it to the entire length in advance. Carnauba Creme softens and preserves leather and can be polished with a piece of wool fur. The added flexibility may help get rid of the corner wrinkles. If the wrinkles persist, try skiving it down a little thinner. If it's cloth or vinyl, check on upholstery forums, like https://www.theupholsteryforum.com/.
I have the 211g156 with reverse. The 211s are tough machines, but have small pulleys for high speed sewing of upholstery, boat/truck covers, tarps, tents and banners. My machine is at my shop. I'll take a look under the oil filler cover tomorrow and report back. I squeeze oil into every hole that isn't tapped for screw. You'll need the proper oil pan. You can probably get one from Toledo Industrial sewing Machines, who are advertisers here.
@keenbean To add to my previous comments, even if you are able to source thinner needles in system 7x3 - for a Juki 441 class machine - know that they are very long and easily deflected. With a lot of layers taped, glued, or stapled together there's a good likelihood that some deflection will occur. You can reduce the deflection by limiting the smallest needle to a size 20. This will poke a slightly wider than usual hole for #92 bonded thread, but it's still much smaller than a #23 needle. Since the 7x3 is a round point, the ends will still be on the surface, as opposed to leather point system 794 S point that submerges the ends. If you can live with a thread range of #92 through 207, a Cowboy CB3200 will handle everything you can throw at it. It sews 1/2 inch, but the feet lift 5/8 inch. I have seen folders on the Cowboy/Hightex website, which would be a special order. You can ask Bob Kovar, the owner of Toledo Industrial Sewing Machines, about folders and other attachments for that model. If anybody could fit one onto that machine, it's Bob. Addendum: I wrote a blog article about dumbing down a Cowboy CB4500 or similar class 441 machine for use with thin needles and thread. You might find it useful if you want to consider a CB3200, 4500, or similar machine. Note, most of the machines you're looking at are manually oiled. It's no big deal. It's a routine you develop.
@keenbean First, take a look at this thread and needle chart. It shows the diameters of various sizes of thread and needles and tells you which needle to use with a particular thread size. You really need to define a range of thread sizes, then find machines that can use the range of needles that are best matched to the thread. But, keep in mind that lockstitch machines for overlapping knots that must be pulled up inside the material without seeing them on the top or bottom. The thicker the thread, the harder it may be to conceal those knots. Different classes of sewing machines are able to handle different ranges of needles and thread. Most upholstery grade machines are meant to handle a range of thread from #69 through #138, with a corresponding needle range of #18 through #23. Extra heavy duty machines may extend the thread range to #207, which calls for a #24 needle. From your description of the range of materials and thicknesses involved, you will be on the borderline of heavy duty and super heavy duty. The Juki 1341 and its clones may or may not live up to your expectations. You want a 5/8" clearance under the foot (15mm). The only way you can get that amount of lift on a walking foot machines is if it is built to lift at least that high without the tip of the needle sticking out of the inside foot. The 1341 and its clones are probably not built with that extreme amount if foot and needle lift in mind. Ironically, the Juki LU-1508NH flatbed machine is built to lift that high, including the tip of the needle. It accomplishes this by using a longer needle system with a longer stroke. The 1341 and clones are made to use system 135x16 and 17 needles, with are standard length for upholstery grade machines. At their maximum rated lift, the needle bar just barely clears the lifted feet and the needle's tip is just inside the bottom of the inside foot. You'd have to ask a dealer, or somebody who has tried it to know if these machines can accept the longer system 190 needles that would be needed for a higher than standard foot lift. While the upholstery grade machines run out of lift around 1/2 inch, and are limited to a maximum thread size of #138, the 441 class machines are happy with thicknesses up to at least 3/4", with some able to sew 7/8 inch. However, these machines are built for super heavy duty sewing with large thread sizes and correspondingly large needles. As such, it is difficult to find any leather point needles under a #23, and even harder to find round points under size 22. These needles are perfect for #138 thread, top and bottom, but are way too big for thinner thread. Further, these machines have very large oval holes in the feed dog to clear needles up to a #26 or 27. Thin material can get pushed down inside the hole. To solve that problem, at least two people are producing narrow feed dogs and throat plates for the 441 class machines. So, you'll have to choose between modding a lesser machine to use a longer needle, then figure out how to increase the foot lift, or dumb down a more powerful machines to use thinner needles (if you can find any) with thinner thread.
I moved your post to the Marketplace section, under used sewing machines. Here is a good tutorial about adding photos to your post.
