Gosut
Everything posted by Gosut
	I did on my first two projects, one of them stitching together a belt keeper. Since then, I place the needles a little less than a quarter of the way from the ends of the thread and allow it to slip through as needed as I stitch. It makes a lot of thread to pull through the hole, but i don't have to contend with pulling a long length of thread at the start of the stitching. That said, for a small project without an unwieldy amount of thread, I'd probably lock down the thread.
Beveling edges - I just keep getting worse at it, and it ruins my projects
Gosut replied to Toffe's topic in Getting Started
It's the right way up, but from the scratch marks in the photo, it looks like one side is resting on the leather. The beveler should rest so that the groove in the tool is 45 degrees to the surface. In the photo, it looks as though it's not. A beveler cuts off the corner of the edge, so that's how you want to turn the tool. You shouldn't have to press down on it, just glide the beveler over the corner. -
	Around here they go by the name monument companies. Usually it's grave slabs and tombstones, but they also do all sort of monuments.
	Nearest one is a good distance away, though I drive past for a doctor's appointment (typical old age stuff, nothing serious). Monument companies are easier, with two fairly close. Have been thinking about talking to them.
	Thanks all. What I was considering was that if it's the mass that helps, then I could use any similar rigid mass for punching, snaps, and rivets as long as I cover the surface. In particular is a cheap patio stone, which are made of concrete. Note that the leather wouldn't go directly onto the concrete, but on an old magazine, which I'm already placing under it. Possible drawbacks are the potential of a concrete "stone" breaking and would have to put something under it to prevent marring the work surface as well as on top of it. Before anyone points it out, this is one of those ideas that could easily turn into spending ten dollars to save one, all for a work surface that's not fit to tool on.
	I know this is a stupid question, but what is the purpose of a stone slab? For tooling, I can see the advantage of having a hard, smooth, surface. Other than that, is it to provide a rigid mass so that the work surface doesn't deform, allowing more of the energy from the mallet or maul to be applied to the piece?
	I was going to take a photo of the snaps on the old belt, then found them on the Tandy Leather site. Their Segma snaps are exactly the same. Weaver Leather Supply has a similar Segma snap. Not trying to make any converts here, just pointing them out for anyone curious to what was on that old belt. I like the idea of Chicago screws. It would serve the same purpose of allowing to change the buckle. It's perhaps worth noting that I can only find snaps on my oldest belts. The later ones sew the flap down.
	That's the ferrous acetate solution I made months ago. I strained and poured the finished solution into an airtight plastic bottle and ended up with only some precipitation. Used it on January 1, 2024, and pouring let in enough oxygen that the solution turned a dark red. Nothing to do but to discard. I like vinegaroon, though. Am thinking about making it as needed instead of making up a batch and storing it.
	Thanks, all. I hadn't considered Chicago screws. The whole point of snaps is to allow changing the buckle, and Chicago screws would do that just fine. Last year I first used rivets, but was getting dye from somewhere in the buckle end and ended up boring them out and dunking in M&G. Went back with snaps. I did have a problem with the snaps coming loose, but attributed it to them being cheap snaps. Ended up fiddling with the wire in the socket that grabs the stud and that helped.
	Found an old belt that got stuck behind something. These days I look at worn out belts and think "Hardware!" but in this instance I paid attention to the snaps holding the keeper and buckle flap in place. Last year I had bought some cheap snaps, and when I used them on a belt, the rims on the inside part of the post and socket created a gap. These snaps didn't. They're segma type snaps, but sit perfectly flush. The socket doesn't even have a rim, just a series of splits in the side to hold the socket in place, with the post fitting inside, maybe all the way into the cap. The belt snaps were also smaller diameter than I remember. Is is possible to find a snap that allows a flush fit? The segma line snaps at Tandy seem to have a thin rim. Would that give the same flush fit?
	The vinegaroon worked beautifully. The M&G did as well. It's my stitching that stinks. I had a gray thread on hand that I thought would work well. Not top name, but good enough. It was passable, but the light gray against black highlighted every flaw, and there were plenty of them. The first I noticed was stitching up the checkbook cover. I had given it three coats of a 50/50 solution of M&G and water, and had set the holes prior to the vinegaroon. There was enough acrylic in the holes that I had to run a regular awl through them, but i can't blame the stitching on that. The punch side wasn't so bad. The underside, though, had several places out of line. Honestly, I didn't do that bad on my first project. The leather pouch for a whetrock was worse. Okay, so it was simply to protect a small hard Arkansas stone, and only tried dyeing it as a test. Instead of M&G, I stopped after my usual two light applications of neatsfoot oil. Once again, used the gray thread. The stitching is horrible, the worst I've ever done. The pouch was tight and I cased it to fit the stone, but had punched the holes first because precisely because I feared I couldn't keep them aligned. How bad are they? I had planned to photograph and post on the board because of how well the vinegaroon turned out, but the stitching on both are so bad I'm ashamed to show them in public. Sigh. I thought we were supposed to get getter with experience. I know the problem was in the angle of the chisel, but I though I had this down. The best thing I can say is neither one were gifts. No one has to see them.
