Wizcrafts
Moderator
  1. @JAM, You should look into a 7 inch tall post machine with a roller foot and roller feed dog. The 7 inch post will let you sew in a circle over the post to combine the uppers, and to sew decorative patterns. Most post machines are able to tension #92 thread and under. Some may even handle #138. Many cowboy boot pattern stitching is done with #33 or #46 bonded thread. The seams are combined with #69 or #92 thread. You'll need to stock up on several needle sizes and points, including these: size 12 for #33 thread, size 14 or 16 for #46 thread, size 18 for #69 thread, and size 19 for #92 thread. Most leather is sew with some shape of leather point needle. Some shapes cause staggered stitches. Others lay down a straight inline row. If you want to sew flat work before combining the edges, get an upholstery class walking foot machine, like a Consew 206rb-5. That machine handles from #18 through #138 thread with ease. It is too strong for #46 and thinner thread, but it could be dumbed down with softer action tension springs. You may need to use a McKay or Landis sole stitcher to attach soles to the insoles, or welt. It really depends on how you construct the bottoms. You may be able to just use contact cement.
  2. That's good to know! @CowboyBob has sets of actual Singer taps and dies that he uses to repair old Singer sewing machines in his shop: Toledo Industrial Sewing Machines.
  3. Almost 40 years ago, I went through the growing pains of finding a proper sewing machine for leather projects and holsters. I started out by getting what turned out to be a tailoring machine, but looked like it could handle anything. WRONG! I kept buying heavier machines from people who insisted that their machine could sew anything you put under the foot, or feet (walking foot machines have two feet). The most I could sew on a Singer 111w155 turned out to be about 5/16 inch on a pancake holster, using #138 bonded thread. I've owned over two dozen industrial sewing machines since I started in this business. The machines that are built to sew thin work are too light duty to sew thick items, and vice-versa. I keep different machines for different types of sewing. All holsters are sewn on a Cowboy CB4500. No ifs, ands, or buts! I have standard walking foot machines to handle thinner work, upholstery, patches, and repairs. I suggest that you read this topic that I started a number of years ago:
  4. I have successfully sewn leather soles onto a shoe with my cb4500 using a narrow inline foot set I got from @CowboyBob- at Toledo Industrial Sewing Machines. However, they had a 1/4 inch minimum width flange stitcking out past the upper toe box. A 5/16 or 3/8 inch flange would work better. Trim the excess afterwards. That said, the walking foot mechanism is wrong for sole stitching. It is best to buy a Landis 12 that somebody is getting rid of for peanuts after going out of the shoe repair business.
  5. That is the foot lifting lever. It mounts somewhere along the back of the head with a large bolt holding it in place. There may also be a spring that goes over it to force it to stay down until you want to lift the feet using the floor foot lift pedal. There may be a chain feeding down with S clips to connect it at both ends.
  6. You *can* do it on a post machine. The only trade off it that you won't have a flat surface for zippers or certain more critical seams. I prefer to sew in zippers on a flat bed machine. It keeps them aligned properly. Sewing them on a cylinder arm or post machine distorts the alignment between the zipper and the two layers of leather that are doubled over inside the zipper pull path. Then, there's the hanging weight to consider. If the jacket gets heavy, the hanging weight will try to pull it off the arm or post. You may get bad stitch lines. I have hossed a lot of leather jackets around sewing in zippers and I prefer a flat bed if they are heavy. I suppose you could try using a cylinder arm machine with a table attachment and see how it works out. I have one that is mounted on what's called a U shape table. With this table there is a flat surface, albeit a foot below the arm.
  7. First of all, if you must use #138 on top, use a smaller bobbin thread, like #92. It will be easier to hide the knots with a smaller bottom thread. Next, ramp up the bobbin tension for s strong but steady pull. Balance the knots with the top tensioner. Stronger tensions may help keep the knots hidden in the same position from the bottom. Just don't ramp it up so far that the leather puckers! Next reduce the slack in the top thread by moving the check spring disks to the left. There should be a curved slot with a set screw inside it on the outside check disk. Loosen the screw, back off the thumb nut a bit, then rotate the disk to the left. Tighten down everything you loosened. Less slack may help center the knots more reliably. Set the stitch length to about 6 stitches per inch. Finally, change to a #21 needle. If you have a choice of points, a diamond point is close to a straight point in the results. A diamond point lets the top thread sit on top of the leather more than an S point or chisel point.
