Gosut
Everything posted by Gosut
The third coat dried quickly in the heat, and found a can of Kiwi Wet Pruf paste in the shoeshine box. It's older than the now-grown children, and only a little around the edge of the can, but it was still pliable and looked and felt like it had beeswax. Buffed the belt, then applied the paste, rubbing it in and then buffing. Whether from age or ingredients, the paste felt tacky like beeswax. Had no dye rub-off. Given the amount of acrylic on it, thought the surface might crackle under bending, but it didn't. Due to the acrylic, applying the paste may have been wasted effort, but it's done. Used cheap snaps that I had on hand instead of rivets. The snaps aren't holding as well as I like, but then again, they are cheap snaps. Wore it a few hours without rub off or bleed through, but that's not like wearing it all day.
The dye was Fiebing's Pro Dye Dark Brown. I've used it to good effect on a gift checkbook cover, sealed with Resoline, but it's not exposed to moisture. I put the third coat on maybe 20 minutes ago. One advantage of sunny hot weather is that things dry quickly outside. Brought it in for the evening, and it was maybe 90% dry after just an hour. Let it dry overnight, then gave it another dunking. Once again, I had some dye bleed into the solution, about as much as with the first dunking. I don't think continued dunkings will do much good. The mystery is that I'm getting none from the keeper, made from the same leather, with the same dye and sealant. The bleeding is coming from the belt. Looked for Sno-Seal (tm) yesterday, but, not surprisingly, found none locally. Not much snow here, but plenty of hot and humid weather. May try neutral shoe polish. The acrylic will act as a barrier, but have to try something.
Keeping on the side of caution. Some companies are sensitive to how you use their product names, lest it become used as a generic reference. Classic example is Aspirin, which was Bayer's trade name for the medicine. Another is Kimberly-Clark's facial tissue, Kleenex (tm). Kimberly -Clark used to run polite ads in at least one writing magazine reminding authors to use the term facial tissue for the generic product, and (hazy memory here), Kleenex (tm) facial tissue if they needed to mention the specific product.
I'm still around, just busy and having to spend money on other things. This goes back to a belt project several months ago. I did three coats of 50/50 Resolene (tm) and water with a sponge, drying between coats and getting some resistance to absorption on the third coat. However, after wearing it maybe twice, I got signs of dye bleeding in the buckle area. I removed the rivets and trimmed out the length of the slot to better accommodate the buckle, but then stopped, uncertain of how to proceed. I have plenty of Resolene (tm) for sponge application but not enough for dipping, which I wanted to try. Alternative was to try Mop & Glo (tm) cut 50/50, but it doesn't seem to be available locally. Yesterday was buying mower blades in a big hardware store some distance away when I thought about Mop & Glo (tm). They had it, got a bottle, and this morning put just shy of 3 ounces (88 ml) Mop & Glo (tm) and water in a gallon zip-lock bag and dunked the belt. Did the keeper first, dunking and placing it on a wire hanger outside, then loosely rolled and dunked the belt. I planned to reuse the solution for subsequent dunks, but I immediately had bleeding into the solution. I hadn't sealed the belt properly with Resolene (tm). Didn't time it, but I closed the bag and sloshed the solution thoroughly on the belts to be sure all parts were exposed, then removed and placed on a wire hanger. Finished by wiping down both the keeper and the belt with a disposable shop towel. The solution I discarded lest I end up depositing dye on top of subsequent coats. Checked on the belt a few minutes ago and found no streaking. I'm baffled as to what I did wrong with the Resolene (tm). Made sure all parts of the belt were covered and used a cotton swab to apply it in the holes and slot. Some was cut away when I lengthened the slot, but it also cut away the dyed exterior. The plan is now is to see if I get bleed-off in subsequent dunks. If I still do after the third, not sure what to do.
Maybe. It would be interesting to see if a pattern could be imprinted on it in the press portion. But my skills aren't up to carving and tooling leather. My main interest is puncture resistance. Had a inside waistband carry idea, then the damaged sheath on a cheap Fairbairn-Sykes knock-off reminded me that it can easily puncture leather, and that's not a good thing to have near the femoral artery as the sheath moves in clothing. Kydex of sufficient thickness should have puncture resistance. The only possible leather option I could come up with is to harden leather, and I'm not sure how puncture resistant that would be.
