Damas
Everything posted by Damas
132k5 Help needed to adjust clearance between needle and hook
Damas replied to Damas's topic in Leather Sewing Machines
@Constabulary Thanks, I am not sure I'll be able to apply heat in a good way, I'll be afraide to over heat. I did use a larger splint among all my different atempt, unfotunately with no luck... @RockyAussie That's definitely the easiest solution and I thank you for providing it ! I will use it in last resort because I don't feel very confortable with the idea of altering an oem part -
Dear @Constabulary, thank you for your help. I have done as you say and it does not help, that bushing still won't move. I put plenty of WD-40 on it, I used a brass tube to tap on it, no success. There is no collar on the left, no collar on the right, appart from the one at the other hand of the shaft, near the gears, see pic. But I believe this one is to prevent the shaft to move to the right. There is the shaft end, with the bushing once the hook is removed. That's the other end of the shaft, with a collar That's the right side of the bushing -
OK, I gave it a try and succesfully removed the bobbin case retainer ratchet, and that allow me to access to screw #4. Bu once untight, nothing moves... I don't know what to do next. I have gently tried to tap on it in order to unlock things but nothing moves... And I am scared to bend something if I go harder on it Is it supposed to slide, or unscrew ? I don't know how to move this bushing... -
Thank you @CowboyBob, I'll try that ! -
It's me again. I could not resist and brought home that old lady from 1925. I found very few litterature on 132k5. I have a 132k10 so I have been able to compare and there's very little difference between them. Hook and shuttle are different, even if based on the same system. I am having a hard time with it. I followed the attached, in order to time the machine and I have been able to moove the hook so it meets the needle at the right place, on the right time. But, needle is too close from hook and is pushed every time the hook is passing by. I need to move it to the right in order to have enough clearance between needle and hook. I just can not figure out how to do that. I can move it to the left, but I did not found a way to move it to the right. English is not my mother tongue and the following instructions aren't clear enough for me to succeed... Can someone here help me ?
Left Stand Singer 45K Variant → Singer 145K1
Damas replied to Constabulary's topic in Leather Sewing Machines
Dear @Constabulary this post is so interesting ! it’ll be great if you could do, one day, a step by step tutorial to unmount and remount a 45k. Unless such thing already exists ? I fear to do it by myself, I am so scared I will never be able to reassemble it… By the way, I have to post about my mistery 45k mill machine (darning) : it has a feed mechanism and a stitch lenght adjuster even if there is actually no feed dog. The serial is not a Singer one, neither the plate. But parts are definitely Simanco I think it might interest you and probably @Jimmy too -
DIY Electric Bobbin Winder - Singer 111 and 45K Type Bobbins
Brilliant ! @SARK9 could you please explain the modified shaft, as it is not clear for me how to built it and how it works -
216X1 Needles - 214X1 Nedles - Whats The Difference?
Edit : I've redone my test because I realised that the Schmetz needle was not facing the hook... It was slightly turned (it probably moved when I secured the screw) and 214x2 needles are definitely working with 132K10 which is supposed to take 216x1 I have tested from 200 to 250 with success Smaller needles won't catch the thread but I guess this is normal, you're supposed to adjust hook/timing with such a difference in needle size. -
Hello All, OK, back to an old thread. If I am not wrong, 214x2 is similar to 214x1 but with leather point (LR) Well I tried both in my 132K10 and it does not work with 214x2... The hook does not catch the needle thread. I did photos to compare, needles'top anatomy does not look similar at all Singer original on the right - It is shorter - playing with the needle bar height won't help -
An Introduction to the Pfaff Numbering System
Damas replied to Uwe's topic in Leather Sewing Machines
Hello, Anyone ? I am about to order some needles but I am not sure what maximum size I can take, regarding this unusual serial number. Do I have to take that B letter as the model reference ? -
Hello, I recently came across this antique Pfaff 142 and took it back home. I wonder what its letters/numbers mean : 142VR113B S https://photos.app.goo.gl/xnnnqCA96Wn1wyBL9 -
Hurray ! She's fixed ! After having replaced screws and shuttle, I finally succeeded in timing the 45K25, she is now working like a charm ! I am so happy ! Thank you All for your help and support, and for the fabulous information I always find here !
@Constabulary Thank you very much ! I will, in case the screws I have oredered locally does not fit on the machine. I will keep the post updated because anyway I still have my timing issue.
@jimi you’re the best ! #453 is the one ! Thank you very much !
@shoepatcher When you say screws are available in generic, would you please provide a link so I could check the type of screw I have to look for here in Europe based on your link ? For the other screw, I unfortunatelly didn't succeed in finding it's part number... I hopefully found a local provider for the other parts (shuttle and foot) So I will update here when I'll get them
@jimi Thank you very much ! She's trully a beauty indeed ! I think you are right, it came with that foot mounted on it but I noticed it was different from the one usually seen on 45k and identitical to the one that was mounted on the 132k10 ! I am curently trying to get the right foot. That was the only foot that came with the machine. But I believe I will have the same timing problem with original foot, I think my needle is going far too low @shoepatcher Yes, definitely, these screws need a replacement. Original part number for needle bar clamping screws is #158 but I believe #145, #127 or #141 could also do the trick. I am having a hard time to find them somewhere in Europe... I am still trying to figure out what part number is the shuttle driver screw, because I have no blueprint for 45k25
The shuttle itself is damaged, I have ordered a new one. I made a video showing the issue with the presser foot up : https://photos.app.goo.gl/5SQ6Nz6mTpX5pRYU8
Dear All, I recently bought that machine (in a lot with the 132k10 I mentionned in another post) and I am having a hard time with it. I have a timing problem, which I tried to solve using the great following post : https://leatherworker.net/forum/topic/62477-directions-for-timing-a-singer-45k25/ I first tried to time it by moving the needle bar, but when done, I have two issues : - The hook seem a little bit too much far on the right of the neddle to catch the thread - The needle can not achieve a full revolution with the presser foot up : it's blocked in its way down, by the presser foot I then thought I need to move the shuttle in the right position by loosening the screw where the shuttle driver attaches to the back end of the shaft but I was not able to turn the shuttle by hand, it does not move at all Last but not least, both clamp screws and shuttle driver screw are in a very bad condition (head is damaged), making them hard to loosen or tie, making the whole process even much more complicated for me ! I guess someone else before tried hard to fix the machine and baddly damaged these screws Any clue where I could find spare screws in Europe ? Thank you very much for any help and support, I would really like to have this beauty back to work
Dear Constabulary, Thank you so much for your answer, I'll take a look at it. My K10 does not have the roller foot, so I guess it's not in its original setup. Here is a picture of the presser foot I bought the machine with :
Hello All, I just got this machine and I am having a hard time finding a user manual. Does anyone has it and willing to share ? This would be great ! Thank you very much
Hello Gregg, Thank you very much ! Very helpfull ! Hi Constabulary, very interesting but very high shipping costs for such small pieces (about 20€ !) I'll sure have to combine.. About servo, do you have any advice regarging it's size for this walking machine ? There is so many
Right, thank you, I'll do that straight away. I just need to find them... Hard to find mitsubishi parts
