Wizcrafts
Moderator
  1. Tony stopped making sewing machines years ago. The last model he made was called the Windham Cub, which was sold to Weaver Leather and rebranded as the Weaver Cub.
  2. Any walking foot machine that can sew 3/8 of an inch will have to have a maximum clearance of about 1/2 inch with the feet fully up. This is because they walk up and down about 1/8 inch, plus or minus. So, look for a machine that clears 1/2 inch or greater. The Juki LU-1508NH comes to mind. This is a production machine that will last for decades if not abused (meaning oil it regularly). There are clones of this machine, but they aren't cheap. If you really intend to sew something with #46 bonded thread, know that it is about the same size as common garment thread; just stronger. I believe that you'll need a #12 or #14 needle and probably a softer action primary tension spring. The check spring tension will need to be backed off and the bobbin spring action increased. In other words, you'll have to dumb down the machine to use #46 thread. Rather than dumbing down a walking foot machine, think about getting a bottom feed tailoring machine with a flat foot. Or, if you'll be sewing thin leather, a roller foot machine. The advantage of a tailoring machine is that it will have a small hole in the throat plate to accommodate a #12 or #14 needle without excessive clearance like a walking foot machine will have. The first machine that comes to mind is a Singer 31-15 flat foot, or 31-19 "kick foot" that has a spring loaded outside foot, but fixed position needle and inside foot. These are flat bed machines that can easily handle thread sizes 46 through 92. By changing the needle plate and tension spring, they can handle #138 thread. Further, there are roller foot conversion kits that fit the 31-15. Boot makers, like Lisa Sorrell, often use this machine, or one like it to sew fancy stitching on Cowboy boots.
  3. @MattiJoy2; Get the model number and maybe a low res photo.
  4. @MattiJoy2; You will need two machines if your friend intends to sew serious holsters. The reason is that a proper holster should be sewn with a minimum thread sizer of #277. The machines capable of handling this size thread are too heavy duty for upholstery. I know because I own multiple sewing machines and can attest to the fact that big holster ready machines will eat thin leather and vinyl unless they are "dumbed down." Unless you can only afford one machine, consider getting a heavy duty machine for holsters and sheathes and another medium duty machine for thinner work and vinyl. I use a Cowboy CB4500 for heavy thread and thick projects and various walking foot machines for lighter jobs. Some are flat bed, one is a cylinder arm, two are patchers and one is a post bed machine. Each does something better than other configurations.
  5. You can use the search box to look for previous discussions of the machines you are interested in. There, you will learn about any issues others have had with those machines. I always recommend that you go and try out the machine, or have the owner show you if it sews and how to thread and operate it. From reading previous topics about the Adler 291, it may be a difficult machine for a beginner. Also, parts may be a problem. As for the Consew, it is a simpler walking foot machine that is similar in design to the venerable Singer 111 series. The G size bobbins hold a fair amount of thread. It is limited to #138 thread, tops. Most of the time, I use either #69 or #92 bonded thread in my Singer walking foot machines.
  6. I split your request into a new topic. Hopefully, you will get the information you are searching for. But, as long as the machine is fully functional, who cares about the serial number or date of manufacture? I've had machines with obliterated serial numbers that worked perfectly. I've had others with clear serial numbers that were pieces of crap. Go see the machine and test run it with a piece of 8 ounce leather.
  7. If your disability affects your hands and arms, the Outlaw will be a real challenge to operate.The Cowboy 3200 and Cobra 4 are heavy duty harness stitchers that are best used with medium through heavy thread sizes. You'd be hard pressed to sew anything thin, or very soft with those machines. The Cobra 26 is a beefed up walking foot machine that's less heavy duty than the harness machines. It won't sew thick holsters or knife sheathes as efficiently as say the cb3200. If it was me facing this decision, I'd go for the heaviest duty machine that meets the heaviest work requirements, then I'd dumb it down to sew thinner work. Alternately, I'd buy one machine for thick, dense leather, that handles very heavy thread and has huge, long needles. Then, I'd buy a used walking foot machine, like the Singer 153, to handle thinner, less dense work that doesn't need large thread and huge needles.
  8. I used to have a Singer 153. It is a medium duty walking foot, cylinder arm machine. It struggled to sew over 1/4 inch of veg-tan leather with #138 thread and a #23 needle. It's not suitable for holsters as they should be sewn with at least #207, if not 277 thread. It is better at sewing compressible leather. It can sew up to 5/6 inch of soft to medium temper chrome tan bag or jacket, or chap leather. Aside from the thickness and thread size limitations, the 153 is a good machine as long as you don't exceed those limitations. It can sew chaps, jackets, aprons, totes, tool pouches, patches, hems, purses and wallets. If you are considering buying this machine, make sure that it's mounted on a powered table and that the motor works. This is a very old machine and may be driven by a heavy clutch motor. You'll have to learn to feather the clutch, or else, swap it out for a servo motor. This will involve additional costs.
