bruce johnson
Moderator
  1. I read the same thing for Stamps.com. It didn't look worth it to me after reading reviews either. I ship quite a bit and do the "Click and Ship" from the www.usps.com website. The site loads a little slow but is improved on features from a few years ago. There is a discount vs. window rates on smaller packages. Get into International Express and it gets to be bigger discounts doing it at home and you can print out customs forms too. I print out on plain paper and tape the label half on the package and file the receipt half. They give me a handful of the customs pouches for the international mail when I run low. I normally drop the packages off at whatever post office is handy. We use a PO box and my wife is at that post office everyday. Most of them either have a drop box or the counter people take them or have a spot for them. Your mail carrier will pick them up also. The only ones I wait in line for are Express Mail and International Priorities and get them scanned and a receipt. Some counter people recognize me at one post office I go to mostly. They call me up as a "non-money, ready to ship" drop-off to bypass the wait if I flash the label at them.
  2. I always stitch in a groove on top with any vegtan and most chap leather I scratch a line too as a guide. My tacks go in that groove line. I lay my belt inlays out so the lay of the hair is across the belt (pointing down). With the short haired Brazilian hides I only have hair sticking out the bottom. When I trim my linings and hide after sewing I use a rotary cutter. This cuts most of the hairs off flush. When I rub the edge up and then singe, the rest are pretty much gone. I dampen with my casing mix, slick lightly, dye, slick again a little more vigorously, add my sealant coat, slick when about dry, then paraffin and go to the burnishing wheel, sticks, or bones. This makes a pretty durable edge for me and lays down the chrome tan sandwich and blends it all well.
  3. I used to make a bunch of these. My lining was 3/4, the top side was split to 7 oz. I cut the hide with a rotary cutter from the flesh side. I glue about 6 in wide strips of hide to the same width lining with contact cement flesh to flesh. I skive the ends of the inlaying hide some to make a smoother transition at the ends of the inlay. You need to glue it in the middle of the lining and allow for the billet and buckle ends. For the topside prepare it however you normally do - stamp, oil, skive the buckle end, etc. I use a round end punch to cut the ends of the inlay. I use a border tool on a swivel knife to score the length of the inlay cut and finish with a round knife. Save the cutout. Slick out the inside of the cutout. I apply contact cement to the billet and buckle ends of the top piece and stick it down to the lining. I allow the lining to be oversized while I stitch and trim later. I put the inlay cutout back in and clamp in a few places with a binder clips. I sew with the binder clips in place. That cutout being back in there will help keep the top straight on the underneath piece. You can use tacks some on the top piece too. Once they are sewn I smooth the edges on a bench top belt sander. I run the edge down a flame to scorch off stray hairs sticking out from the inlay and then finish the edges. The chrome tan from the hide is sandwiched but still can take some prep. I dye and then finish.I like acrylic finishes like Leathersheen to give it some sizing and the texture lays down and blends in pretty well. A few variations. I made them mostly with 1/4" spots. When I do those I lay my top piece over the hide without a lining. I have the cutout in place and set my spots. Once they clinch through the hide, that helps keep everything in place some. Then I glue to the lining and sew. I still had my Boss stitcher then. It could sew up really close to the spots with a right toe foot. Neither of my current machines could do that with modifying the center presser foot. The two line ones without spots will sew with a left toe foot for both lines as long as the cutout is in there. Tack the edges to hold them and pull tacks as you get to them. I buy really slick short hair hides. They inlay better and look cleaner. I started out with some pretty wooly hides and they moved around more and were bulkier.
  4. Here's my thoughts. You could sure start with the basic sets and see if it all works out for you. Realize that most all of the good,better, and best swivel knife makers sell swivel knife blades too! That is something a lot of new people don't know. I think most all of them make a blade that will fit a Tandy knife. You can upgrade a cheaper knife and and get a handle on what a good blade feels like. As far as stamps, Yes there is a difference. To learn on? Probably not really necessary. If you are going to do passable Sheridan work, you will need some of the specialized Sheridan style tools to do it right, especially the tighter patterns and most stems. Regular bevelers just don't do it. You will also find when trading up to better stamps that in many cases they might run smoother (like bevelers) than the entry level stamps. If it all doesn't work out and you do have some good stamps to sell, they tend to hold their value relative to lower end stamps. Ebay seems to have no shortage of folks willing to pay more for recent tools than you can buy them for from the maker.
