Members BFaehn Posted March 16, 2022 Members Report Posted March 16, 2022 I don't know what I'm doing so any tips would be great. I put a sheen coat o. And applied antique gel but this is the finish I got. Wht am I doing wrong nd can I save the piece is tried it on? All I seem to be doing is making the leather darker where I apply it. Quote
CFM tsunkasapa Posted March 16, 2022 CFM Report Posted March 16, 2022 Did you apply the antique to the entire piece, or just the carved design? And when you say a 'sheen coat", what product did you use? I'm not sure that a lot of 'sheen' products have the proper 'resist' to apply antique over. Quote
Contributing Member fredk Posted March 16, 2022 Contributing Member Report Posted March 16, 2022 1 hour ago, BFaehn said: . . . nd can I save the piece is tried it on? . . . Try sponge washing it over with alcohol. This will remove some brands of antique and dye Quote
Members BFaehn Posted March 23, 2022 Author Members Report Posted March 23, 2022 I used suet sheen. Should I be using something different? Quote
CFM tsunkasapa Posted March 23, 2022 CFM Report Posted March 23, 2022 (edited) I use Fiebing's Pro Resist. I'm not sure that super sheen is resistant enough, but I don't use it at all. If you are getting good 'resistance', you shouldn't get much darkening of your project, but only in the cuts and depressions. It may be that you need to do 2 or 3 coats to get the resistance you need. Also, apply the antique to the whole project, to ensure consistent coloring. Edited March 23, 2022 by tsunkasapa Quote
Members AzShooter Posted March 23, 2022 Members Report Posted March 23, 2022 I use Resolene. It really helps. Put it on, when dry apply your antiquing and wait 10 minutes. Then, wipe off the antiquing. This will prevent it from making the entire piece darker. Quote
Members Handstitched Posted March 23, 2022 Members Report Posted March 23, 2022 One method I have used in the past, for a carved piece for eg. flowers, I use a small brush on the flowers ( only) with a super sheen sealer, perhaps a few coats, let dry fully , and then apply the antique dye on the main body and over the now sealed flowers using a swab, but quickly wiping off any excess with a slightly damp cloth. The outside/main body is dyed, but the flowers remain natural . There might be a little dye on the flowers , but hardly , and thats it. Its fiddly I know, but it works. Another technique I learnt from somewhere on this site in the early days: I used to put my antiques directly on dry leather, with varied ( and unsatisfactory) and blotchy results. Then I started to put some oil , like neatsfoot, or phane oil over the stamped/ carved pattern , let soak in , and then I apply the antiques and cut back with a damp cloth. All the antique dye stayed in the stampings/carvings with much better results . I've been doing that ever since. HS Quote
