grittyroots
Content Count
33 -
Calendar
Everything posted by grittyroots
red rover red rover gritty rootys wants to come over
be careful if you pull the needele. badgers have a needle bearing that can be damaged really easy. you can also put cleaner in then hold your finger over the nozzle to back flush. then spray without finger to get all the crap out. then follow above. i mainly use acrylics and it builds up fast. good luck
i just bought a 2" u strap cutter and the second day chipped the blade on a glue spot on my cutting board.
My First Sporran
grittyroots replied to grittyroots's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
i would skiuve the gusset. i also get the gusset edge wet and the use small spring clamps to fit it to the back . when they dry it's alot easier to glue and sew. -
Stingray Knife Sheaths
grittyroots replied to lbaize3's topic in Gun Holsters, Rifle Slings and Knife Sheathes
wow those are really cool! -
thats really nice. i'm working on one now
i'm in knoxville we have a pretty good little group here. the tandy store hosts the group. keeven the manager is really knowledgeable and there some other folks who are willing to share. when your back in knox come check it out gritty
hi all i have acquired several gallon jugs of prime leather finish. the jugs were from around 1997 and they only had basisc info. i have googled it and i still can't find too much info. i figured it is not a stain it's a finish. i'm trying to find out if i can use it straight out of the jug, can i thin it. is it water basedand will it make me have childeren with 3 eyes. any information would be helpful i think. thanks gritty
How Do You Handle People Wanting To Cancel Orders.
grittyroots replied to billymac814's topic in Leatherwork Conversation
i always take a deposit for my furniture work. it is usually 50% this should cover my materials and time. if i have bought the material and have started the project i will not refund the deposit. if i have bought the material and haven't started i will refund the deposit less material. hope this helps gritty -
My First Sporran
i tend to do things alittle unorthidox. some say sporran some say murse worn with a kilt -
My First Sporran
picture 2 -
My First Sporran
ok i think this may work -
My First Sporran
sorry technical difficulties. i will hopefilly have pictures soon gritty -
My First Sporran
grittyroots posted a topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
here is my first sporran and my second bag. let me know what you think thanks gritty *note the gas, grass or _ ss belt buckle -
Purse Help!
grittyroots replied to immiketoo's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
i'm using goat for the gussett, but you can skive the edges of the gussett. then get the gassett wet it will be more plyable. this has worked for me, but i've only 3 bags. are you doing square 90 degree corners or a radius corner? -
Purse Help!
i punch my holes around the front and back then i glue back to gussett i use little spring clips every few inches to hold it all together. then i poke holes through the punch holes and gussett. i will do about 10 holes at a time, so i don't have to remove the clips all at once. hope this helps. i vote for the hidden skull gritty -
welcome, i loke the aged look of your wallet
hi str8line. i'm in knoxville. i learned to weld from a retired pipefitter/ tool making blacksmith in NC. i have much respect for your trade. i have a hard time focusing on something long enough to become a master at anything. always learning
hi bill do you have any pictures of something simular? i have a couple ideas. do want it to be a press or a hammer it? do you want removable dies to change sizes of holes? how many different spacing settings would you need. oh wait i just had an idea. i need to draw it before i forget it brendan
welcome to the site and to the addiction.
I Was Just Given A White 1927 Sewing Machine
grittyroots replied to grittyroots's topic in Leather Sewing Machines
thanks for the info -
i've been doing leather work for a few months now. i have been mostly doing carved bracelets, but i'm interested in learning all i can about leather. i'm a cabinet maker as a profession, but i'm also a toolmaker/ welder and i also do silversmithing. i'm happy to help anyone who is interested in any of these areas. you can see some of my work at grittyroots designs on facebook.