  8. @jayl65 There are some walking foot machines that have a large knob on the top that alters the foot lift amount and ratio, from low to high. A machine like this would let you set it to extend the inside foot all the way down when you drop to a single layer, thus pressing down directly around the needle to get perfectly balanced stitches at the transitions. The trick is to set the inside foot position so that it makes contact with the top of the leather at the same time as the point of the needle. The closer these two things are, the better the results.
  9. I've been sewing leather since 1984. My Father had a tailor shop for over 6 decades and he only owned one sewing machine: a Singer 31-15. Once he set the tensions, he was good to go. But, he only sewed cloth. Armed with this history, my first industrial sewing machine was a straight stitch Singer 96k40. I bought it to sew a leather vest that i was constructing from a pattern and leather that I bought at my local Tandy Leather store. After gluing the varipus pieces together I began sewing across some back seams. The moment the foot encountered a new layer, it stopped in its tracks. When I used the knee lever to lift the foot, the stitch tension got screwed up, then the needles broke. I went back to that dealer with the vest in hand and he sold me a Singer walking foot head only. It dropped into the same table. That machine sewed the vest without any hiccups or readjustments. It was the old style spring foot mechanism with an oscillating horizontal hook. Decades have passed since then, and I now have a shop full of walking foot machines. The absolute best one for climbing up and down while maintaining good knot placement is a Cowboy CB4500. The next in line is an Adler 30-7 patcher with a top feed walking foot that turns 360 degrees to feed the work in any direction. The rest of my machines are compound feed walking foot machines. Some have issues changing to different layer and others are not so bad. All of my machines have check springs with adjustments for tension, stopping position, and importantly, slack. When sewing thick seams, it is best to give the top thread more slack via the check spring adjuster. Most of my machines have a common round disk covering the check spring. There is a curved slot on the top area with a set screw that can be loosened and tightened to control the amount of slack in the top thread. If you are going from a single layer to a double layer, preset the adjuster for the maximum slack, then adjust the top tension to hide the knots well inside the single layer..You should get them drawn up to about the same depth when you come to the new layer. While this holds true for moving UP to a new layer, it may or may not be the same going down. Sometimes, the first stitch or two will draw the knots right up on top of the bottom layer because the foot is not directly pressing down around the needle. Here's where using a compound feed machine excels. It has an inside alternating foot that pressed down directly around the needle. As long as that small foot makes hard contact with the bottom layer, the stitches should be properly buried. Another bad thing that can happen when transitioning from a higher level to a lower one is that, without intimate presser foot contact, the bottom layer may lift up as the needle ascends. This not only throws off the knots, but causes skipped stitches because the thread loop on the needle dissolves before pickoff time..
  10. I have dealt with images since the start of Web 2.0. Back in the days when you connected to the 'net through a dial-up modem, image filesze mattered a lot. So, I researched some Windows programs and bought into Paintshop Pro, which is now owned by Corel Corp. One of the features of Paintshop Pro is that, after any resizing, cropping, sharpening or effects, you can save as both a file TYPE and QUALITY. If you save the photo as a common JPG file, you can choose the amount of compression to apply to reduce the file size. I find that I can save jpgs at 80% quality and still make out all of the details unless you enlarge the photo a lot. Another program that does this is called FastSone Photo Resizer. It does everything from one interface and is made for Windows computers. If you don't have a Windows computer, there are photo resizing Apps available for most smartphones...
  11. That spring pushes down on the inside foot, which pushes down on the material under it. Under that is the feed dog with its hole or slot for the needle. If you get prominent pock marks on the bottom from the hole in the feed dog, back off that top screw and let the main pressure spring on the back exert most of the foot pressure. I've attached a manual for the Singer 111w155 and 156 that shows the various views of the parts, including the rear pressure spring. It also contains valuable usage details. 111W156.pdf111W152_W153_W154_W155.pdf
  12. No, it isn't. But, it does have a strong effect on the force needed to turn the machine it it is all the way down. That spring and screw affect the inside alternating/vibrating foot. The spring I was talking about runs along the back side of the machine. It is a long, flat bar, about 1/8 inch thick, 1/2 inch wide and maybe 10 to 12 inches long. There is a screw about half way along the back side that pushes down to add pressure to the outside foot.
  13. I have a 211G156. The foot pressure is adjustable via a screw over the long pressure spring. Try backing off that screw and the foot pressure should ease up.