Can a worn case/hook prevent adjustment of case opener lever.
Wizcrafts replied to beefy's topic in Leather Sewing Machines
If there really are washers under the hook, removing them will advance the hook timing. -
Either the latch opener arm is bent down too far or the hook is sitting too high up. -
Buying A 227R What I Have To Check The Most?
Wizcrafts replied to BodegaBrasil's topic in Leather Sewing Machines
They're a brick and mortar business that's been in the same location for 28 years now. They have more parts than you can shake a stick at! Plus, it's a family run business. -
What sewing machine should I purchase?
Wizcrafts replied to J Kellar's topic in Leather Sewing Machines
Perhaps if you increase the search area to a wider radius you might see some desirable sewing machines on Marketplace. I found a lot more at 100 miles, and even more when I expanded to 200 miles radius. -
@J Kellar There is another class of heavy duty sewing machine that can handle thick and dense leather, large thread and big needles. I refer to these machines as the 45 Class because they are based on the ancient Singer model 45. That machine was available with a fixed flat foot and with a flip up roller foot and had bottom feed only. I had one for a while when I first got into sewing heavy leather. It could handle #346 bonded thread with a #26 needle The maximum thickness was about 3/8 inch, although it could sew 7/16 in less dense leather. The modern equivalent would be the Cowboy CB2500, shown on this web page. You can read the full description there. It is a less expensive option if you don't expect to sew stacks of leather over 7/16 inch, or if tooth marks on the bottom and foot tracks on the top won't be a problem. Those marks can be pounded or rubbed out to a large extent. The main difference between a 45 class and a 441 class machine is that the 441s have triple feed that can walk up and down different layers without difficulty. The flat or roller foot would need you to lift the foot with the foot or hand lifter to climb up onto new layers. It would certainly handle knife sheathes and pancake holsters that only have two pieces being sewn together. Having had a Singer 45 and now having a Cowboy CB4500 gives me a good reference about the differences between these classes of machine. The only way I'd acquire another 45 machine was if I was going to be sewing tow straps or something else made of heavy webbing. You also asked about the best thread size for securing two layers of 10-11 ounce skirting. You'll definitely want to use #277 on the top and bottom. This calls for a #25 leather point needle and a lot of foot pressure. -
Here is a thread and needle matching chart that I had a hand in creating. Where two sizes of needle are shown, use the smaller size in thin or soft material and the larger in thick or denser material. When it comes to the accuracy of the thread sizes, trust the name brands over no-name spools. Name brands have some degree of quality control. Avoid the cheapest thread (e.g., off-brands on eBay or online Marketplaces). The thread chart includes the strength of each thread size. This is its breaking strength. That can be used to determine the best thread for a particular job. For instance, if you are going to seam a cover that will be pulled tight over an object, or otherwise subjected to stress along the seams, use one size larger that the smallest thread. It might be a little harder to totally hide the knots on the backside, but the stitches may hold up better. I usually use the largest thread that allows me to bury the knots. There will also be different compositions of thread available to you. Choose the type of thread that fits the material. If you're sewing denim, you can buy a type of thread called Denim Thread. It's washable and stable when washed and dried. If you're sewing indoor upholstery, buy bonded nylon. If the job is for outdoor use, like a porch chair, or an awning, outside banner, or a cushion on a boat, use bonded polyester thread that's UV resistant.
Info on machine. Looks older and huge.
Wizcrafts replied to bigsig11010's topic in Leather Sewing Machines
That is an American Straight Needle harness stitcher. The machine is from the early 20th Century and has a needle and awl. They were made to use waxed linen thread. It was made to sew along the edges of harness and saddle straps. If you remove the edge guide, it has a depth of about 4 inches from the needle to the body. Here is a video explaining how to thread it and operate it: https://www.youtube.com/watch?v=vgt0AUp3emU -
Start by using a Schmetz Serv 7 system 135x17 needle. I don't recommend #69 thread for this thick seam job. Move up to either #92 or #138 thread, top and bottom (or maybe 138 top and 92 bottom). If you go with #92 thread, use a #19 needle for a tight stitch, or a #20 needle for a bigger hole and easier knot pull-up. If you go with #138 thread on both sides, use a #23 needle. For 138/92, use a #22 needle. No matter which thread and needle you choose, crank down the presser foot screw to squish the material and get any wrinkles or fluff smoothed out. You might have to lengthen the stroke of the check spring and add some more slack thread via the check spring adjuster. Finally, the timing my be borderline for this thickness and density.It's a good idea to open the bobbin cover plate and watch where the hook is in relation to the top of the needle's eye on the upstroke. Also, look at the loop and make sure it isn't dissolving before the hook can pick it off.. Normally, the point of the hook intersects the needle in the scarf about 1/8 inch above the eye. It should have a big enough loop to easily grab it and carry it around the bobbin and shuttle. Maybe your timing is retarded and advancing it will both resolve the skipped stitches and any snapping sound as the top thread goes around the bobbin case/shuttle.