...That I like leatherworking, but thinking of doing a sheath in Kydex?
Reasonable expectations to the life of a leather item
Gosut replied to nstarleather's topic in Leatherwork Conversation
Strictly as a user of leather goods, the wear and tear on leather seems heavily dependent on customer care. I've seen a WWI US Calvary saddle that was heavily used in civilian hands that was in good shape after a century. Our family no longer has the mule harnesses because they deteriorated long ago. The leather on shoes much younger than that gave up the ghost, but most of these were work shoes subjected to hog lots. My grandfather's razor strop is still around, but would be reluctant to strop a blade on it due to its fragility. Let's say someone offers a century guarantee. After a year they get a claim because someone didn't take proper care of the item. Then what? Say "This is due to your negligence," which is the truth, but is likely to get the complaint going that you don't honor your guarantee? Replace it no questions asked, then end up hemorrhaging time and money with questionable claims? -
Not picking on Vinegaroon here. Dunk regular tanned leather in water, and it will bleed. Have discolored socks over the years that attest to this. I had hopes for vinegaroon, though, given it turns leather black through a chemical reaction. I tested it on a scrap that turned as black as coal, neutralized it with water and baking soda, and noticed some bleeding. Rinsed and resoaked with more bleeding. Placed it on a folded paper towel, and it wicked away bleeding. At this point I allowed it to dry and soaked it in steeped tea to add back tannins destroyed by the baking soda, then rinsed and soak. Had bleeding, but it could have been from the tea. Rinsed and soaked again, with more bleeding. At this point I stopped and allowed the scrap to dry. At no point prior to exposure to water did the scrap display rub off. It's only on exposure to water. Is there a way to prevent bleeding? My concern is sweat. I know I 've had belts over the years that got throughly soaked in sweat and didn't bleed, but I assume they were chrome tanned. Then again, there's my experience with boots and shoes.
Interesting. This tannery seems to use a combination chrome / veg tan process. They didn't show them breaking the hides. Does that mean chrome tanned hided don't need breaking? Sticking the hides to glass looks like an clever way around tacking a hide to a board or lacing it to a frame during drying.
Was surprised to find the orange ring is gone this morning. The liquid is still pale yellow, cloudy with a white precipitate. There is white precipitate at the bottom. The bottle showed more bending inwards, but it's also about 30° F / 17° C cooler. It seems to imply a change to maybe ferric acetate, but then to something else. Since most of the things in the bottle are iron, acetic acid, water, and oxygen, whatever is going on has to involve iron, carbon, hydrogen, and oxygen. That limits the possibilities. Though not part of the experiment, I did neutralize the free acetic acid in the test strip. Also discovered the black color bleeds. Since it's a test strip, need to just let it soak in water to see if it reaches a point where the bleeding stops, and, if so, if the leather is any less black.
Mine is headed that way. The orange is a ring around the top. When I gently shook it this evening, there was a rain of white precipitate from the top. Interesting, the plastic 2 liter soft drink bottle has the sides bending inwards, as though the air at the top is less Temperature is about the same as yesterday, as is the barometric pressure.. My assumption is this is some sort of oxidation. Whatever it is, it's combining with something in the air.
I thought it was at an end. The vinegaroon now has a layer of orange floating and seemingly slowly descending from the surface. I suspect this is oxidation. It also had a white precipitate in the bottom. I suspect it has to do with pouring it through the coffee filter, either some sort of oxidation reaction or with the filter itself. Again, it was clear before I poured it. Will watch it, but in the future, would rather make it as needed than make a large batch and have it go bad.
Have made a grand total of two. One was more of a quarterstaff than a walking stick and broke. The other, in my teens, was closer to a small fence post. These days I prefer an eye hoe handle. These are 54" / 1.37m long and maybe 1.25": / 3.175 cm in diameter. I put a rubber non-slip chair leg cover on my latest, to protect the end.
