Everything posted by Big Papa Leather
The head on mine is 2" diameter and 2.25" in length. I am going to pick up some more at the local plastic shop prolly next week. Interstate plastic is the name. Interstate has alot of locations search them on google and see if one is close to you. I intend to try and make few more. Allen
I found several references to removing chrome from metal. I have not tried these and can not vouch for them. I am only providing the information. The procedure is very much the same as removing rust but with different chemical. First, degrease completely and scrub thoroughly with detergent. Mix 1 cup of Muriatic acid with 3 gallons of water in a plastic bucket. NOTE; ALWAYS ADD ACID TO WATER. NEVER WATER TO ACID !!! (It WILL explode) Hang two or three copper wires (#12 or larger) around sides of bucket. Connect these to ground of battery charger. Hang item to be de-chromed in fluid with positive lead connected. Be sure part doesn't touch ground wires. Within a few seconds or minutes, depending on thickness of chrome, it should come clean. More or less time as required. When finished, wash parts in mild soda water solution to neutralize acid. (Do this right way to prevent rust) As with any caustic acid, handle with care. Again use at your own risk. Allen
I used stainless steel bolts and molded the bolt head with a belt sander. Once I got the shape I wanted I changed grit and polished up the newly shaped heads. I then used a dremel and the fiber cut off wheel to create the lines, on the other I used a diamond bit to add the holes or pebbles. When I was happy with the design I went back to the belt sander to polish the burrs away that were created by the dremel. Allen
These are a first attempt, so keep the laughter to a minimum! I used stainless steel bolts. One is a simple crossed line look, but it kind of looks like a spider web or similar to the "Bio-mech" look that is popular in tattoos. The second is similar but it has a pebble added. Now I just need to figure out what I want to do with them. Any comment or suggestions accepted. Thanks Allen
I took BearMan's inspiration and created my own lightweight maul. I used some Redheart wood and a 1X30 belt sander to shape the handle. The head is UHMW plastic rod 2" in diameter. The handle is much thicker than the BK maul I have. I like the BK maul and think it is a fine piece of work, but making my own was fun as well. I needed a drill press to drill the hole for the carriage bolt that runs through and connects the two pieces. It weighs in at 12.6 oz. I have only tested the maul on scrap but I am going to use it to make a project this weekend. It gave me ideas to make a heavier one. I am going to make another head that is hollow to allow the insertion of lead shot to create more weight. It may even give it a "dead blow" effect. The main problem I have is the plastic place requires a $25.00 minimum purchase. That will be a Huge amount of this stuff. I do not plan on going into production of these things so I might just revert to eBay to buy a smaller qty. So if you see Scissormedic bidding don't bid against me Let me know what you think, and again Bearman thanks for the inspiration! If anyone has any suggestions on the weighted head please let me know!
Hello again! I was also the one who got the "plate" made. It is the bulldog face below. The green imprint is from the plate using a 1 ton arbor press to apply pressure. I made the holder as a protector against dinking up the edges. It was the first time I wet formed a case/holster. The two impressions on the brown piece of leather are the makers stamps she did for me. Sorry my photography sucks. One is a heart with a dagger and the text "Big Papa Leather" on the banners that cross the heart. Brenda went the extra mile to make the lettering look right even though it is tiny. The second is a old school tattoo swallow and Big Papa Leather again. I blotted out the third makers stamp as she did not do that one. I am completely happy with the work she did and the effort she made to make sure it was just how I wanted it. I would recommend her (and have) to anyone looking to get stuff like this done. Allen
I have a source for a Consew 18 Machine. I know NOTHING about sewing machines. Would this be a good starter machine? Comes with a table and alot of accessories. I would not be doing tack or heavy stuff. Max would be maybe 8-9 oz and a thin liner. Book covers, maybe a wallet or business card case, belts with a lining. Everyday type stuff. Their asking price is $400.00 Any help? Or maybe this offer I got on a Juki # DDL-555 $400.00 Are they comparable or is neither one a good buy? Should I just forget both and look for something else? Thanks Allen
CD Case
Big Papa Leather replied to Butch's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
That looks great! Allen -
Hey all, I am interested in starting a collection of makers stamps and making a display for my workshop that I hope to start in the real near future. My idea is to swap imprints with whoever is interested. If you do not want one in return I would gladly take one from you if your willing to do it. I can send one to you via USPS with a self addressed stamped envelope enclosed so you are not out the cost of postage, or if you wish we can just trade addresses. I can be reached at scissormedic at gmail dot com off the board to prevent any addresses being posted online. Also I just cleaned my message box here so there is another avenue to trade addresses. Allen
I had her make me two. I will get them tomorrow. She (brenda) is great to work with and will go out of the way to help. Allen I'm not affiliated in any way other than a customer.
