Everything posted by Treesner
I'm in California so pretty far.. I saw a 86 on marketplace in my area, whats the difference between he 55 and 86
the cheap Chinese ones do have some leveling in the stamp area itself with the 4 bolts, kinda annoying but doable. mine does not have the springs as advertised here, I wonder if that works to self level the stamp as they are claiming it to work? I have to use quite a bit of force so I feel like I would end up just bottoming out the springs.. https://www.amazon.com/Upgraded-Stamping-Pressure-Base-Plate-Embossing/dp/B07H97H9RQ/ref=sr_1_1_sspa?crid=INNXX90SZVN6&keywords=foil+stamping+machine&qid=1686682812&sprefix=foil+stamping+machin%2Caps%2C184&sr=8-1-spons&ufe=app_do%3Aamzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzRTVYREYzWlhZQ0NBJmVuY3J5cHRlZElkPUEwMTU1MDY0MzBQOTIzTFY0SUs2VSZlbmNyeXB0ZWRBZElkPUExMDQ1NDg2MzFEOTlTNVpIVE5RUCZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
hey guys I have a cheap foil stamping machine and I'm trying to figure out a way to line up my straps to get them centered. I'm doing a diamond shape too so it makes it tricky not getting it crooked.. anyone have any tools or adjustable fences I could add found this XY drill fixture on amazon this machine has a cool looking guide Etsy I like that this has the clips to hold the work and the whole base slides in and out, expensive machine tho Etsy https://www.dreamfactorytools.com/products/stamping-machine?variant=31465078259756
just ordered this stool, well see if it gets under the stand and makes the machine easier to use https://www.amazon.com/gp/product/B0936KDWRX/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 also I bought a new chain from home depot and easily made the left pedal the up/down presser foot and the right pedal the throttle. what do you use those for?instead of the casters so its lower? not following
oh yeah a stool like that would be closer for sure
hey thanks I didnt think about just moving the entire pole, that would probably be the easiest however I did measure and I have to sit 14" closer to get where I want, if I move my post all the way to the edge that would get me 8" closer and I'm not sure if having it way over on that edge would be out of balance or not, at least the motor is mounted behind the machine to help counter weight it I guess I think I can cut the post on the pedals down to make it narrower and squeeze in more only thing is, drilling through this super rethink steel plate is going to be hard with a hand drill I bet!
I think I can actually just switch the throttle bar and get a longer chain to switch pedals I modded it and the presser foot works at a diagonal like this
glad I'm not the only one annoyed with this setup can you send some photos I dont know what an off the arm table is
this is what I think would make it better
this is what the u table looks like
hey guys I recently got a artisan sewing machine and opted for the pedastol style table as I thought it would take up less space in the shop however I'm finding it a little awkward. I can't really get a chair close to it because the legs hit the base.. I was short of thinking about cutting a notch in the base so the chair leg could squeeze in but I noticed that if I sit non the edge of my chair to get closer to the machine then my feet are in an awkward position like the pedal would need to be moved back I wonder if I could drill new holes and mount the machine closer to the edge of the table? the other thing that I dont understand is do you use your left foot as the sewing and right as the presser foot lifters? or do you switch feet? ideally it would just have the side leg thing like some of the other machines have but I'm not sure that could be fitted or not. could I switch the pedals so left was presser and right was speed? I feel like I need my right to have more control over the speed where left is just up/down so finessee does not matter
found this one, is 450$ but would be pretty easy to mod something similar DIY with angle grinder I would think https://www.woodysrocks.com/store/p142/1_Ton_Arbor_Press.html#/
magnet is an interesting idea, if figured it would just break the magnet under the pressure but looks like its working of setting snaps for him
do you think 150 pound press is enough for stamping leather with a 1.5x1.5 stamp and cutting slots and holes though leather? this K+M one is pretty tall and have an extra long feature as well https://kmshooting.com/product/arbor-press/
the guy who makes the chuck recommends this press but its a 3 ton so pretty expensive Baileigh press brakes are very nice and an excellent bang for the buck with lots of room under the ram: https://www.baileigh.com/metalworking/presses/arbor-press Here's a demo video of the 1/2" chuck tool used in a Baileigh AP-3R 3-ton arbor press: https://www.youtube.com/watch?v=qNE9S-ZjOW4 also for reference The 1/2" chuck with the magnetic back plate is 2.9" high
I think I would be cutting strap ends, cutting slots and hole and stamping logos. don't have compressed air in the leather area but interesting solution do you have a photo I don't follow
anyone know of an arbor press with higher clearance than normal? I dont really need something much stronger than 1/2-1ton as I'd like to use one of these magnetic chucks to hold different leather tools/stamps https://www.mathews-engineering.com/store/p15/Arbor_Press_Magnetic_Pin_Press_1%2F2"_Chuck_Tool.html it seems like the 2 ton presses might be tall enough to accept the chuck and the tool but they are more money/larger/heavier so wondering if you know of another option
I was originally thinking of trying to convert my hiker press that can take 3/8" post accessories so I would have to find slot cutters/strap cutters to fit in 3/8 or have someone turn mine down then just making a wide bottoms plate that goes in 3/8 or 13/16 lower hole that would give much more leverage for stamping and cutting but not as nice as the drill press chuck for random jobs and not as much vertical space the craftool and same looking but more expensive tandypro is similar, has a nicer adjustable bed for when stamping and they make a few hole cutters I'm not sure what size their attachments are, it looks like some are 3/8 but others look really big like this adjustable tube punch https://tandyleather.com/products/press-die-for-hand-press-round-tube-punches
yeah doesn't look to sturdy wonder if this Dremel brand one is a stronger https://www.amazon.com/Dremel-220-01-Station-MultiPro-Keyless/dp/B01MA36EDU/ref=sr_1_46?crid=O6A79K4QC49C&keywords=dealt%2Bdremil&qid=1643828992&sprefix=dealt%2Bdremil%2Caps%2C151&sr=8-46&th=1
anyone tried these cheap burnishers from amazon? I watched a YouTube review on one and he said it worked great. the other cheap option I've seen in the harbor freight polishing machine then attaching a wood burnisher and a sanding wheel which comes out to about the same price https://amzn.to/3s4Prin
Anyone used one of these hole punching presses? its got a drill press chuck on it so you can put different cutters in it that you already have. I think I would use it for strap end cutting, oblong slots and pressing logos in. I was planning to get a one ton arbor press but found this in the search which seems a little more useful with the chuck https://amzn.to/3IMwIi0 https://amzn.to/32RggxW
slightly different from he wood ones, maybe since its narrower it would get into the thin stuff better https://www.ivan.tw/products/craftplus-strip-ease?pr_prod_strat=copurchase&pr_rec_pid=6207456116931&pr_ref_pid=5017261637769&pr_seq=uniform
found this thread for cutting thin leather http://imgur.com/a/yswIR
these end cutters ate 5/16 they said, just under 3/8" so would probably work https://strapwarehouse.com/handyman-accessories-end-punches/
do these exposed blade strap cutters work better than the wood ones that go through the two slots? I'm having a hard time getting my thinner leathers through the wood one as you cant push them through as easy as something like a stiff veg tan https://www.amazon.com/OwnMy-Leather-Cutting-Cutter-Aluminium/dp/B0868B1N9S/ref=psdc_12897141_t3_B076B1WF9H
