Members unicornwoman Posted October 31, 2007 Members Report Posted October 31, 2007 leatherroo: A shed or garage to put it in would be nice too. The kitchen table gets a workout! Its not so much the table, but i have to get everything out and then put it all away and then repeat the process the next session.>>> Been there and done that. Whew! It really dampens the creative processes. Finally, got a work room added on last summer. Now the challenge is keeping the tables & desks CLEAR so I can put project on them. Seems like all the household paperwork/filing ends up there... Bruce Johnson: Standard warning - WEAR eye protection. Once the tubes fill up, subsequent punchings are ejected in random directions. I find them in coffee cups, casing water, etc. Open mouth once when talking.>> ROTLF! Quote Melody D. Snow The Unicorn Woman (established 1980) Lillian, Texas, U.S.A. Miniature Tackmaker, Leathercraft Artist, & Freelance Writer http://www.unicornwoman.com
Members ghstrydr164 Posted October 31, 2007 Members Report Posted October 31, 2007 greg If you drill your hole the proper size you will have a better lock than with an awl punched hole. If you set up the seam correctly before you drill your holes your stitches will look much better than awl work by most people and as good as the best awl work. There are times to use an awl but only when a drill will not work. As far as the test goes lets look at some facts; if you slit a piece of leather through in the center and pull on it it will continue to tare along the cut, that's why we are taught to punch a hole at the ends of slits to lessen the tendency of the slit from tearing. The second item that I ever sewed by hand and it will stand up to any awl work I have seen. Cyrus Quote
electrathon Posted October 31, 2007 Report Posted October 31, 2007 The second item that I ever sewed by hand and it will stand up to any awl work I have seen. Cyrus Cyrus, I am incredibly impressed with both your stitching and your tooling. Aaron Quote
Members greg gomersall Posted November 1, 2007 Members Report Posted November 1, 2007 When you drill a hole you are actualy removing material,how is this type of stitch tighter. It takes time to learn how to hand sew properly but when you sew with an awl, you do not set the awl to run along your stitch line but diagonaly so that it will not tear. The Art of Handsewing by Al Stohlman is a good book for some one wanting to learn the correct way. If you are happy with drilling your holes that is fine, I don't care but some people want to elavate the level of thier work constantly and there are no shortcuts to excellance. Go back through your LCSJ issues and study the rebuttal Jeremiah Watt gave to the so called test on which method is best. There may not be a right way or a wrong way but there is a Traditional Way. Greg Quote
Members D.A. Kabatoff Posted November 1, 2007 Members Report Posted November 1, 2007 Cyrus, I agree with Greg on this issue and sure hate to hear people quote that test... especially when the people conducting it didn't know how to hand sew properly. There is an important aspect that was overlooked in the test and that is the compression of the leather by an awl. As Greg mentioned, first the awl has to be used on the correct angle so that the point to point from hole to hole causes the stitch to pull on an angle. When an awl makes a hole it doesn't remove the material but instead compresses it making it more dense and harder. A drill bit has the opposite affect by removing material, leaving a hole with broken fibers around it's circumference; The leather will definitly be weaker. I have attached two photos of a good size to give you a close up of what handstitching should look like. You should be able to see that the holes made by the awl were made on an angle and that the stitches do no pull in a straight line. Instead they are pulling towards one side of the diamond shaped hole made and pulling on firm, compressed leather. As Greg mentioned, people can do whatever they want with their goods, but it is simply incorrect to say that drilling holes is stronger than traditonal handsewing. Incidentally, do you have any pictures of handsewing done with a drill that was sewn with white thread? I'd be curious to see it next to the photos I have posted to compare the tightness of the thread through the hole. The reason this is important is that when you remove leather with a drill and create a hole that is slightly bigger than the thread, dirt will build up in that hole and the grit will wear on the thread. By using an awl, the memory of the leather will cause the leather to expand slightly after the awl is removed. This means the hole will tighten up even more around the thread which is obviously impossible when you remove leather with a drill. Darc Quote