Lateral Cell Phone Case Pattern
Big Papa Leather replied to 99centtaco's topic in Patterns and Templates
Thanks 99centtaco! This is exactly what I was looking for. I am going to make one of these for my brother who just got an insulin pump. It is the size of a small cell phone and with the added tutorial you included makes it a perfect holster project! Allen -
Hair thingies
Big Papa Leather replied to howardb's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
HowardB said "Oh screw 'em. I'm too cool to care" That is funny. Also my motto. Allen -
Flask
Big Papa Leather replied to Big Papa Leather's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thanks Art, creepy was the point! TrooperChuck thanks for the reply. Allen -
It is also good for: Protecting yourself from dogs or other mean animals on a walk. Going to jail for an illegal weapon. Swatting mosquitoes on your friends head. Swatting mosquitoes on your not so friendly persons head. It very versatile! Allen
I made me a wallet. I have been wanting to do some old school tattoo type flash stuff and took the time yesterday to throw this together. I tried to make the artwork clean, yet unrefined. Sort of jailhouse/shipboard/ghetto tattoo look, but at the same time make it look good. I am a USN veteran of Desert Storm/Shield so the anchor is fitting The Swallow's banner bears my chicken scratched (intentionally made to look choppy) last name and the wifey, and kiddos initials in the heart. It is lined with a maroon bandanna. Pre-made black guts/interior. Sorry for the blurred photos, best I could get with the cell phone. My digital camera is acting up. Reason to go pick out a new one right? Allen
Hair thingies
Indy, Hobby Lobby has the hair barette clips. 3 Sizes too (I think 3, maybe two) But either way they have them in the jewelery section. Allen -
Anyone make a comfortable or semi-comfortable small of the back holster for a Glock 27? I had one that I misplaced and (just the holster) and do not know the maker. It was a gun show model. Anyway I am interested in getting one or if you willing to share a pattern I'd try my hand at making it. It is not something I think I'd do a lot of. Anyway any help is appreciated. Allen
I was wondering ya'lls opinion on the maker mark deal. Do you apply your mark to every item you make? For example, I have had some request for simple bracelets. Just quick simple carvings and such, but I have not been putting any identifying marks on them as they are small and the space is limited. How do you do it? Allen
Thanks ATX, Not sure that I'm ready for teaching. Still learning! Sorry I missed the airbrush question. Harbor Freight $14.00 one. Allen
The skull cloth is an Alexander Henry pattern. I got it along with a few other designs from a eBay auction/seller. I got this one, a skull and roses one and the background of old school tattoo designs as well. If you go to eBay and search tattoo fabric or rockabilly you will see many, or just search Alexander Henry. Allen
Here is a bunch of firsts for me. 1. Inlay or filigree or whatever it's called. It is snake skin remnant. 2. Two Tone double loop lacing. It was actually easier than I expected it to be. 3. I air brushed all the color. Including the flames. I tried to add a bit of Eco-flo smoke black to deepen the cuts on the back, but it ended up muting the color in the flames some. 4. Black and red skull fabric insert. Overall I am pleased with the outcome. The insert is a small 36 photo plastic photo album that I picked up at Hobby Lobby for $0.49 Now I need to go print up pictures of stuff and put it in the book. Allen