Finally, an End to It The test scrap is dry and is as black as coal. May try neutralizing the free acetic acid in a solution of baking soda, followed by a dunk in some tea to replace lost tannins, followed by a rinse. Don’t know. Will be subjecting it to some bleed tests, to see if any of the black seeps out when the leather is wet. That’s beyond the scope of this topic. I went back over the calculations from scratch and came away even more confused. My first set of calculation may be the closest to correct. Here’s why: Once again, the formula for iron and acetic acid is Fe + 2(CH300H) = Fe(CH302)2 + H2. This means that it takes 1 iron to react with 2 acetic acids to make 1 ferrous acetate and 2 hydrogens. Chemistry uses moles to make calculations more convenient, so we can say it takes 1 mole iron to 2 moles acetic acid to make 1 mole ferrous acetate and 2 hydrogen. A mole of iron is 55.845g and 2 of acetic acid is 2 x 60.052 = 120.104g. I first figured the amount of acetic acid in vinegar by reading an FDA regulation and assuming acidity is by weight / volume. Liquid acetic acid has a density close to that of water, 1.049g/ml, though. If we work it out with acidity as volume / volume, then 5% acidity for 1000 ml = 50 ml acetic to 950ml water. So, 50ml x 1.049 = 52.45g per 1000 ml. 52.45g / 60.052g/mole = 0.873 moles acetic acid. If we have 0.873 moles acetic acid per liter of vinegar, then that would react with 0.873 / 2 moles iron = 0.437 moles iron. 0.437 x 55.845g = 24.404g iron per liter of vinegar. For two liters 5% acidity white vinegar, 24.404 x 2 iron is needed = 48.404g. This is close to where I started. As a quick check, the ratio of iron to acetic acid is 55.845/120.104 = 0.465 x grams of acetic acid. For 104.9g acetic acid, we would need 104.9g x 0.465 of iron = 48.779g. That means 48.404g is in the right neighborhood. This means my 49g of iron wasn’t way too much after all. But it also means that in two weeks a significant amount remained. That meant there was very little ferrous acetate in the solution I poured into another bottle. It also means that it takes very little ferrous acetate to react with tannic acid to give that nice black color, and that there’s an awful lot of free acetic acid in the solution. There are some other things I want to try, but this experiment is at an end. It’s also a failure, in how much iron is needed to react with all the acetic acid. That went off the rails when it pushed vinegar out the vent cap and I started topping it off. At best this is a learning experience in how not to do this sort of experiment. It also suggests that the iron should be well below the surface of the solution to prevent oxidation.
This afternoon noticed the steel wool floating and the neck was free of liquid. Went ahead and poured. The liquid in the bottle was clear, the steel wool gray. I poured it into another 2 liter soda bottle, using a coffee filter and a funnel. Toward the end, the filter had picked up enough steel wool particulates that I had to change it. Think this was off the steel wool itself. Pouring the vinegaroon took about half an hour. During this time I poured a small unfiltered bit in a quart ziplock bag, just enough to cover a scrap of 3 oz veg tan on both sides. Let it sit while I finished. I was nearing the end when I noticed the bottle, now filled mostly with steel wool and a little liquid, felt warm. Wondered if it was my imagination. Set it down while liquid filtered into the second bottle and picked it up again. It wasn't my imagination. There was a definite warmth. Not good. Fortunately, I was just about done and I when finished, I cut open the bottle (wearing vinyl gloves for all this) and removed the steel wool. There were clear signs of rusting that had not been there before I started pouring. It had oxidized that quickly in air and the heat was likely due to oxidation. Squeezed it out best I could and disposed in an airtight container. The vinegaroon itself has a slight yellow tint. However, it's cloudy now where it wasn't before. That may not bode well. The test strip of leather looked black after about 20 minutes. Removed from the ziplock bag and set aside to dry. Don't know if I'll just rinse it later or neutralize any remaining acetic acid.