  5. Yes, that is the type crank skiver but I have an American model B with a little wider blade. It is about 2-3/4" which works on most of the strapwork I do. I have tried the jigs for the pull splitters and they work OK. I am just a little handier doing the the push the handle/pull the strap on a handled splitter. The only problem I had was they are a little awkward and I would occasionally have the jig or strap slip on each other. I am not sure how they would do through a crank splitter.
  6. Billy, Advantages of pull splitter vs. a crank splitter. You can pull through some softer leathers than a crank spliiters can sometimes split. Like I use one of my Chases for, you can start anywhere on a strap and level split all the way out. With a handled splitter like a Keystone or #84 you can also do lap skives. It can also be faster than a crank. I can pull something through faster than I can crank most of the time. In fact my first crank splitter was an American. The Americans and Champions both feed from the back instead of the landis system of feeding from the front. I'd start a strap on the American and when I could get a good hold on it, I'd pull it the rest of the way through and let the handle free wheel. I especially did that with latigo becuase it can sometimes wad up against the blade and split unevenly in a crank splitter. These are the biggest differences in use off the top of my head.
  7. Here's my take on this. Realize I am a splitteraholic. I buy my leather in a couple weights for the big flat projects. For the most part I buy 7/8 or so, 10/11, and skirting. I buy cheaper vegtan for lining big pieces, and use either that or split down heavier leather or latigo for lining straps. Currently I have four splitters on the benches. Landis 30 - I use this for splitting down odd shaped pieces, small scrap, and level splitting straps. My wife can easily crank out hand size pieces from the scrap bin and then click out coasters of the same thickness. I can split a wallet back pretty easy from scrap and so that is one weight of leather I don't buy. 8" Chase - I leave this pretty much set at 8 oz. I use this setting for the skiving the ends of straps and belts where they are going to fold over a buckle. Stick the strap in to catch the fold area, pull back and it is level 8 oz out to the end. I do the same for spur straps and dial it down to about 4 oz to allow for lining since I fold them bottom to top over buckles. 12" Chase - The width here is handy for two reasons. I can do a lot of splitting across the width before I need to strop or resharpen. I have also leveled some skirting pieces up to almost the width on cased leather. I don't do that a lot anymore, but I can. Randall Krebs pattern - This is what I use for repeatable level splitting. I can dial it right back to where I was a week ago. I can also do some "spot" skiving. I can have it dialed in to the desired depth. I gradually let the roller fall back as I pull and then taper it back out as I get to the end of where I want to end the skive. This works pretty well for folding over a buckle or dee on the end of a doubled strap. For my shorter lapskives I have a crank skiver. For long laps it varies depending on what other splitters I have on hand. I have used Spitler pattern splitters, #84s and #84 knockoffs, and really like the little Heritage brand for laps. I could sure get by without a splitter or even with any one of these splitters and do some of these things by hand. That said, having the versatility of these makes it easier, more repeatable, and faster work than handwork and lets me use my heavier scrap up better.
  8. I used to use the wooden blocks for everything. My biggest problem was when I got a new stamp was having to do the left shift/right shift to make room. Then there was the problem putting one back wrong and having to rerack everything to make room. I went to using cups on a pegboard at the back of my stamping bench and that worked pretty well. I sort them by type of stamp and size. My mauls and knives are all right there too. I recently added the stamp rolls under them to sort off the really good stuff. They are sorted by makers and pocketed by type of stamp. An old test tube rack works well to hold the handled tools like beaders and ticklers. I have a small wooden rack to hold the stamps in use for a particular piece. I have a few weight bags there too. I use a scrap of woolskin on the right to lay my swivel knife down on. That saves the tips from hitting the stamp rock and is a subconcious reach. This system has been my handiest so far.
  9. I am running into this problem lately and wondering if anybody else does. I am sewing on a Ferdco 2000. On some spools as I get down to 1/4 spool or less I start to get twisting as the thread comes off the spool (between the spool rack and the machine). It is like the coil memory of fishing line. It eventually builds to the point I get twisting and kinking all the way down, loops don't form, skip stitches, say bad words, cat decides the shop isn't that fun after all. I have tried laying the spool sideways so it unrolls off sideways rather than pulls up, There still is some of that memory coil there, although maybe a little less. Today I cut off a good sized length from an offending spool and ran it between my fingers out to the end and untwisted the coils. It sewed about 20 feet just fine so the problem sure seems to be the coiling. I have had to change thread suppliers and have tried a couple. I used to use Dabond (peasant color mostly) and had the problem rarely, maybe two spools out of a bunch off the top of my head. I have now tried bonded poly in different color (no manufacturer name on the thread) from another supplier and bonded nylon also. I am running 2 for 4 on these as I get low on the spool. They started off alright but both are now doing it. Bad luck?