Members Peter Ellis Posted November 1, 2007 Members Report Posted November 1, 2007 Just to put this back on track.. Lacing holes - that's what this started with - Is the thonging/lacing chisel equivalent to making your holes with an awl ? Preference for whether the lacing hole should be a punched out hole or a pierced through slot ? Quote Peter Ellis Noble Lion Leather
Contributing Member Clay Posted November 1, 2007 Contributing Member Report Posted November 1, 2007 What a great topic. It is interesting to see different views on this. Personaly I was taught to use an awl and I like it better than punching holes or drilling be it right, wrong, traditional or not. The thing to keep in mind with an awl is that it is like the swivel knife blade it has to be very sharp and smooth to work properly. An awl used off of the shelf is probably not sharp enough and may be the reason why people get discouraged with awls and make the user want to try other methods of making the holes. As for lacing I prefer to use a lacing chisel for the same reason that was stated about using an awl, the leather is not removed, it is cut and compressed. It looks beter to me and it will also help prevent the lace from twisting as you are lacing the project. Thanks for the informative topic!!!! Clay M. Quote Clay Miller
Ambassador Beaverslayer Posted November 1, 2007 Ambassador Report Posted November 1, 2007 Even thought this is getting to be a very good topic, I have to return to the original that got this all started. As to using a punch, drill, awl or burr, this would all depend on the material you are going to be lacing together. I have attached 3 pictures of lacing that was done on the vest that I have worn since the day I finished it almost 2 years ago. All the holes were punched using Al Stohlman punches. As I believe you will see from the photos that there would be no way to effectively drill holes through this material with a drill press, even if the punch was as sharp as possible. The chances of the punch or drill catvhing and tearing to shreads as the vest twirled around the chuck is way to high to even attempt this. This is the shoulder yolk with 3/32" holes and 1/4" lace. Yes you could use the drill and punch method on the carved yolk, but I would'nt use the awl or straight lace punch with using this type of lace. This is the front edge and front pocket, again punched with 3/32" holes and laced with 1/4" lace. Using a smaller size hole than the lace, you obtaian the same expansion/contraction theory as the awl. As the lace is being pulled through the hole it expands, and once done the hole will contract onto the lace giving you a very clean look. As you can see, the hole is not visible once the lace is complete. This is a picture of the backside of the edge, it also shows the inner pocket. Again you will see that there is no evidence of the round hole. As to the pocket, I don't believe you would be able to put holes in Pig Skin Suede with a drill and punch. So, again, depending on what you are putting the holes into will determine the way you accomplish the task. Hope this helps someone out there. Ken Quote Beaverslayer Custom Leather<br />Wearable Works of Art https://www.facebook...erCustomLeather
Members ghstrydr164 Posted November 1, 2007 Members Report Posted November 1, 2007 (edited) Darc Very nice hand stitching no matter how it was accomplished. I drill my holes small enough to require pulling the needles with pliers and that is very tight. Making a hole with an awl cuts or tears fiber and drilling a hole removes fiber. At best it seems that one over the other is a matter of choice and not a matter of one being superior to the other if both are done correctly. Al Stohlman extolled many beliefs that served him and Tandy and many see him as a mentor. I don't think to depart from his ways is wrong as I do not think tradition is a bad thing as long it is kept in prospective to the times we now operate in. I have no intention of doing leather work by an oil lamp unless I am forced to, traditional or not. Cyrus Edited November 1, 2007 by ghstrydr164 Quote
Members greg gomersall Posted November 1, 2007 Members Report Posted November 1, 2007 Proper hand sewing goes back centuries before Al Stolhman. The gentleman I apprenticed under in the late 80's himself apprenticed under an old harness maker in the 40's. The very first thing he had Hank do was hand sew triple ply harness traces by hand. Hank asked why hand sew these when you have a sewing machine right there, The reply was "you have to learn to hand sew properly if your gonna be any use around here." As for the times we now operate in, being efficent is the key to survival even when hand sewing. I have no idea how long it takes you to mark your spacings ,drill your holes and then sew your holster while reaching for your pliers each stitch but I would be fairly confident that either Darcy or myself could sew at 7 stitches per inch by hand using traditional methods and sew four holsters in the time you got through one. But what the heck I don't know squat anyhow. Greg Quote