	It's possible that it wasn't strong enough. Another possibility is the tannins in the leather. On New Year's Day, I used vinegaroon I had made over several days back in the summer, but prior to use I dunked the leather in black tea and let it stay a few minutes to add tannins. Then I dunked it in vinegaroon, then, when it was nice and black (less than half an hour), removed, gave it a baking soda bath, then rinsed and put it back in the tea for a short soak, then rinsed again. Based on comments on the forum, the next time I use vinegaroon, I think I'll not bother with the baking soda. The idea of the baking soda is to remove free acetic acid in the vinegaroon that's left in the leather, but it will also remove any tannins left. What's going on is that the iron and the vinegar form ferrous acetate, which reacts with tannic acid to produce black. That's why I gave it a short soak in tea before and after. There has to be enough ferrous acetate to react with the tannins, and enough tannins for the ferrous acetate to react with. My guess is that 20 hours didn't produce enough ferrous acetate, but that's just a guess.
- 54 replies
- vinegaroon
 - roon
 - (and 10 more)
	Used it tonight, in a 50/50 dilution. I first used it on a belt that had a bleed through issue I couldn't nail down. Removed the rivets and dipped the entire thing a total of three times, drying in between. The only drawback was I had already used Resolene (tm), and the final result was fine "crackles" that can be felt but not visible. Pretty sure that's a case of over-application, but wanted to stop the bleed through This time I used it on a vinegaroon dyed checkbook cover. I did the dip method again. Anticipated streaking, and had a section of sponge moistened in the solution and wiped it clear. When it dried sufficiently, noticed there was still light streaking, but it buffed out. Has I not been wanting to make sure the inside of the pockets were sealed, wouldn't have dipped it. This cover will be subject to sweat, and wanted to make sure everything is sealed.
	I don't know if a baking soda rinse is necessary or not. Have read some comments by those who do and comments by those who don't. The pamphlet I read on home tanning did not mention a baking soda rinse, only following a dunk in the veg tan bath after the vinegaroon. I was hedging my bets, so to speak, with the initial soak in black tea, then a final soak in tea before the last rinse.
	I had planned to leave the whetrock pouch be after a short soak in the tea and a rinse, Just oil it and let it go, as you suggest. Unfortunately, I somehow got a little vinegaroon on my thumb, and when I rinsed the whetrock pouch, there was part of my thumb print. The pouch is just to protect the whetrock, so I was about to leave it be, then decided to dye it black to cover it. A little vinegaroon, a short soak, and it was done. Rinse with a baking soda solution, then soaked in tea again, then a final rinse. Unfortunately, with all that soaking, the molded pocket went away. Wrapped the whetrock in plastic cling wrap and reformed the pocket. It's drying as we speak After removing the checkbook cover from the vinegaroon, I rinsed, then poured the baking soda solution left over from the whetrock pouch failure into the bag. Let it soak a little,l then removed, rinsed, and set it soak a short time in the tea. Rinsed and wiped off the excess, but feared it was still drippy. It was a sunny day above freezing with a light to moderate breeze, so I hung it outside in the sunshine. Black color + sunny day + wind let it dry out in an incredibly short time. The resulting leather was stiff, but seemed no stiffer than the whetrock pouch was after it dryed after casing. Have applied a light coat of neatsfoot oil and have it hanging inside to make sure it's all absorbed. That light coat has helped the stiffness. So far I'm very pleased with the vinegaroon. That could change, but right now I really like it.
	With two minor projects, a whetrock pouch and yet another checkbook cover, I wanted to try something new. The whetrock pouch is made from scrap and is for a hard Arkansas stone about the size of a small whetrock. The plastic case for it shattered decades ago, and I happened to look at it last week and think "Hey, I can make a pouch out of scrap for it." Though I used another as a pattern, the leather was so tight I ended up casing it after gluing. That worked surprisingly well. Instead of leaving it natural, I decided to try baking soda to turn it brown. That worked with a test piece of scrap last year, so I wanted to see how it went. I had already planned to used the vinegaroon I made last year for the checkbook cover. The test scrap I dyed with it turned out well, so I was optimistic. For both, I steeped some store brand decaffeinated black tea and let cool. I dunked both in separate containers (store brand ziplock bags that leaked slightly) for about ten to fifteen minutes. The whetrock pouch I put in a near saturated solution of baking soda and water. The checkbook cover got the vinegaroon treatment. Both are in different ziplock bags than I used for the tea treatment. The baking soda is a surprising disappointment. After about a half hour, the leather has shown little to no darkening. The vinegaroon started to work before I sealed the bag, The checkbook cover is currently a nice solid black. Both the whetrock pouch and the vinegaroon will go back into the tea. I read a pamphlet on home leather tanning that suggested returning leather to tannic acid soak after the vinegaroon, so I'm wondering if the tannic acid will react with the remaining baking soda and ferrous acetate in the leather. I did see a pamphlet on home leather tanning that recommended this for vinegaroon, so it's not an original idea. May rinse the checkbook cover first in a solution of baking soda to neutralize any free vinegar. At least I know not to rely on baking soda for brown.
