Wizcrafts
Moderator
  1. Full STOP! The needle you listed is a "System" 190 profile, and a number (width of the business end) 22. The System 190 is an extra long needle. It is only recommended for higher than standard lift, mainly on walking foot machines. The reason is that the higher capacity of the foot or feet to lift and function properly would be too high for a shorter needle to clear the top of the lifted foot or feet. A standard walking foot machine might be able to sew up to 3/8 inch of compressible material. If you stuff 1/2 inch under the feet and hack them to lift higher up, the bottom of the needle bar will make hard contact with the raised inner or outer foot and something will give or break. So, some machines are already setup to sew thicker than standard and have their needle bar raised up high enough to clear the feet in their highest working position. Many are made to use the longer System 190 needle in the needle bar. Since the distance is longer from top to the eye, these needles can still go down far enough for a loop to form at the eye of the needle and the hook to pick it off. Note, that these longer needles are more fragile in smaller sizes (diameters) and are more likely to get deflected and break that a shorter needle of the same "size." Get the manual for that machine and compare the full model number to whatever is shown in the manual for the factory needle system. The 22 part relates to a business end outside diameter of 0.718 mm. Due to the rib channel one one side and the cutout around the eye side, the actual diameter changes. No matter its geometry, a #22 needle is the minimum size required to sew with #138 (Tex 135) bonded thread on the top and bottom when you sew into soft to medium temper materials, and soft chap or garment leather. The thread itself has an outside diameter of about .414 mm. When you sew on a standard lockstitch machine, the top thread captures the bobbin thread and folds around it as it draws it up into the material. We refer to this lock configuration as a "knot." The knot is about twice the diameter of the individual top and bottom threads. Veg-tan leather is less pliable than chrome-tan chap and garment leather and its extra density means that you'll probably need a needle one number larger for the same thread sizes. Thus, to get the "knots" pulled well into the leather, you'll need a #23 needle with #138 bonded thread. One parameter that hasn't been mentioned is the top mounting diameter of the part that goes up into the needle bar hole. It must be a good fit; not too loose and definitely not wider than the hole. You should be able to insert and remove a needle with finger pressure alone. It should not wobble when all the way up and tightened down with the needle bar set screw. Many modern era walking foot machines take a 2 mm diameter top needle shank. Some ancient machines only took 1.5 or some random number smaller than 2.0 mm.
  2. Check to make sure that the top thread is staying all the way inside the tension disks. Add some more top tension. Verify that the check disk is properly threaded and that the spring tension is good, the bottom stopper holds the thread taut until the needle pierces the leather, and that the little set screw is either in the center, or to the left in the curved slot. Finally, change needles. UPDATE One way to ensure that the top thread has a fighting chance of staying seated inside the top tension disks is to twist it around a top post counterclockwise, feeding it through a top and bottom hole in the post. You can turn the post with pliers to get a good angle coming out of the bottom disk. This provides back pressure before the disks and helps keep the thread seated down in them. It also tends to counteract twisty thread that may act like a coil spring coming off the spool.
  3. When you do make the jump into sewing machines, if you have any technical or operational questions, head over to our Leather Sewing Machines section of the forums. When you do get to try using his Juki, hold back the starting threads so that the top thread doesn't get pulled into the shuttle and jams the machine. Holding at least to top thread, back and to one side, keeps it from getting drawn down unexpectedly. You can let go after either backtacking, or sewing all the way around and overlapping the first 5 to 10 stitches. Your master should teach you that, but it becomes a subconscious operation that one might fail to pass along.
  4. @Sblof Your Nakajima 280L machine has been discussed on these forums, before. Here, here and here. It is a compound feed walking foot machine. It uses the common System 135x16 and 135x17 needles. It takes all manner of Singer 111 style feet. Most are smooth. It was a forerunner of the current Juki 1541.
  5. Some Puritan machines have been in service for a century, or longer. Parts wear out over decades of use. Finding replacement parts may be difficult. I believe that Redwing repairs their Puritan machines on-site and probably manufacturers all needed replacement parts, or out-sources them to local machine shops. Here are some references and videos of Puritan Machines in action. https://www.youtube.com/watch?v=RMWAPPEucMI https://www.youtube.com/watch?v=DOVaDCN-BEI Here's one (currently) for sale on eBay, in Pennsylvania.
