bj139
Everything posted by bj139
43 second video . I like to keep my videos to 1 minute. I have a CLSP (Chinese Leather Shoe Patcher) and it sews fine. I fixed some of my shoes. I would buy it again.
Beautiful carving. You are an artist.
Thanks. I may try to get some system 190 needles and try it when I get time.
Thanks. One thing I don't have to worry about on the 111w155 is reverse. One good thing is stitch lengths are the same in forward and reverse once I turn the material.
I have just one application where I am trying to sew a layer of nylon seat belt webbing to 3 other layers of webbing that are 3/8" thick. The total might be 7/16" so I might be able to turn the handwheel by hand and sew it. For most other things I have been sewing 3/8" should be more than enough.
Why do the Singer specs say 1/2" presser foot lift? Is this just lift and not working height?
Can a longer needle be used and the needle bar moved up to re-time?
Kevlar has twice the thread strength of nylon or polyester for an equivalent size. I used V92 Kevlar to sew my tree saddle since I didn't want to fall out of a tree. With all the stitches in it I calculated the main seam would break at around 13,000 pounds. Cutting it with scissors is surprisingly difficult. Now I know why it is used in bulletproof vests.
Singer 111W155 presser foot adjustment
bj139 replied to Ole South's topic in Leather Sewing Machines
Here is this solid cardboard thickness I sewed. The servo motor had trouble sewing this but I helped with the handwheel. A larger handwheel would work better. I tried pushing another layer of cardboard under the foot but no go. -
I know this is an old thread but searching for 111w155 foot lift led me here. Isn't the maximum foot lift limited by the needle bar coming down and hitting the top of the foot? I have mine adjusted so I can fit about 7/16" of material under the foot and the needle bar comes down and barely touches the top of the foot. I don't know if sewing 1/2" is possible because of the needle bar hitting the foot. It looks like I am getting a tiny bit less than 4 SPI at maximum stitch length. -
I waited and a Singer 111W155 showed up. I bought it for $175. Can this sew 1/2 inch? This one feels pretty tight. It was used in a one person shop to do upholstery.
I just checked and it is Cutex that has the complete knee lift not Sharpsewing. Is this the roller you were talking about? I think this knee lifter might work on my Mercury M-337 since it has a straight rod pointed down to activate the foot lift. I might as well order 2 rollers for the Mercury and the 111. https://www.ebay.com/itm/402941886480?hash=item5dd1354010:g:oJkAAOSwiHJg01cd
In the picture from Sharpsewing, isn't it assembled incorrectly? I recently bought a 111W155 without a table and now I need to get a knee lift. The one from my Singer 95-40 gets in the way of the undercarriage of the 111 so I can't use that one on my table. I've found that Sharpsewing seems to be the only place that has them in stock. I need to figure out how to install it since I doubt instructions are included. It seems to be a different design than most.
There is a breaking strength to thread which you may be exceeding with the thickness you are sewing. Have you tried V92 thread?
- 4 replies
- tension problem
- leather sewing machines
- (and 2 more)
I will call before I order to verify.
Thanks, kgg. I have a feeling most people here would have the same advice. The resale part seems important as well as parts availability. Are all Juki dnu-1541s made in Japan?
The beauty of this is they are the same price. The Thor has the extra tension assembly and the easy walking foot height adjustment.
I just called Keystone Sewing Machine Company to ask about a Juki and the message said they are on vacation until August 16 and will not be checking messages.
I have been looking at a 1541 type machine for a few months. The price of the head only, which is all I want, appears to be the same for the Juki or the Thor. Which one should I get? I thought I should get the version with the safety clutch on the hook shaft. Is this a good idea?
I did send an email to Greg at Keystone sewing back in May and got no reply. i just found out today he passed away in March. I understand now. So sad. His email address still shows up on the website. Are they still in business?
Sorry to hear of his death. So young.
$18 for the pulley is a cost effective way of getting slower speeds. My reaction time is quick enough for this lightning speed setup.
Need Help with new Servo Motor install and Needle Positioner!
bj139 replied to DustyBench's topic in Leather Sewing Machines
Mine has always turned a few revolutions on startup. I thought it was a feature. -
I'm pretty sure both were run at minimum speed for that motor. Both are slow enough for me I think. I have to get some leather to try. Are they really different? I don't see it.
Need help threading Brother machine
bj139 replied to rivercityleather's topic in Leather Sewing Machines
Maybe a brazing project?