  9. The problem with reversing the motor is that if the hook runs backwards, it won't pick up the thread loop off the needle. Sewing machine shuttles pick off in one direction only. To reverse the feed, the machine needs to be designed to reverse the direction of the feed dog and anything else that moves in sync with it. In the case of walking foot machines, there are 3 things that need to reverse: the feed dog, then needle bar and the inside foot. For bottom feed machines with a fixed foot and needle, only the feed dog needs to reverse. You cannot add this onto an existing machine. If you want a machine to reverse, buy one that already has a reverse lever.
  10. It uses system 135x16 in leather points and system 135x17 in round points.
  11. You are probably using the Schmetz S point needles that came with the machine. It's their nature to create a submerged appearance on top because of their geometry. Order you some diamond point needles and the stitches will lay more on top and appear longer. Some are 3 sided and some are 4 sided. Their holes are closer in appearance to round points than the S points are. You might even be able to use round point needles with chrome tan leather. I use them all the time when I sew embroidered patches onto leathers. But, they're done on smaller walking foot and patcher machines.
  12. @Bosko90 If you've checked the entire thread path and nothing is binding, but too much thread is being drawn around the bobbin, you can adjust the "check spring" so it provides less slack thread. One way is by moving the bottom stopper bracket down to make the spring hold the thread taut longer. Another way is to tighten the check spring's action by loosening a set screw and using a screwdriver blade to turn the shaft holding the spring in whichever direction tightens it. Then lock down the set screw.
  13. Our member, @shoepatcher may have one he can sell you.
  14. @Southerngunner Your 144 year old machine is still in perfect sewing condition! They sure built things to last in the late 1800s.
  15. Google Translate converts it into English, as follows: Good day everyone! I'm looking for a special meter for sale that can be shipped to Mexico! Stay tuned, greetings and good day!
  16. @Southerngunner My heart skipped a beat when I saw your photos of this 19th Century machine! It is in mint looking condition! When these types of shuttle machines were the rage, they were built strong enough to sew leather. I refurbished a few Singer 27 and 127 boat shuttle machines from the late 1880s and 1890s and they were able to sew 9-10 ounce bridle leather strips with #92 bonded thread (using a #19 or 20 needle)! I included a sewn sample with the machines to help sell them. If your machine can even sew 8 ounces, with #69 thread, it's worth 10 times what you paid for it!
  17. You'll want a compound (triple) feed walking foot machine for multi-layer garment or chap leather jobs. If the shirts are also made of leather or suede, the same machine can be used. However, if the shirts are made of cloth, and it is anything lighter than heavy denim, a walking foot machine may eat the fabric! For these projects, a bottom feed machine is better. There are plenty of those out there. Every alterations shop has tailoring machines that are bottom feeders with a flat presser foot. I have a bottom feeder at home. It's a Singer 31-15 that was made in the early 20th Century and still runs just fine. My Dad had one for his entire professional life as a tailor. He bought his new in 1920 and retired in 1975 or 76. These machines have interchangeable feed dogs and throat plates. Some feeders are for fine work, like dress shirts, and others are more aggressive for heavier materials, like coats. The 31-15 machines are able to sew chaps and even shoe and boot uppers if you use a roller foot. There is another type of walking foot machine that just has top and bottom feed. It is commonly used to sew vinyl, canvas and webbing. There are teeth on the presser foot that claw the work on top in sync with the feed dog on the bottom. The needle only moves up and down in dual feed machines. While they are great for use on materials that don't hold tooth marks, they shouldn't be used to sew veg-tan leather. Ask me how I know.
  18. I sew around round magnets when we make phone cases and other items with magnetic closures. The trick it to attach a single toe presser foot that presses on the outside of the stitch line, not one that goes on top of or right next to the magnet. In our case, we use a right toe foot and allow sufficient clearance on the project to keep the foot on the leather. It can be trimmed afterward. One reason to not have the presser foot come down on a magnet is that the magnet might crack from the impact.