  6. Redwing boots are sewn on Puritan chainstitch machines. Some have 4 or more needles to sew parallel lines at critical seams on the boots. I guess it wouldn't hurt to contact them and ask if they have any Puritans they want to sell off.
  7. I try to keep my minimum sewing speed to about 1 stitch per second, except on intricate turns and patches. I slow down to get the best needle placement, then speed up on straight-aways.
  8. Despite all of the improvements made in electronic motors over the last almost 20 years, I can still feather a clutch motor so it barely turns over the machine, and hold it at a slow and steady speed. Yes, they are noisy and generate a bit of heat. But, they are like the Ever Ready Bunny: they just keep on going! If anybody reads this and is having trouble controlling a clutch motor, try backing off the big screw on the clutch housing. This adds a certain amount of slack movement before the disks engage. You can also tighten the coil spring that holds back the clutch lever. That keeps the lever up and away from engaging accidentally. Finally, you can smear a little grease on the internal cork disk that mashes into the main disks. The final adjustment is to replace a large motor pulley with a 2 inch pulley, or to add a 2:1 speed reducer.
  9. I didn't find that. I sewed with the optically modified motor on my cb4500 and a couple of walking foot machines. They worked very well. The Cowboy had a 3:1 reducer. My long arm Singer machine fed directly from the motor's 45mm pulley. They had no hesitance to start turning over.
  10. I'm not an engineer; just a knowledgeable user. Optical speed control is not new technology. I've had volume pedals for my pedal steel guitars from decades ago that used a small light bulb or LED to emit a focused beam against a photo-resistor. The sensor/resistor controlled the signal transfer between the input and output jacks. When backed off, heel down, a small phenolic board blocks the light beam, so there is no output at all, yielding full resistance. As one moves the pedal with his toe down, the phenolic board is brought out of the line of light, gradually increasing the amount hitting the sensor, decreasing its resistance. This results in an extremely smooth transition from zero to the maximum volume that the volume pedal is able to transfer to the amplifier (~95%). My current electronic volume pedal is still optically controlled, but uses a variable density filter instead of a solid piece of board. It has a small amount of amplification so that it doesn't lose any signal at full volume. Fast forward out of the world of pedal steel guitars and into the world of digital servo motors on sewing machines. In 2011 through 2013, our main 441 machine suppliers sold them with a digital motor that had a 45mm pulley. Some started with a jolt at 200 rpm. Others started with a similar jerk at 100 rpm. So. somebody took their motor apart and saw that it was optically controlled, just like my old volume pedals. That person had a good printer and some transparent "paper." He went and printed out some strips that had a varying density of gray ink, smoothly ranging from 100% black to 100% transparent. By playing with the spread of the printed filter, he came up with a simple optical filter that anybody could install inside their motor. He sold them through the forum for a modest fee. I installed one in my Cowboy cb4500, in my buddy's Cobra Class 4, and on a Techsew I acquired a little later. This modification worked 100% as designed. The only thing that caused a variation was if the machine hit a bump in the floor when I moved it to sew a log project (webbing strapping or a long rifle case). It was a simple matter to reposition the filter, which I later glued in place. So, is this new KineDyne motor optically controlled? If so, have you considered using an optical variable density light filter to control the speed? I think I still might have a spare filter in an envelope. Bob Kovar might still have a couple left. We could probably get one to you to experiment with. I'm pretty sure there is a variable density filter in my original digital servo from my cb4500, which is on the floor in a closet. If you try the variable density filter control system and perfect it, then secure it to survive shipping and man-handling, you will be able to offer a motor that smoothly transitions from absolute zero through the top speed as set on the control panel, with good low speed torque from the numerous coils. A side benefit of having a digital servo motor running this slowly is that there seemed to be much less heat being generated. Originally, we felt the heat as we sewed at 5 to 9 stitches per second. It was even running hot at slower speeds due to it starting at 200 rpm. I also disliked the non-linear speed change which ramped up after I pressed down on the pedal. It wasn't an instantaneous change that I preferred. I grew up using clutch motors on sewing machines, and still do on a few of them. I have since moved away from touchy digital servos to the analog motors sold by my Cowboy dealer. They contain brushes and replaceable carbon signal transfer blocks on springs. They reliably start at zero and speed up linearly as I press my toe down; just like my volume pedal on my steel guitar.