  14. You can buy 1/4 inch diameter leather belting and a steel C clip and cut it to size. Order a 64 inch length and you should be golden. You'll need a tiny hole punch, like for poking a hole for a hand stitching needle. Most revolving punches have this size in them.
  15. Thanks for posting this data with the tpi and equivalent screws.
  16. @Agent319Contact Bob Kovar, at Toledo Industrial Sewing Machines, in Ohio, or Ralph's Industrial Sewing Machines in Denver. Both are long time Singer dealers. I believe that Ralph's bought all of the remaining parts when Singer went out of the industrial sewing machines business. Finally, there's Hoffman Brothers in Des Plains, Il. They were also Singer sales and service going waaaaaaay back.
  17. This is very good advice. It might not be obvious to some people who haven't worked on disassembling sewing machines before.
  18. That's a first for me. I have never had a machine that threaded the bobbin retainer tab like that.
  19. First of all, I see thread that is bound onto the bobbin hold down tab. Free that thread before you do anything else! There should never be thread trapped like that! After freeing the thread from the tab, check the hook timing vs the eye of the needle on the upstroke. A properly timed hook will intersect the needle about 1/8 inch above the eye and sill be within the scarf cutout. Many times, a late hook will cause that snapping sound. Advance the hook a bit the loosen the thread loop. The check spring comes into play here. If the travel is too long, the top thread stays taut longer than necessary. Before you change the bottom stopper, try moving the screw in the curved slot to the right end of its travel. If that doesn't help, loosen the screw under the bottom stopper bracket and move it so the spring only moves a little past when the needle makes contact with the top of the leather. This adds slack thread and reduces the tension as the thread goes around the bobbin case.
  20. I agree with your assessment. I got my Cowboy cb4500 in 2011 or 12 and haven't had any mechanical problems or failures yet. It has more than paid for itself over these years. I will mention that it is necessary to keep it well oiled to ensure a long life. This involves removing the left faceplate occasionally to oil all the little holes in the crankshafts.
  21. What kind of motor is it? Can you take a small resolution picture of the machine and the motor under the table and upload it here? Use the lowest setting on the camera, like 1x1 or 3x4. If you need a new motor, consider this type, which I use.
  22. @Lostranger When I have problems with patchers, and the timing is as close as it can be set and the bobbin thread is not getting picked up, I look at the following things. The top threading. Make sure you've gone around the top tension disks and that they apply sufficient tension when the foot is down. Make sure you are feeding it through the hole in the check lever on top, then down the snout. The needle system. Make sure you are using either System 29x3, 29x4, 135x16, or 135x17. Make sure that there isn't a broken needle shaft stuck inside the needle clamp and that the needle is all the way up in it. The needle orientation. Make sure that the rib side is facing left and the scarf cutout is facing due right. The needle position. You can move the needle clamp to the left or right to get as close to the hook as possible. The paddle spring. This often overlooked spring is inside the needle bar, just above the needle clamp. It's job is to hold onto the top thread as the loop is formed when the needle makes a down>up job. If this spring is bent, gouged, or missing the thread loop will dissolve before the hook can pick it off the scarf of the needle. Check the driving gear inside the gear box to see if it has come loose. This gear is directly under the shuttle. There is a small screw inside the gear that secures it to its shaft. There is a hole on the back of the arm, inline with the gear. Rotate the wheel to bring the screw into view in that hole.You'll need a narrow blade precision screwdriver with a flat blade and good side handle to tighten it if it's loose. A loose drive gear throws off the timing. Finally, adjust the spring tension and travel of the check lever on top. It's possible that the spring is pulling it up too much and overpowering the paddle spring as it tries to secure the loop at pick-off time. If all of this fails, get rid of it. I fought with a blue body Singer long arm patcher for years and it never sewed reliably. I got rid of it and bought an Adler 30-7 and haven't looked back.
  23. Good find! Now, have you figured out how to keep this from happening again?
  24. There is a screw going into the housing that holds the check spring shaft in place. You should see it on the right side behind your arrow. Loosen it and wiggle the shaft out. The screw's job is not just to hold the assembly in place. It also is used to adjust the spring force. You would loosen that set screw, then rotate, then use a screwdriver blade to rotate the shaft to the left or right for more or less force. Once you are happy with the spring setting, lock the shaft down with the set screw.
  25. I'd start feeling and looking at the thread guides for burrs. You didn't mention whether or not the thread is bonded. If it isn't, you're supposed to run it through the wax pot to bond the strands. If you don't have Sellari's stitching wax, order some online.
