Slow Learner
Everything posted by Slow Learner
Looks like I will be ordering at least 1 10mm and probably 8 & 9mm rivet dies as well. My earlier post about the line 20 and 24 dies I was in correct it seems that I mistakenly ordered one of the wrong dies. I have since ordered the correct set and am very pleased with Goldstar tools. Thanks Allen for your post on the rivet dies. Big help.
Thanks for the information. I use Corel Draw but no way I can do anything like that. Good work.
- 10 replies
Thank you! Very professional looking pattern. What program did you do the design in, If I may ask?
- 10 replies
Simple Holster
Slow Learner replied to Bryan M's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thanks Tip for that information. I'm not sure what this means? "I hope you notice I made my suggestion without the bias of the other contributor." Oh well. -
Rotating Swivel Tooling Station
Slow Learner replied to chriscraft's topic in Leatherwork Conversation
Consider the seat swivel for a boat. They are substantial and readily available at Wally World and I'm sure other places. -
May I as which carver you made it from. I have an old Harbor Freight hanging grinder but it is not reciprocating tool. What king of reciprocating carver did you use?
Thanks Bob, The demo says that turning down the controller helps with the thinner leather. Were you able to turn it down when working on the thinner stuff? I have nothing but time to practice at least as much as God will allow. Thanks for your thoughts.
It is both. After holding the stamp only a short time my hand will cramp and if I try to work through the cramp then I destroy the piece. It is difficult fro me to maintain the stamp grip pressure on the mallet therefor striking the stamp is inconstant making for an ugly project.
I used to work at a trophy shop and we used sublimation dye heat transfers onto metal and polyester material. I assume the process would be the same. We would spray a bonding agent on to the light colored metal or material then place the art printed from our sub dye printer (Hewlett Packard laser printer), onto the object then apply heat using a heat press machine. All of the supplies are available and the dye is quite expensive.
- 12 replies
- digital printing
- dye sublimation
(and 1 more)
I have the usual old age problems with my hands and tooling has become almost impossible for me to do. I happened across a tool call the "Power Mallett" and it looks like the thing that will allow me to tool/carve leather. The problem is it is very expensive as hand tools go. Almost $1000.00. A price I would willingly pay if I could try one out but the guy that invented the mallett doesn't live next door so hands on is out of the question. I have seen it demoed on Youtube and it is exciting but he is a pro and the inventor so it would look easy. I have always gotten good guidance here at leatherworker.net so I come here looking for anyone who has seen/know about this little machine and hear your thoughts.
I have just purchased a Goldstar tool press and dies. I bought both the line 20 and 24 and out of the bag as they were intended to be used, they did not work but a combination of the two I found four dies from the eight that would do both the line 20 and 24 snaps. I want to try some of their dies for rivets and spots but a twenty bucks a pop I am a little reluctant with out some idea as to which to purchase. If you have had some experience with their other dies I would welcome the input.
Simple Holster
I liked the holster and thanks for the pdf. I will build one for my 1911. It looks better than the NRA two piece holster they were touting some time back. With your permission I would like to try some different modifications. If it works out I will post the results. I would also like to see one of the "stick it in the barrel holsters" that shooter mentioned. I think I have only seen one of those and it was being used as a quick draw holster in competitions. They must have thought it a good idea. I don't know just saying. -
Is that all that is needed? I put my old singer in storage and picked up a clone shoe patcher to do the occasional work on thin stuff. I paid more for the patcher than the motor would have cost? If that is all that is needed, I will order a servo motor from toledo today.
Where did you get the post that attaches to the burnisher? The typical dermal post would be too short, I think? I assume you drilled through the burnisher piece?
I know this is off topic but since there are 31-15 users I thought someone here could help. My Singer 31-15 keeps breaking the thread when I sew leather but does ok when I sew heaver cloth. I have had the bobbin case, feed dogs and still the problem continues. I am wanting to put a servo motor and reducer wheel to slow the machine down and maybe that will fix the problem. Any idea? and Which motor and wheel should I use? Oh I forgot. I am using #16 leather needle and #46 Bonded nylon thread.
Slightly off topic but I have been trying to use my 31 15 and it keeps breaking the top thread when sewing leather. Fabric works fine. Also would a servo motor help slow down the machine for more control in tighter sewing situations. I would love to be able to use this machine to put decorative stitches on belts, wallets and watch bands.
Thompson Mini Walking Foot Pw-301 Sewing Machine
Slow Learner replied to uumpa74's topic in Old/Sold
Do you know the heaviest thread and largest needle that this machine will handle? I want to use a machine like this to add decorative stitches to belts, wallets and watch bands.- 8 replies
- sewing machine
- thompson
(and 3 more)
Have you talked with Steve about this? They are interesting observations. Since the Cobra 4 is for the most part a "clone" I would expect there to be a reason for difference. I have looked for what you described and sure enough my machine does the same. I can start sewing a single piece with a good stitch and as I sew the stitch will change and start pulling the top stitch all the way through the piece leaving the bobbin thread flat on the back of the piece. I adjust the stitch again and continue sewing then I will get a loose top stitch. The stitch stands up above the others and after I finish I have to pull the bottom of the stitch bringing the top stitch back down then milt the back stitch to take up the slack. I thought it was just me but maybe it's not. I'm going to call or email Steve with this information. Maybe he has some thoughts.Thanks
Oh, please let me in?
I had the same problem then I refreshed the page and it loaded.
Got it working now. Looks good on 5oz. and 1/2" thick. Now on to sew. Thanks Steve for your patients and understanding. It's good knowing you are there we non sewing mechanics run into problems. Darrel
This is to my fellow Cobra 4 owners. I for the most part like the machine even thought it probably is overkill for what I do. (holsters, belts and odds and ends. But I have a block and can't seem to find a solution. Of course I could call Steve but, I wanted to find out if others have experienced the same thing and if so how you resolved the problem. The problem is that when sewing around curves (not tight turns at all) or when sewing up a gradual incline to two or three thickness of 8-10 oz. leather the stitch length will become smaller. Sometimes it will happen when sewing a straight seam with no turns. I have about decided the feed dogs (spelling??) are the culprit. My machine came with the smooth surface feed dogs in place so I figured that was appropriate and never thought to changing. It has become very frustrating because every project ends in my quickly growing box of uoops. I can't let anything out of my shop that looks like that. I am about to go back to sewing everything by hand and suffer with the pain or give up completely and sell everything. HELP. Darrel.
I Want To Make An Electrician's Tool Bag
Slow Learner replied to Slow Learner's topic in How Do I Do That?
Thanks Dwight, I understand the need for specificity in the design as I have seen no less then 20 different configurations hence the confusion. Your drawing seems pretty straight forward and simple enough to make it practical. If you don't mind I may take your picture and develop on that and see what happens. Thanks Darrel- 2 replies
- bags
- electricain
(and 1 more)
I want to make a bag for an electrician friend. Specifically a tool bag and belt. I have looked at pictures but have not been able to make a pattern so I come to the place where I know someone will head me in the right direction. I have looked at the bag tutorial here, and even though it is not exactly what I wanting to do I may go with it anyway and make some dividers for tools inside the bag and some loops of some type on the outside for other tools. I just didn't want to reinvent the horse so to speak.
- 2 replies
- bags
- electricain
(and 1 more)
Owb Pancake Width
Slow Learner replied to chiefjason's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I like the tooled addition. How did you sew that on after molding the holster? I assume the holster was glued and sewn prior to molding. It is a classy touch.
