Everything posted by venator
The stitching was challenging as well as cutting circles but it turned out wonderful
Okay folks who use drop in liners, I'm trying to figure out how to size them. I always seem to be either 1/4" to a 1/2" off either long or short which leaves me with either a weird outcropping of liner or a weird outcropping of bag, how do you get it correct to the mm every time? Or is there some trick to give yourself a bit of flexibility?
I'm looking for a brogue punch, any idea where to get one other than KS?
So my bobbin winder stopped working and I want to open her up and take a look. I can see the bolts to pull but do I need to do anything special? Or worry about the large knob on top for pressed foot height? Stu
Casual Weekender
venator replied to venator's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
In the past I've done linings with interfacing to stiffen them but with this type of bag I don't find that necessary. I just do a turned lining out of just the fabric and use a plate in the bottom the same size as the base that rests inside the bag to help it keep it's shape. The drop in plate is in a fabric sleeve that matches the lining so it blends nicely. I find between that and just the overall shape the lining doesn't have to be particularly stiff. -
I'm quicker with my punches and maul. . .
Casual Weekender
Thanks -
Casual Weekender
Thanks for the kind words -
Casual Weekender
Thanks. I'm a big fan of this style of bag. Though I do need to develop one that's a bit more structured for the folks who like that. The lining was the client's choice. I routinely hit the fabric stores and scoop up the end of bolt sale items and that was one, then I can let them pick through and pick the one they want. -
Weekender bag
venator replied to Leatherhips's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very nice! -
Casual Weekender
Thanks. Now I just need to figure out how to sell some... -
Casual Weekender
Thanks. Our Adler 467 is a pretty solid all purpose but we want to add a cylinder arm and are looking at a cobra, cowboy, or techsew in the class 4 range -
Casual Weekender
Pretty much all of it. Much as I love hand sewing my hands go numb after about 10 minutes so it's never going to be practical for me to do. Plus because the pieces are joined with a semi-felled flat seam to give that nice rolled look and hide the raw edge they all have to get sewn twice. -
Casual Weekender
Thank you! It's my own pattern. I've certainly been inspired by similar bags and I'm sure I'm not the first person to make a bag this way but there was no pattern, nor did I copy anything I'd seen directly. I used to make similar bags out of 2 big pieces but recently I've started doing them out of the 5 pieces and I'm much happier. While it does require more sewing I really enjoy the way the seams frame the sides and give the bag a little shape, as well it's a lot more efficient for leather usage vs just 2 big pieces. I have another one ordered from a client that I'll be starting in about 2-3 weeks so I'll try to snag some pics and video and perhaps do a quick how-to if anyone wanted to see it. Thanks for the kind words. I'm not sure exactly where it comes from but it's a distressed brown oil tan. It marks very easily, and the marks rub out with use so it's perfect for bag that's going to get marked up anyway through use. My supplier carries it in stock in two colours, this and a toffee colour, so it's super convenient. It's about a 4oz, very soft. -
Casual Weekender
Thank you, this is probably the best one I've made yet, or at least on par with the best. -
I finished this recently for an order, they were so happy they've ordered another in a different colour. I'm quite thrilled with how it turned out.
First Double Gusset Briefcase
venator replied to venator's topic in Satchels, Luggage and Briefcases
Yup, and it's not bad leather, just a little down from bridle. I'm sure I could sell this one easily enough but it's what I had laying around that was the right thickness so away we went. -
It was an old side they had sitting around the warehouse they called "skirting". Basically it's like diet bridle, so a similar finish but dull and the flesh side isn't quite as pretty. So it's bargain bridle? -
Yeah it's some misc 4/5 oz skirting. The weight was perfect for this and definitely what I'd use in the future. You could use thicker for the uprights and 4/5 for the gussets if you wanted something beefier but it's not really necessary. -
So I went and made a double gusset briefcase, not the best leather but it was really just a test to see how it would turn out. I'm very happy with it, the handles especially were a nice new technique. There's two internal compartments as well as a slip pocket on each side. There internal pockets within one of the internal compartments and the strap with the snap is so you can drop it over the handle of your roller luggage without losing it.
No, I find the eco-flow goes on well enough if I use a fairly large diameter. If I try to push it through the tiny airbrush it helps to thin it a bit. I do thin my resoline 50/50 with water to push it through.
Well you can soak it with the airbrush too, but like with working it in with a sponge it just gets darker and darker too. I don't find the penetration any worse with the air brush and I do 2-3 coats on each item.
Yup, I find with the alcohol dyes too much of it ends up in the air and not enough on the leathers. Plus the waterstains seem to even themselves out a bit whereas alcohol dyes don't.
It's the Tandy Crimson waterstain, it's a great red and I prefer using the waterstains through the airbrush when I can. Air brushing is definitely the easiest way to get a nice consistent even coat of dye I find. I'll take a look, it's not really a big deal though since it's in the garage and it's not like I'm trying to airbrush at 2am.