  10. Same book and worth the bucks. It goes into some of the background and history, the tools and why and how they are individually used, and pattern layout and execution. The examples at the back are a study. Bob Park's book is another must-have too.
  11. Looks really nice Lucas. I like the beadline with the breaks on the skirt.
  12. I was taught to do it on heavy leather and just do it out of habit for the little I hand sew anymore. It will really lock down a stitch. On thinner leather sometimes the overhand knot can show to one side or the other and I don't do it then.
  13. Looks really good and hope you have a great show there. My wife has a scarf slide and two pendant necklaces from Shawn and I have the reins from you. She might need to have a collaboration deal between you two to tie it all together once we get past the hackamore.
  14. One of the showring pleasure saddle companies tried a foam padding under the bars and then a layer of leather over that. I rode a few colts for a guy in college and he had one. It slid around a lot.
  15. Just to toss my 2 cents in here. The granite inspection plates from Grizzly are sure nice and priced right. Curley is talkng about one that is 3" thick. The countertops don't come close to half that thickness. For heavy stamping or to really quiet it down, that thickness and mass sure helps make clean impressions quietly. Grizzly has a deal with shipping too. If you don't need the mass, then the sink cutouts work well. When they have them in stock, they are a couple bucks at the local Habitat For Humanity outlet store. I had a larger end cut off a countertop that I got free from a cabinet installer too. It was OK but a littel bouncy and tinny even with the weight from a large size. I used to use a free headstone too and that worked as well as the inspection plate. The biggest problem was I wanted to make a bench with the rock inset into the top. They wanted about as much to square up the headstone edges I had, vs. buying a larger inspection plate from Grizzly that was already rectangular and smooth sides.
  16. I hold them with visegrips if I go to the wheel. At least here they are getting harder to find in the injector packs in the drug stores. That said, those are sharper for me than the Tandy ones. The Tandy ones seem sharper out of the pack than the CS Osborne 100 packs too.
  17. Silver Sharpies are a paint type marker and not a penetrating dye like most of their other colors. You need to "fix" the color first to prevent the smearing. I use spray application of Supersheen but there are other fixative sprays at art supply and hobby/craft stores.
  18. Will there be guided tours of the Bob Park birthplace in Wickenburg? We are missing Wickenburg this year but going to Sheridan. Any plans for your classes there?
  19. Christmas orders are done, ready to start on the after Christmas is OK orders, and worked on a few tools between. I have added a few fresh tools to my website today. I put on some halfround pinking punches, a straight pinking chisel, and some hard to find scalloping punches. I also put on a nice Gomph knife and several good French edgers. Here is the link - Bruce Johnson Leather Tools Thanks
  20. Bret, Sure looks good!
  21. I would guess your cutting board is LDPE. I use that to punch on because it has some give and won't crack as fast as HDPE. However the HDPE works better for me to cut on. The knife won't bury as deep. Some leathers can be pretty tough. You end up pushing down as much as forward and that tends to make you bury a knife more too.
  22. I have one that mounts on my hydraulic stand from Ron's tools. It is just Ok to use. I could get by without it. It is a little unsteady and you bump the stand and the arm moves and you need to reset everything. Good for checking one though.
  23. Mijo, CS Osborne made that pattern splitter in 5,6,7,8,9,10, and 12 inch sizes but the 6 is the most common. Never fails, we are looking for an 8" blade and I find 10"s.
  24. Joe, It is kind of a humidity and terrarium effect. I used to suck all the air out and if I had more water than I needed I'd have to wait. With the air in, if I come out and first thing see a bag that is foggy, thenI know I have too much moisture and will open that one and lay the piece out to evaporate some while I work on another.
  25. The Lexol is the conditioner, I am not sure what all substitutes there are. I have been told that Bick 4 conditioner is the same or close. The baby shampoo helps break down the surface tension of the water and penetrates faster. I double that up on hard leather. The Listerine I use is the old tried and true brown formula. It is the antifungal. Contrary to what some think, it is not the alcohol in the Listerine that is the active ingredient here. It evaporates off pretty fast. Listerine contains thymol and will prevent mold growth. I use tap water here. Some people with iron flecks from the pipes will be better off with distilled water. I slather it on my leather and depending on thickness may let it sit for a few minutes and add more. I bag my leather in ziplocks with enough air to keep the plastic off the surface of the leather. Ziplock makes some huge storage that will hold anything up to saddle skirts. I case overnight usually and may go a few days at times. If my leather is drying while I tool, I spray more of the mix on with a hand sprayer and set to a fine mist.