  11. @X24 A few years ago, I was friends with a guy and lady who were producing bespoke shoes and boots. After a couple of years, she left the partnership and went on her own. She decided to make moccasin style footwear. She enlisted me to help find some suitable sewing machines. To my amazement, I discovered a specialized shoe sewing machine that is called a "sole sidewall stitcher." This type of machine combines the vertical sides attached to the soles to the uppers, all around their sides. I did a quick Google search and discovered that some of our own advertisers sell these sidewall stitchers. Brand names that come to mind include Cobra, Cowboy and Techsew. Although not an advertiser, yet, Campbell-Randall in Texas also carries these machines. You can see them in action in the videos in a 2017 topic linked to in the topic below. Here is a previous discussion about sidewall stitchers on Leatherworker.net:
  12. It's probably not going to fit on the needle bar of the 45k. I recommend contacting industrial sewing machine dealers who sell the GA5-1 machines and ask if they carry the roller foot assembly for it.
  13. I'm not familiar with either machine. But, I googled both and found that the main difference is that the Seiko is a compound feed walking foot machine, while the Consew is merely a needle feed machine. The walking foot would have an advantage if you have to sew over new layers and tall seams. Its compound feed will simply walk up and down over these changes in layers. The needle feed machine will stop against a new layer unless it is very thin. Both machines are double neelde machines. You'll need to learn how to turn corners properly and balance the knots with two tensioners and bobbin tension springs. Both use large bobbins. In some instances, time is money. If your sewing is based on an hourly charge, the needle feed machine will probably spin faster and run smoother. There was a discussion about the Seiko in 2016, here:
  14. When you come to any sharp corner, bury the needle, then feather the speed pedal, or hand wheel the machine until it rises a little so that the hook is inside the thread loop on the right side of the needle. Raise the presser foot enough to clear the leather, then rotate the leather, lower the foot and continue sewing. Doing these steps insures that you don't break the needle or lose the thread loop, which will cause a skipped stitch.
  15. @thobgood In case you didn't know, Juki machines are top shelf for many applications. Yours is a top notch garment material sewing machine with a fixed foot and bottom/drop feed. Once you get the timing right, it will be a money maker. Many leather crafters on this forum sew heavy and thick leather projects on specialized machines we often refer to as harness or holster stitchers. Way back around 1986, or so, Juki came out with a heavy duty harness stitcher that they assigned the model name/number: TSC-441. I saw one that was still in a wooden carton in a sewing machine warehouse. At that time, the dealer told me that I could take it home form only just under $6.000. I didn't have that kind of money and they didn't do financing to individual buyers. Fast forward to around 2011 and a Chinese sewing machine company obtained a Juki 441 and disassembled it. Then they made molds and began casing new versions of that Juki. They gave them new model names and sold them to dealers who assigned their own brand names. I bought one in 2012 that I still use every time I need to sew a thick project. It is a Cowboy cb4500. My best friend has an equivalent brand, called a Cobra Class 4. Both have the same capabilities. Techsew offers their own model as a Techsew 5100. You can now buy one of these machines for between $3500 and $4400, with all manner of accessories! In contrast, I just found a new Juki TSC-441 for sale from a dealer for $9400 plus shipping. Enjoy your Juki!
  16. Some hooks have a deflector shield that will prevent the needle from touching the needle. They are thin steel and bendable. Yours may or may not have one. If not, just move the hook away from the needle slightly. This may alter the timing, so recheck it afterward and advance or retard the hook as necessary.
  17. No, that isn't the opener. On some machines there is a lever with a bent arm that pulls back on the bobbin case to let the thread slip through without getting hung up. If your machine has a latch opener, it is quite abrupt in comparison to those found on our typical walking foot machines. Without the opener lever, the only thing making room for the thread to the hook is the thread itself. That works if the top thread is taut, but can fail if it has too much slack.