Is there a sewing machine for me?
Wizcrafts replied to D.jsherwood's topic in Leather Sewing Machines
You'll need a walking foot machine for this job. It could be a portable walking foot machine made by Sailrite. Or, it could be an industrial machine head mounted on a 20x48 inch table with a clutch or servo motor under the table. -
Either the safety clutch has tripped due to a thread jam (most likely), or the driving gears have loosened on the drive shafts.
This translates into English as the following: Good day. I got a machine, since I turned it on, the machine has become very hot and as if it is stopping. The belt is rubbing against the table and I can't see how to adjust the motor. Any advice? What is the make and model of the machine? Can you post a picture? In the picture, show where the belt is rubbing and show a picture of the motor under the table. Please translate your replies into English. Thank you. In Afrikaans Wat is die maak en model van die masjien? Kan jy 'n foto plaas? Wys in die foto waar die band vryf en wys 'n foto van die motor onder die tafel. Neem asseblief klein fotogroottes. Vertaal asseblief u antwoorde in Engels. Dankie.
If I understand you correctly, You are saying that the top thread loop that forms on the right side of the needle is still present as the needle moves up and the shuttle is making its second rotation. If this is the case, I think that you have forgotten to pass the top thread through the hole in the take-up lever! The path is to loop around the three hole pre-tensioner bar, then around the center of the top tension disks, then out the bottom of the disks to the check spring assembly - where you pull up as you wrap the thread around the spring and its channel until it snaps in place. From the check spring, you feed the thread up through a thread guide to the take-up lever. Pass the thread through the eye in the lever from right to left, then down through the remaining guides to the guide ring on the bottom of the needle bar. From there you thread the needle from left to right, making sure that the ribbed side is on the left and the cutout scarf side is on the right. Failure to thread the check spring correctly may also cause this problem as well as cutting the top thread as the needle descends.
CB341 having issues with sewing near edge of leather
Wizcrafts replied to Chapelworx's topic in Leather Sewing Machines
@Chapelworx The weight of the leather at the edge must be the problem. To control any misalignment from the weight over the edge, try increasing the foot pressure via the large threaded pressure adjuster on the top of the head (over the presser foot). If there is also an inner foot adjuster screw, turn it down too. Are you using the stock feet? Does the outer foot have left and right toes, or just a left toe? You might need to use a double toe foot to keep pressure on the right edge to keep the leather from lifting at the inside edge. Are you using the needle and thread that shipped with the machine? What are their sizes? Check the edge of the throat plate to see if it is tapered at the left edge. Finally, using your left hand, slightly raise the left side of the belt a little higher than the right as you sew. Push the belt towards the right as you sew. Can you take a picture of the left nose end of the machine from the front view and post it here? Keep the resolution to the smallest allowed by your phone or camera. If you have the option, use .jpg format as it is usually a smaller file size. -
I have the same machine. It could be that you are trying to run a thread size that is bigger than the machine is rated for. That would be #138 (T135) bonded thread. -
You have correctly summarized the check spring. As for when the spring lets go (the stroke), it should always be after the needle fully penetrates the material. This will be longer on thicker stacks than thinner ones. When this spring first appeared, most people were sewing cloth garments. The problem of running without any check spring is that the top thread loosens as the take-up lever moves down from TDC. All of that loose thread flopping around tends to get caught by the needle and is likely to split if the needle hits it square on. The purpose of a thread controller, as it is officially called, is to keep the thread taut until the needle is inside or under the top of the material so that it doesn't split the loose thread by accident. Since thicknesses do vary, I usually adjust the stroke stopper bracket lower to keep the thread taut a little longer. I set the spring tension to manage the size of the thread, using less force on thin thread and more on thick thread. If you set too much spring tension, it can override the main top tension disks. I use just enough spring action to both fully seat it in the lowered position and to control the amount of slack, but not to add appreciably to the top disks adjustment. The adjustment for the "throw" varies with the design of the check spring assembly. No matter its geometry, there should always be some method of adding or subtracting how much loose thread is fed to the descending needle. The lesser the looseness, the tighter the lay of the stitches, and