  19. @AlanLessing, Since you are just coming out or a hand sewing environment into a sewing machine environment, you need to assess how each item you assemble would be sewn on a machine. Obviously, flat seams and things that will be sewn while laying flat can be sewn on a flat bed machine, which is the most common. But, if the pieces become curved, or have shapes on the bottom on one or two sides, a flat bed won't do. Those may require either a cylinder arm or a post bed machine. In order to give you any accurate advice, we'd need to see the items you want to sew. Since you mentioned wanting to make shoes, you're already into the realm of needing two or three different machines at a minimum. I have a friend who delved into bespoke shoe making. He bought an old Singer 107 zig-zag machine to start. Then, he added a flat bed walking foot machine with reverse. Next, he discovered he needed a post bed machine, then a cylinder arm. He acquired a sole stitcher along the way. I thought he was done until he called and asked me to help find a suitable side-seam stitcher! Crime-n-Ebblies! When does it stop! If it turns out that you're going to need multiple types of machines, forget your imaginary budget! Poof, it's gone! Be prepared to spend lots of bucks. Even if you find every machine used and in good condition, it will end up costing several thousand dollars. Ask me how I know.
  20. @TrigoLaneTrading Since you bought the Cobra machine new, you are entitled to free support from the parent company: Leather Machine Company, in California. Their contact info is on the bottom of the home page. Until you are able to contact them and open a troubleshooting ticket, here are some tips for you to follow. Make absolutely certain that you have threaded the machine exactly as shown in the user guide that accompanied your machine. I recommend inserting the top thread through the top hole in the top mounted guide post, then turn it around counterclockwise and feed it through the bottom hole to the loop under the top tension disks. This can counteract any right twist in the thread that can cause the thread loop to dissolve prematurely in reverse. Make sure that the top thread is fully seated in the top tension disks and that it moves freely when you lift the feet, then tightens when you drop the feet. Make sure the top thread feeds through the loop in the check spring and that the spring moves up with the take-up lever and stops moving down as the tip of the needle meets the top of the feed dog hole. Make sure that the needle is aligned so that the scarf above the eye faces due right and the ribbed side faces due left. Make sure the needle is fully seated up in its mounting hole and tightened in. Make sure that the bobbin thread feeds smoothly without any jerkiness or binding and that it has good tension on it. These machines don't like operating with light spring tensions. There are two spring loaded screws that secure the shuttle assembly to the head. Screw them all the way in, then back off each screw 1/2 turn. This lets the thread push the shuttle outward to avoid binding as it goes around the shuttle.The springs over the screws push it back in after the thread finishes its cycle. Add some more top tension via the large hollow screw on top of the head, where the presser foot bar moves up and down. If the tension is too light for the material and thread, the work can lift with the needle, causing skipped stitches and mangled top thread. If none of these steps fix the problem, your hook timing or position may need adjusting. Try to get LMC to walk you through the process. They have videos about this on the website. Do NOT try this without a visual guide or expert assistance the first time you need to adjust it. If you get it wrong, the machine may not sew in either direction. Once you understand the process, you can adjust it any time the timing goes out. Your timing can be knocked out if the screws on the hook, or its driving cam on the bottom shaft are loose. It can also be knocked out it the needle hits metal and the needle bar screws aren't really tight where they connect to a driving crank shaft inside the head.
  21. This post is 13 years old. I haven't seen Eric active on the forum in several years.
  22. I've been using bonded nylon thread to sew patches since 2012. I normally use #69 thread, top and bottom, with a #18/110 Schmetz Serv 7 round point needle in system 135x17. I discovered that leather point needles tend to separate the edge threads, which are usually sewn with a serger. Round points don't usually ruin the edge appearance like leather points. I think that if I lived in a hotter location, where there was a lot more sunlight, and sewed for local clubs, I might switch to bonded polyester thread. It is only slightly weaker than nylon. While #69 (T70) thread is adequate for securing patches on a thin vest, it may not do so a padded leather jacket. If the owner expresses concern about the thread letting go, or the patches being too easy to tear off, move up to #92 thread and use a #19/120 round point needle. Try to sew close to the border on club name or logo patches, to make them harder to pull off. Ambushes happen in Biker life.
  23. I bought this inexpensive binder platter on Ebay, a couple years ago. I clamps onto the edge of the table.
  24. Bring some of your material with you. Have them try to bind it with their tape and binder. Then, let us know how it plays out.
  25. @Dave9111 Have you tried contacting Sailrite using their online chat? They deal with people sewing canvas and nylon. All of their machines have special binder attachments available that work with the bias tape they sell. This ain't yo Momma's bias tape either. Some of it is made out of canvas. They sell Sunbrella and matching bias tape. Chances are that their folders and tapes will get your jobs done correctly. Here is one of the Sailrite videos demonstrating how to sew both inside and outside 90 degree turns using Sunbrella bias tape and fabric.