Right now I'm just waiting a few days to pour the liquid into another bottle. The liquid still shows no signs of orange and the steel wool no sign of rust. Plenty of bubbles. No sediment. This leads to a concern: H2. My initial thought was that H2 production would be slow, dissipating through the hole in the cap. In keeping the bottle full, there's not much room to collect in large quantities, though I have gotten the aforementioned liquid coming through it as the H2 collects on the steel wool. I'm not comfortable with H2 collecting at all. I've seen lead acid batteries explode, courtesy of H2 and a short between plates. This is something different, but the Wikipedia article on H2 doesn't inspire confidence. It's possible that I'm worrying about nothing, but how much H2 was in those lead acid batteries? And you can get an electric charge on plastic and even glass. courtesy of static electricity. I'm thinking of trying this on a much smaller scale with a wider mouth container, one open and the other with a layer of oil on top. It's frowned on now for environmental reasons, but putting a thin layer of oil on standing water is one way to control mosquitos by preventing the larva from being able to breath air. I think a little mineral oil is sometimes poured down seldom used drain traps to prevent evaporation, which would allow sewer gasses to come through the drain. But this would introduce another worry: The effect of H2 on the oil, in this case neatsfoot oil. I think a catalyst is needed for hydrogenation, though. H2 bubbles should pass through the oil. Maybe. Could try it with vinegar and a little baking soda first. I discarded the paper towels I had underneath the bottle. It had a tie-dyed orange look, but the last spillage had some dark gray. Fine iron can oxidize quickly enough to be a fire hazard. Even steel wool can be touched off if you're not careful. Again, probably worrying about nothing, but better safe than sorry. The fresh paper towels beneath it haven't had any spillage on it yet. Now I need a project to try it on. A simple one would be Yet Another Checkbook Cover. I would like to start on the knife sheath idea that started me in leathercraft, but I need to see about replacing the range hood before I buy more leather. Initial plan is to cut, glue, dry, then dye with vinegaroon prior to punching the stitching holes.
Even failed experiments teach something. To minimize surface area to air, I fill the 2 liter bottle to the neck. From the start I observed liquid coming out the vent hole in the cap. First I assumed that it was trapped air pushing up some of the steel wool, making it act as a plunger. But in subsequent fillings, the steel wool hasn't been near the neck of the bottle and have still observed the same effect. I think it's the hydrogen displacing the vinegar. Because I have 49g steel wool crammed into the bottle, I think it's making it harder for the hydrogen bubbles to float to the top. Twice now I've bumped the bottom of the bottle, releasing bubbles but no more liquid, and ended up with a clear space from the cap down to the main body of the bottle. It had already pushed the vinegar out the cap, but because the hydrogen bubbles remained attached to the steel wool, the bubbles didn't rise to the top. Instead, it pushed out liquid. Topped it off again this morning. Wondering if I should just wait a few days then pour the liquid in another bottle and discard the remaining steel wool and try again with smaller quantities.
Rusted iron is ferric oxide. Iron and water rusts, but I'm unclear if it's due to free oxygen in solution in the water or the water itself. If it's the water itself, it has to produce H2. My assumption is that it's due to oxygen in solution, but it's only an assumption. The acetic acid in vinegar reacts with iron to produce ferrous acetate. That''s what reacts to the tannic acid in the leather to produce black. There's iron loss, but it's not due to oxidation.