  18. The bottom travel stopper is set by the bottom screw inside the open channel in the bracket. The slack adjustment is the little screw in the curved slot that's above the main shaft and nut.
  19. @thobgood When a machine that normally sews well suddenly starts missing stitches, there are three usual suspects. The first is when the needle and hook are out of time. The second is when the check spring motion is incorrect. The third is when the foot pressure is too light to hold the material flat during the needle take-up cycle. Since you have removed the cover plate, you can easily see if the hook is intersecting the needle above the eye, but still within the cutout "scarf." Where the point of the hook is can matter a lot, depending on the quality of the loop that's formed by the ascending needle. You could have perfect timing, but a too small thread loop that might not persist when the hook arrives to pick it off. I normally time my machines so that the hook intersects the needle 1/8 inch above the eye after it ascends about 1/8th inch. This isn't set in stone, but is a good starting point. If your timing isn't close to that, either move the needle bar or the hook. The quality of the loop is determined by two main parts. The first is the motion of the needle. The needle needs to go all the way down with the thread basically taut, then begin to ascend after the thread loosens up. That's where the upward motion comes into play. The hook must wait until the needle comes up as mentioned before. But, if the needle rises as specified and the hook arrives at the designated position and the loop doesn't get picked off reliably, the usual suspect is the check spring assembly! The check spring assembly usually has these three adjustable components. The stop motion bracket. This is a movable bracket that stops the downward motion of the spring where the thread comes out of it. It must keep tension on the top thread until the needle pierces the top of the material. Then it can stop moving. You might let the spring move down after the needle penetrates the bottom layer if it leads to better results. But, never stop before the needle meets the top or it might separate the thread and shred it! The slack adjustment. This is usually a curved slot with a tiny screw that is set to give a decent amount of slack thread. Normally, setting it to the far left gives the least slack thread and vice-versa. The normal position is dead center in the slot. A tighter setting leads to tighter laying stitches and the opposite direction leads to looser stitches. The spring tension adjustment. The tension is adjusted by finding and loosening a screw that is close to the body. It locks the shaft holding the spring in its position. That shaft is slotted on the outside for a flat blade screwdriver. Loosen it and use a screw driver to rotate it one way or the other until it just has enough pressure to hold the thread taut until it stops moving down. If it is too light, the spring may not move all the way down, which can lead to skipped stitches. However, it is it too tight, it may override the main thread tension disks setting. Balance the overall thread knot position by adjusting the top disks after any adjustments to the check spring assembly, and/or the bobbin spring. This may be a lot to absorb, but, it's important to understand. By playing with these adjustments you will better understand why your machine sews as it does, or misses stitches. The last thing I mentioned was the foot pressure. This is actually a two pronged issue. The foot, or feet in a walking foot system, must hold the materiel flat as the needle ascends and the hook arrives at pick-off time. If the material lifts with the needle, you will probably get skipped stitches! So, tighten the foot pressure screw on top of the head! But, what if you have tightened the foot action and the material still lifts between the legs? Yep, skipped stitches! When this happens, buy another foot with less space between the inside of the legs! Recap. Either confirm or adjust the nook to needle timing. Adjust the quality of the thread loop via the check spring. Make sure your presser foot is able to hold down the material between the legs. Once you fine-tune these settings, your stitches will be more reliable. Afterward, you might want to tweak the hook position for the quietest pick-off. If it is too close to or too far from the needle's eye, the thread will snap as it goes around the hook. It is usually louder if the timing is a little late. Try advancing the hook a little. Just make sure it arrives about 1/8th above the eye after the needle rises about 1/8th inch. Your manual may give the exact factory specification for timing the needle. If so, use them. The check spring slack setting can fine tune the quality of the loop. I hope this helps!
  20. Welcome back, Andrew! We missed you!
  21. Is this motor optically controlled? If so, there were people printing variable density optical filters that users could install inside their digital motors. These filters smoothed out to speed variations so the motor started at zero rpm and steadily increased as the operator pushed down on the speed pedal. Stopping the foot motion left the motor at that speed until one backed it off or pushed down further. I had this modification on a motor that came with my Cowboy cb4500, in 2011 or 2012. I would compare the action to the analog motors that replaced it.