vice-versa. If you sew something that is thin and soft, like garment leather, denim, broadcloth, linings, etc, and the stitch line is puckering, stop sewing and cut the thread, then pull the work to remove the puckers. Move the slack adjustment to add more top thread, run a test, then resume sewing the job. You will find a happy position where the work lies flat and the stitches aren't too loose on top. The actual spring tension is controlled by rotating the entire check assembly one way or the other. On most of my SInger style machines, there is a locking screw underneather the metal housing that the assemble fits into. That screw stops the assembly from turning on its own. To change the spring's force, loosen that screw on the housing, then put a narrow flat blade screwdriver into the end of the split shaft and turn it to get the amount of spring tension you want. Tighten it down after you're satisfied. Most thread controllers I encounter have the slack adjusment in a curved slot with a small screw that sits inside the slot. You loosen the screw and the nut that tightens the assembly, then rotate to the right for more slack, then tighten it all down. Factory standard is dead center in the slot. However, the distance that the spring travels up and down comes into play if it's much longer or shorter than the default factory position (typically about 8 to 9 o'clock in the resting position). machines setup to sew leather usually have a lower resting position of the stop bracket or adjustment. I recommend experimenting with any new sewing machine until you are familiar with all of its adjustments and how thay interact.
Nice work!
What Machine Do I Need to Sew 12 mm Leather
Wizcrafts replied to OscarRush's topic in Leather Sewing Machines
@OscarRush Sewing those thicknesses of veg-tan leather are beyond the scope of upholstery class walking foot machines. You'll need to buy a machine that's built to sew holsters, saddles and horse harnesses. Most of these machines can sew at least a half inch of hard leather. Some, like the cb3500 and 4500 that AlZilla mentioned, can sew 7/8 inch of saddle skirting. I have the 4500 and a bunch of walking foot machines, so I know what I'm talking about. My walking foot machines can sew up to 3/8 inch of chap or garment leather, using #138 bonded thread. My Cowboy cb4500 can sew from just under 8 ounces, up to 52 ounces thickness with very heavy thread, like #441. I personally never go beyond #346, but I could if I needed to. -
Neither of these machines was built to handle or tension #207/T210 bonded thread. Do so at your own risk. Sewing with #207 thread on the top and bottom calls for a #24 needle. You might need to find a heavy duty beehive tension spring to get enough top tension to pull the knots up into the leather. The bobbin tension would have to be very light, which can lead to other problems. Also, the hook will probably need to be moved farther away from the larger needle and the deflector tab may need to be bent out a little more (or not). Moving the hook sideways changes the timing. If you do manage to get one of these machines to sew properly with #207 thread, which has a 33 pound breaking strength, be prepared to replace the take-up lever and the connecting rods and crank shafts inside the head. These parts will wear out much faster than if the thread maxed out at 22 pound test #138. You might be able to soften the forces acting on the moving parts by reducing the bobbin tension to almost zero, while installing an anti-backlash spring under the bobbin, then balance the knots with the top tensioner. Last, set the check spring position for the maximum amount of slack in the top thread. On disk shaped check assemblies there is a screw inside a curved slot to control the slack. Loosen the little screw, rotate the assembly fully counterclockwise so the screw is at the right end of the slot, then tighten down the screw. Next, you may need to change both the check spring tension and bottom stopper position to hold onto the top thread as the take-up lever descends until the needle completely penetrates the bottom layer, and possibly longer. You'll need to get a substantial loop in the needle's scarf for the hook to pick it off at the distance it will have to be away from that thick needle. The hook timing may also need to be advanced to reduce the snapping as the top thread tries to go around the shuttle.
If you can't tame your digital servo motor, consider replacing it with an analog model that has brushes. The Consew CSM-550 is a perfect replacement. I use this type of servo motor, under different brand names over the years, on all of my walking foot machines, including my huge Cowboy cb4500. Servo motors with brushes like the CSM-550 start at zero rpm, but with very low torque at the minimum speed setting. They gradually increase their starting torque as you turn the speed knob a little higher. Once in motion, you can back off to maintain your preferred speed. Adding a speed reducer can double or triple the torque. Machines with this motor and a speed reducer can start turning over at less than one stitch per second and punch through whatever is under the foot/feet.
