Members Brooks125 Posted March 28, 2022 Members Report Posted March 28, 2022 I have a Cowboy 3200 and typically stitch 8/9 oz veg tan leather for belts holsters and gun leather, belts etc. Lately, I have had trouble with skipping pick-ups from the bobbin. When it happens, I know it because the thread loops on the needle chuck. The stitch is good on all other counts, as far as tension and spacing. I'm lubricated well. Tensions all seem right. In fact, I seldom adjust much of anything since my projects are all pretty similar. I've been pretty consistent for about 7 years now! One thing I did change ... I recently switched to Superior Thread (277). Oddly enough, it only seems to be the white thread that does it. Any ideas what may cause this and, more importantly, how to correct it. It's infrequent enough that if need be, I can hand stitch the offending thread down, but that gets old after awhile. The picture shows the skipped stitches on the top row, there's only a couple here. Thanks for the input. Quote "Be polite. Be professional..."
Members Hags Posted March 28, 2022 Members Report Posted March 28, 2022 I would start by cleaning the bobbin area very well. Also take a good look at the hook. No real good ideas here. I use superior 277 white as well and have been very happy with it. Quote Not so retired RN. Living on the Washington Peninsula.
kgg Posted March 28, 2022 Report Posted March 28, 2022 3 hours ago, Brooks125 said: Lately, I have had trouble with skipping pick-ups from the bobbin. 4 hours ago, Brooks125 said: Oddly enough, it only seems to be the white thread that does it. I agree with Hags but I would also try i) replacing the needle and ii) replace the thread with a fresh spool. Are you using an 8 oz spool or 1 lb spool of thread? Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Constabulary Posted March 28, 2022 Members Report Posted March 28, 2022 In 7 years it is well possible that the needle bar has risen a little bit. I´d check the needle hook timing and probably lower the needle bar a tiny bit. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
MtlBiker Posted March 28, 2022 Report Posted March 28, 2022 @Brooks125 - Sorry, but I cannot comment on the skipped stitch issue you're having but as a relative beginner to leatherwork who's trying to learn, I wanted to ask you a question: On the photo you posted of those stitch lines, it looks like you might have cut a groove for your stitch line. Is that right? I know this is done for hand stitching, but I'd never seen/heard that it's also done for machine stitching. I would imagine it would be very hard when machine stitching to keep the stitches within that stitch line groove, or is that just a question of experience? Thanks. Quote Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
Members Brooks125 Posted March 28, 2022 Author Members Report Posted March 28, 2022 There is a groove for all four lines. It does get easier as you go! Quote "Be polite. Be professional..."
Members Brooks125 Posted March 29, 2022 Author Members Report Posted March 29, 2022 On 3/28/2022 at 12:58 AM, Constabulary said: In 7 years it is well possible that the needle bar has risen a little bit. I´d check the needle hook timing and probably lower the needle bar a tiny bit. So far, this seems to be the solution. I came down this morning and it was happening WAY too often. I swapped out the thread as suggested above ... no help. Since this is, apparently the only "how-to" video NOT on YouTube, I called Toledo Ind. and he walked me through removing the head cover (not hard at all) and a couple set screws loosened and tightened, we're back in business. Thanks for the help everyone. Quote "Be polite. Be professional..."
Members Constabulary Posted March 30, 2022 Members Report Posted March 30, 2022 FWIW - when you have skipped stitches it most of the time is the needle bar set too high / needle bar has risen by the time. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