Preventing Stuck Glue Lids
Gosut replied to Gosut's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Will have to try that. I have the same problem with PVC cement. Acetone sounds like a good idea. I wiped the threads down dry, but there's likely still a residue. -
It's contact cement. Have tried channel-locks, but didn't really "shut down" on it from fear of crushing the top. Will have to try again. -
	Have just finished gluing up two minor projects and the issue of stuck glue lids. I have one from earlier this year that I cannot open. I had to use a new one, and I've tried to clean glue off the screw threads with a disposable shop towel, but I'm not optimistic. I had stored the older can upside down, but don't think that helped. Does anyone have a solution? I hate wasting glue.
Leather Holsters and Striker Fired Pistols
Gosut replied to Gosut's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I don't remember the model, if I even noticed. Only know that it was a Glock and had the type of safety that runs down the middle of the trigger. -
Not really a soap box and all good info. FWIW, grew up keeping the finger outside the trigger guard until ready to fire. Walking around with the finger inside the trigger guard is an accident waiting to happen. -
The trigger pull is also a lot less in a striker fired handgun, or at least it was in the Glock I shot. The stiffest I've encountered is in double action revolvers. These are revolvers that rotate the cylinder and cocks the firearm and fires when you simply pull the trigger. This revolver also worked single-action. This is when you pull back on the hammer with your thumb, which also rotates the cylinder, then pull the trigger to fire. Single action in that revolver had a lower pull than double action, but the pull on the Glock was less than both. My firearm knowledge is limited, but I haven't encountered a revolver with a safety. That's a button or small lever you have to push or slide to enable the firearm to fire. Some semi-automatic pistols have safeties. The Glock safety is built into the trigger, hence my concern. Not trying to start a safety / no safety debate. The take-away on safeties on pistols is if the lack of one makes the shooter uncomfortable, then the shooter shouldn't buy a pistol that doesn't have one. FWIW, I liked shooting that Glock, so it's really just a holster question with me. The holsters that day were Kydex (tm) and a leather pancake. I didn't have a chance to to examine the leather one. -
	A short while ago, I had the opportunity to shoot a Glock. That had me thinking about holsters for that type. What gives me pause is the safety is built into the trigger. That has me thinking a holster must be ridged and completely cover the trigger area, as well has have good retention (strap or otherwise). There's a certain incident that made the rounds of an accidental discharge where the top of the holster folded over and caught the trigger. Obviously, the leather can't be that soft,. But is leather for a striker fired pistol holster just not a good idea? Is there some way to eliminate risks? For instance, is "boiled leather" for a holster an option, or would it soften over time and exposure to sweat and the elements? Is there a way to form and incorporate a rigid metal support for the opening of the holster? Is there some other way entirely? Just curious.
	That's a good idea. Will try that. Thanks.
	Have recently been involved in repairing the controls of two identical power recliners. I happened to have the original part number for the control, and ordered one to make sure it was the right one before ordering two. Good thing: It was the right part, but a previous "repair" had destroyed the connectors to the seat and back massage motors. The seat massage motor wire may even be cut. Whoever worked on this installed a control that let the chair up and down, noting more, and didn't bother unscrewing the control box from the side of the chair - just cut the wires and left it in place. I can sort of understand that part, especially if the plan was to install the proper control later, but not what was done to the wires to the seat and back massage motors. Installed the control I ordered on the other power recliner and got it going. The wires were intact on that one so it was a simple replacement. Have ordered a different control for the other chair that will allow it to raise and lower, but would like to do a full repair. The problem is the cable plugs / sockets have stumped me. They are rectangular, two-wire, with one socket round and the other "D" shaped. They seem common among power recliner remotes, but haven't been able to find them. Plan B calls for replacing them with a plug / sockets I can find locally, but that also means doing the same with the proper control unit. Would really like to get it back the way it was. Any suggestions? A huge problem is I don't know exactly what the plugs /sockets are called. They may be AMP Mini-Fit, Jr 2-Way connectors, but I don't know. Thanks. PS: Gripe Ahead. I really don't understand the butchered wiring on one of the chairs. There was no call for it. I can understand using a "get by" control to make the raise / lower part operational, but not what was done to the wires to the massage motors. Whomever worked on the second didn't have a 100% compatible control, but at least didn't cut the massage motor wires. That's how it should be done.