Important Update: I have made a huge, wasteful, error. It first occurred to me that I was stupid in not weighing the steel wool and vinegar mix. If there was no spillage, any decrease in weight would be due to the release of hydrogen. So, noting the decrease in weight over time, would both measure the reaction and allow the calculation of how much ferrous acetate and remaining acetic acid was in the bottle. That’s assuming the decrease was enough to be detected on a kitchen scale. Two liter bottles are unwieldy, though, so I thought of scaling it down to a half liter. It was then that I discovered I wasn’t just merely stupid, but incredibly stupid. By the chemical equation, it takes 2 moles of acetic acid to react to 1 mole iron. The molar mass of acetic acid is 60.052g, and with 5 grams acetic acid to 1000 ml of water in 5% white vinegar, that’s 5/60.052 moles. That means, with 5% acidity white vinegar, there should be 0.0833 moles acetic acid. Since it takes 2 moles of acetic acid to react with 1 mole of iron, it would take 0.833/2 moles iron = 0.0416 moles iron. The atomic weight of iron is 55.845, so 0.0416 x 55.845 = 2.323g of iron. For 2 liters of 5% acetic acid, that’s 4.646g iron. And I put 49 grams of iron in that two liters of 5% white vinegar. No wonder it looks like most of the steel wool is still there; it is. I miscalculated by an order of 10. It would take more than 20 liters of 5% acidity white vinegar to dissolve it all, and that's if the iron reacts to all the acetic acid. I can forget about measuring the decrease due to producing hydrogen. One liter of 5% acidity white vinegar reacting to iron should produce 0.0416 moles H2. But here I’ve made another error: I remembered gases like hydrogen like to stick together, so there’s H2 and O2, but a mole of hydrogen is still one H. So it should produce 0.0833 moles hydrogen. Multiplying that by the atomic weight of hydrogen and it comes up with a loss of 0.0839g for a liter. For half a liter, that comes to 0.0420g. It would take a very sensitive scale to detect that, and a kitchen scale isn’t going to cut it. Where does that leave us? Nowhere. As an experiment, this is at best a learning experience. I can still used the vinegaroon in that 2 liter bottle, just it’ll take maybe at least nine more fillings to use all the iron. That’s a lot. On the other hand, it seems that it takes only a small amount of iron to make ferrous acetate from vinegar. I still don’t know if it’s possible for the iron to react with all the acetic acid, but given accounts of vinegaroon reacting with baking soda even when there’s surplus iron in the jar, I’d say that’s a no. But remember, this is from the guy who miscalculated the chemical reaction by a factor of 10.
It depends on what you mean. As to how much combines with 5% vinegar, that's correct. As to the flaws in the experiment and what should and shouldn't be done, I've learned something. It's interesting to me that I'm not getting orange in the bottle, and the way to see if that's due to the small surface area exposed to air or keeping the steel wool submerged is easy to do. As to age, I'm in my sixties. As to education, went to college. Still make my living with electricity. Haven't had to use chemistry for that, and it shows.
As to chemistry books, I'm was about to crack open my college textbook, but then found one by Linus Pauling, General Chemistry. So far it strikes me more as high school level, but that's just three chapters in. Don't know yet why he covered calculating the distance of atoms in a solid, but wonder if he will tie it in with electrons and chemical bonds. Pauling's text is from the early 1970s, but figured that for the basic stuff, it should be fine.
As experiments go, this one has already gone off the rails. It's just steel wool, measured out on a paper plate on a kitchen scale, in a 2 liter plastic soda bottle filled with 5% acidity vinegar. There is no way to remove the steel wool except by cutting open the bottle. Didn't weigh the bottle before putting in the steel wool and vinegar, so I can't simply pour out the steel wool and weigh it. Even if I did, residual liquid in the steel wool would throw off the results. There's no way other than weighing the steel wool to determine how much dissolved, and the moment I take it out of the bottle and dry it, it's wet steel wool exposed to air, and will oxidize some. I didn't premeasure the vinegar before hand and have topped it off, so even that's out the window. So basically, I have steel wool in a bottle with vinegar and I look at it and go "Yep, there's bubbles on it and the liquid and steel wool shows no orange of rust (or ferric acetate - have learned that's a thing, too), It doesn't even seem to have significantly dissolved the steel wool in a week's time. That raises the question you brought up: How much ferrous acetate does it take to turn tannic acid black? If most vinegaroon leaves a significant amount of the iron intact, that implies it takes very little. At this point I could remove a tad with a dropper and see what happens to a piece of veg tan scrap, but that's about all. I don't know if I can even measure the tannic acid content in brewed tea to get some idea. Memories of titration keep coming back, but that means having some sort of indicator for what I want to measure and something that will react to it, not to mention a precise way to measure it. Am wondering if it would have been better to measure out a small amount of steel wool and vinegar. Doubt a kitchen scale could weigh a single 0000 steel wool strand, but just one with the predicted amount of vinegar might be better for this.
