Everything posted by Bonecross
Designer Double Flap Purse (Shoulder Configuration)
Bonecross posted a gallery image in Our Leatherwork Galleries
From the album: My Creations
Hand crafted and stitched orange leather designer bag with blue pigskin suede lining. Configurable hand woven strap for hand/arm or shoulder carry. Main flap has a magnetic retention and secondary flap uses a snap. Solid brass D-rings, silver and gold angelfire concho on front flap and steel Diablo concho on strap. -
Designer Double Flap Purse (Partially Open)
Designer Double Flap Purse (Hand/Arm Configuration)
Designer Double Flap Purse (Fully Open)
Designer Double Flap Purse (Back Phone Pocket)
Woodland Possibles Bag (front pocket)
Bonecross commented on Bonecross's gallery image in Our Leatherwork Galleries
Woodland Possibles Bag (rear pocket)
Some key fob from scraps to change things up. Created for my neighbor who will be feeding my cat while I am away for a few days. Fun and quick projects -
Period style woodland possibles bag for flintlock hunter. Made of hand stitched 5oz cow leather, rust colored pigskin suede and antiqued brass hardware. Light brown dye with mahogany antiquing. Gusseted sides and bound edges. Personalized for the customer (at his request). -
Woodland Possibles Bag (Insert #1 - Inserted Inside Main Pouch)
Woodland Possibles Bag (Insert #1 - Tripocket and Ball Starter Holder)
Modular Insert for Woodland Possibles Bag. Three gusseted pockets with a single flap covering them. Ball starter tool holder on flap. -
Leather and brass small game carrier. Paws or necks can be passed through the loops to free your hands for other tasks. -
Wallet to hold flintlock flints. -
Bag for lead balls. -
Knife Sheaths (variety)
Thanks My first try at sheaths so I experimented with different styles with pieces of leather from my scrap collection. Luckily the knife maker sent me a variety of blade shapes too! The bottom left one is made with 5oz leather which was wet molded. The unique coloring was accomplished with a base of orange Fiebing's dye and streaks of dark brown dye. The streaks were done by using a piece of sheep's wool (like I always use to dye leather) but I cut the fur uneven, leaving peaks. Then I lightly brushed the dried orange leather with the dark brown to make streaks. Once dry I conditioned then sealed with Resolene. Hope my explanation makes sense! -
1930's Gangster Style Double Shoulder Holster
Ok here is the continuation then So we have a pretty dragon and the background layer that was pre-awled earlier to match the thread locations of our plug. We take a needle and pass the thread into the holes one by one. This is where leaving yourself lots of extra thread pays off! Start on one side and work your way to the opposite: See how all the thread is properly aligned, this is what you are looking for. Try to avoid getting them crossed: Now gently pull each pair of threads tight and tie a simple knot: Oooo pretty dragon right? AND NO FRIGGIN STITCHES!!! Now you can inlay this panel like you would normally to anything: a bag, piece of armor or even a Dragon saddle! Note that I am actually going to undo the knots and cut a hole behind that stone (I forgot!). This is why I use simple knots, lets me adjust or undo them if required!
I had not actually planned a second installment lol. Basically once you are done tooling and dyeing as usual, you stick the threads into the holes you punched into the background layer and tie a knot That's it, finito! Concealed stitches! Tip: You may want to add more stitch points than I showed... Depends on the project. Here is another one I made today, after it's base coat of green dye. I plan to make many of these and pick the top 5 but for now I am playing with the technique
I've done it cold and it worked, the rubbing action sort of melts it. So heating is not necessary, rub it in good with your fingers
Resolene or rub in beeswax!
I re-read Al Stohlman's description of the technique until it made sense and decided to make a walkthrough for this thread with a small project I have a project which involves small tooled dragons and I really do not want to have to pierce them with thread and ruin them...So what I want to do is use the Concealed Appliqué Stich. Here is a prototype: First step is to grab a piece of 8oz leather and make rough lines for the dragon. Then take a piece of thinner leather (I used 2oz) to act as a "plug" and make it slightly smaller than the shape of the dragon carving: We then flip our 8oz thick dragon over and carve the backside so that the plug fits into it (I used a variety of edging tools): Yaya it's fairly flush Position the Dragon and plug over the leather that will be used as the background (that you will stitch to), and make thread holes to properly support the piece through both plug and background layers: Use a needle to pass the thread through the holes in the plug. Leave 4-5 inches of thread ends. You can clean it up with a rubber band or something to make it manageable: Now contact cement the plug into the hole your carved into the back of the piece: Looking good after some flattening Now I prepare it by applying shelf liner to the back then leave some weight on it to keep it flat overnight. Tomorrow I will continue with the tooling stage and finish trimming it all nice...