  22. My first Juki was an LU-563. The reverse stitches were always smaller then the forward stitches Eventually, I discovered the adjustment to get the distances closer. However, as you found out, the faster I sewed, the greater the difference became. This was in the mid 1980s. Since then, I've had various machines with reverse levers, some of which matched at any speed and some of which were flakey, like my old Juki. A Consew 206RB-5 was pretty reliable in both directions. Many of my current crop of sewing machines don't even have a reverse lever. I either sew all around to sew over the starting threads, or spin the work around 180 degrees and perform what I call, "poor man's reverse." In both cases, the stitch length is constant. I sometimes do it on a machine that has reverse simply out of habit.
  23. One problem I have had with digital servo motors vs analog servo motors is the jerky start up. I can understand that lowering the startup speed to 50 rpm will be less jerky than a 100 or 200 rpm startup, it will still engage with a hit. Analog servo motors I have start at zero and smoothly increase in speed as the pedal is pressed. There is no jerk at startup on those motors. I have helped convert several Cowboy and Cobra 441 clones and one Union Lockstitch machine from digital to analog servos for this very reason. Once the change was made, the owners never complained about being able to control the machine or position the needle as needed. I would be happy to have a digital servo motor that started at zero and increased in speed only as I pressed down more on the speed pedal. I don't like motors that start fairly slow, then speed up on their own ("ramp up"). The motor speed should be pegged to your foot position on the speed pedal. If one needs an external speed knob, the same should apply. As the knob is rotated, the speed should increase. Because many servos lack high torque at lower speeds. I can see that the ones having more coils will have more low end torque. I would gladly pay more for an analog servo motor that eliminated to need for a speed reducer. However, when sewing thick veg-tan leather, the faster one sews, the greater the heat that is generated on the needle. I found that when I sewed at 15 stitches per second, smoke came from the needle! This also began melting the bonding agent on the nylon thread. The result was a weakened stitch line. I doubt that I am the only person who prefers to sew slowly to maintain control of the stitch line and needle placement, as well as to keep down the heat on the needle. I typically sew within a range of 1 (for detailed designs) to 6 or 7 (on straight edges) stitches per second. When I sew at higher speeds, I use an edge guide. When the leather is thinner, I can sew faster than when it is very thick. It can be dangerous to sew 3/4 inch at 5 or more stitches per second. If a fast moving needle is deflected by thick layers and breaks, it could embed itself in one's skin! Ask how I know this!
  24. I got my first ULS in 1986 or 87. I bought it off Tandy Leather. It was sitting in the middle of their parts warehouse, unused for years. There was nothing with it except the needle and awl in the head. No accessories or thread. Once I got a manual and learned how to thread it correctly, I used the large sizes of thread I already had from a Singer 132k6, which was my previous heavy duty machine. All my thread was bonded nylon. So, I used nylon thread in various sizes. I adjusted the pull up positioner, the looper, etc, until I got perfect stitches. I did this for most of the time I owned that machine. I tried running Barbour's Irish Linen thread, but it kept hanging in the barbed needle, or on the looper. I just couldn't figure out how to run linen thread through liquid wax without it sticking to the needle or looper. Arrg! So, I kept going back to bonded nylon. If I get another ULS, I will buy bonded polyester thread just to keep it happy! ;-)
  25. MB, when the ULS was main primary stitcher, I bought every size needle and awl available. First, I got them from New York. Later, from CR. If memory serves half right, I had needles from .5 through 6 or 7 and awls from 1 through 7 or 8. My most used combos were a #2.5 needle and a #3 or 4 awl. Some of the awls had slanted leather points. These made tighter holes for edge stitching. I was able to sew with thread sizes 69 through 554. You're right about the reason for the tool tray. I kept the round wrenches in it, as well as packs of needles and awls. Did you ever do business with Freedman (or Freidman) Harness in Toronto? That's where I learned about Campbell and Randall machines and how to operate them. They helped my with setting up my first ULS machine (from 1968). I brought that machine with me when I moved back to Michigan. I wish I had kept it. The then wife said why don't you sell that big ugly thing that's taking up space in "my" dining room. She's long gone, but so is that machine!
