yuma
Everything posted by yuma
  1. yuma
    Cutting die
    Thanks, I'll check them out. Roger
  2. yuma
    Cutting die
    To be honest, I don't know the correct name of these things.....a wood or plastic base with a raised metal cutting edge that you place leather over and press to get a shape...I'm looking for some one who can do a custom shape.....basically an outline of the state of Tasmania here in Australia. See attached pics.....something like the map outline, roughly 2" / 50mm square, but stylised, less detailed.....if this makes sense ?? Roger
  3. yuma
    Deans belt
    Inch and three quarters, forty inches long...45mm x 1100 overall. Roger
  4. yuma
    Deans belt
    My first attempt at a Ranger belt for a mates brother... Roger
  5. yuma
    Latest....
    Its about 9mm square... Roger
  6. yuma
    Latest....
    A friend of mine in the States needed an ammo pouch for his 16ga / 7x57 combination gun so I made one for him. I also bought a new stamp to try out.... Roger
  7. Nice...I use actual shell casings that I cut down...
  8. Thanks to all, I always appreciate feedback...as the 1911 holsters are so short and the double leather very stiff, you can't fold the holster into the skirt as you would with a longer revolver holster, the unit has to be sewn first and then the strap fitted, hence the rivets and screws have to go in after...this is the only way I could think of to do this.....other than one other ( unfinished ) revolver holster, these are the only holsters I have made. Yes, the pics aren't that clear, but I don't have a good camera or smart phone. If I was to do photo's for advertising or whatever I would have to get them done properly. Again, thanks for the input. Roger
  9. This is my second 1911 holster.....lined / double leather, black strap to match gun, 12ga shell because this is a three gun match...12ga shotgun, 1911 45ACP, and 40 cal + lever gun. Roger
  10. No offence taken...difference of opinion welcome.... Roger
  11. Very nice Will, for competition use the trigger has to be covered and must cover up to the ejection port on the slide. Roger
  12. I used part of an old Al Stohlman pattern for this...I cant see it as the wrong gun / holster.... These are commercailly available ones ( attached pic )..Wild Bunch is a pistol competition styled after the movie of the same name. Roger
  13. Its not quite as bad as that....you can still have handguns if you are a member of a shooting club. Roger
  14. yuma
    Sheaths
    I made a couple of knife sheaths for various knives.....a pancake for my work knife, an SOB for a tracker style knife I made and one for my old Mora... The pocket in the SOB carries a diamond sharpener, ferro rod and assorted bits and bobs... Roger
  15. I also made made a Wild Bunch holster for my 1911 Gold Cup...my first attempt. Roger
  16. I made some pouches for some mates in the Big Game Rifle Club..... I use girth elastic to hold the rounds, some are spaced for double rifles and the pic of the cases gives you an idea of the sizes... Roger
  17. yuma
    Ammo pouch
    This is one I just finished for a mates 470 NE double rifle, the flap folds behind so he can grab two cartridges at a time with thumb and two fingers.... Roger
  18. Yes. I shoot a Gold Cup in what we call " STEEL CHALLENGE " here in Australia and I like to be a bit more practical with my gear. Most competitors use all types of race guns and optics with plastic holsters and mag holders. I would like to make more, maybe not " traditional " gear but leather gear...if that makes sense... Roger
  19. This may not be the right place for this, but has anyone made a competition style holster for a 1911 ?? Roger
  20. yuma
    Key fob
    I usually get about six bucks for them, not a lot but I do sell quite a few... Roger
  21. yuma
    Key fob
    To the right market, yes. A bit of mucking around but better when you do a mob of them, good use for small off cuts, easy with the doo-hickey for cutting the leather out ( cutter cost about $35 ) I found the best market is gun shops, they put them next to the cash register ( like the chocolates at Woolies ) Roger
  22. yuma
    Key fob
    Sorry to rain on your parade, but I've been doing these for several years now....as you said, cut the shotgun cases down with a Dremel, pop out the primer and its surround then re-fit using an appropriate size eyelet then super glue a used large rifle primer back in the center. With the rifle ones, I cut the base at about 3/8" then put six cuts in the body to flare out once its fitted to the leather..I hope this makes sense, the pics may clarify... Roger
  23. yuma
    Ammo pouch
    Pdm25150...Those are made to go on your belt or in your pocket....the pics below are made for your pocket, they are in different lengths for different cases but are all 100mm/4" wide to fit in a shirt pocket.... Roger
  24. yuma
    Ammo pouch
    I assume you are asking about the forms for the top half of these pouches.....I make them from what we call " Form Ply "....the centre piece which forms the pouch varies depending on how deep I need the pouch to be, the base and the top stay the same. Roger
  25. yuma
    Ammo pouch
    This is a bit of an old post, so I may as well add to it while I'm here.....This is one of three small pouches for holding 22's that I made for a mates boys, they'll easily hold up to 100 rounds.... Roger
