Members shadowryder Posted May 3, 2022 Members Report Posted May 3, 2022 Hi All, a while since I been on here but had other things going on,anyway slowly getting back to the leather and I have a chance on the Singer 132 K 10 local to me at a great price. My question is would this cope with 7 to9oz veg tan and similar,I know its standard lock stitch and the guy was sewing multiple layers of cordura/webbing with it but I do not know how it would take to the leather. Also If I picked it up I am wondering if adding a roller wheel would improve its operation at all, any and all advise on the subject would be greatly appreciated, many thanks J... Quote http://www.bat-shadow.jigsy.com/http://www.facebook....tShadowLeathers
Moderator Wizcrafts Posted May 3, 2022 Moderator Report Posted May 3, 2022 1 hour ago, shadowryder said: Also If I picked it up I am wondering if adding a roller wheel would improve its operation at all, Apparently, some of the 132k10s have roller presser wheels. See this page for an example. It will definitely improve the feeding vs a flat foot. I used to have a 132k6 and it had trouble sewing 1/4 inch of veg tan with #346 thread using a #26 needle. It did a better job on cloth and webbing. But, I was inexperienced at that time and I didn't know about #277 thread, or if anybody sold it. My solution was to sell it and buy a more capable leather stitcher. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
RockyAussie Posted May 4, 2022 Report Posted May 4, 2022 59 minutes ago, Wizcrafts said: Apparently, some of the 132k10s have roller presser wheels. See this page for an example. It will definitely improve the feeding vs a flat foot. I used to have a 132k6 and it had trouble sewing 1/4 inch of veg tan with #346 thread using a #26 needle. It did a better job on cloth and webbing. But, I was inexperienced at that time and I didn't know about #277 thread, or if anybody sold it. My solution was to sell it and buy a more capable leather stitcher. Hi @Wizcrafts Are all the 132 K6 machines walking foot models? I am just doing some homework on it as I have one coming in for repair today. Looks like in a move they may have bent the outer presser bar in enough to touch the inner foot which in turn leads to the odd miss stitch. Only dealing with pics and vids as yet. The metal shavings on the top of the presser foot note.The 10 on the side is what is throwing me at the moment. Broken thread guide before needle as well by the look in above pic.- Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Moderator Wizcrafts Posted May 4, 2022 Moderator Report Posted May 4, 2022 Yes, the 132k6 has an early foot walking foot design: a spring loaded follow foot that moves as the feed dog pushes the material on the bottom. The inside foot acts as a needle guide and moves up and down as the outside foot moves back with the material. They were originally meant to sew 1/2 inch thick cotton or canvas buffing wheels using a special spiraling attachment. Despite the massive case and huge bobbin, it is not a leather sewing machine. I learned that the hard way. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted May 4, 2022 Members Report Posted May 4, 2022 I have 132K6 and it sews leather just as good as my 45D91 (45K) but it depends on the nature of the product you want to produce. Sewing plain leather is one thing - producing a specific leather good is another thing. The 132K10 is a plain drop feed machine (like Singer 45K1) with no reverse but it has super large capacity bobbin rotary hook. The feed dog may mark the leather on the bottom side (depends on what leather you want to sew and the foot pressure you have adjusted - the less the better) but that IMO is no serious issue cause a lot of other sewing machines mark leather well. Question is if that is a problem for your product or not - for me it is not but thats maybe just me. Ex factory the 132K10 did not come with roller foot but can be set up with one (if you find one - its the same as for the 45K ). if it already has a roller foot - even better - they are hard to find! The machine is using the same presser feet as the Singer 45K / GA5-1 / CB105 / CB 2500 and the like. Parts are usually no problem. The machine shares parts with the more modern machines like Mitsubishi DY-253 and Seiko SK-2. Best bet - test sew it and decide whether this machine suits your requirements or not. If the motor is a clutch motor you can replace with with a servo and maybe add a speed reducer. When you test the machine make sure you can change the stitch length and the notches on the stitch length adjuster are NO worn. If they are worn you may have a hard time holding the lock lever (front right side) in place when changing the stitch length (push lock lever and turn hand wheel). Hope this helps. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted May 4, 2022 Members Report Posted May 4, 2022 (edited) 8 hours ago, RockyAussie said: Hi @Wizcrafts Are all the 132 K6 machines walking foot models? I am just doing some homework on it as I have one coming in for repair today. Looks like in a move they may have bent the outer presser bar in enough to touch the inner foot which in turn leads to the odd miss stitch. Only dealing with pics and vids as yet. The metal shavings on the top of the presser foot note.The 10 on the side is what is throwing me at the moment. 132K6 are all jump foot machines (no driven walking foot as on 441 and the like). Yes, foot bar looks a bit bent to the right. First Aid could be a washer / shim between outer foot and foot bar to bring it a bit further tot he left. However the 2 feet kinda look like they did not come as a set and probably do not perfectly match (I guess). The 10 most likely was an internal factory / plant machine number. Edited May 4, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
RockyAussie Posted May 4, 2022 Report Posted May 4, 2022 1 hour ago, Constabulary said: 132K6 are all jump foot machines (no driven walking foot as on 441 and the like). Yes, foot bar looks a bit bent to the right. First Aid could be a washer / shim between outer foot and foot bar to bring it a bit further tot he left. However the 2 feet kinda look like they did not come as a set and probably do not perfectly match (I guess). The 10 most likely was an internal factory / plant machine number. Thanks @Constabulary. The machine is here now and the most recent owner seems to have no idea what oil is and what it does. BAD wear on a lot of the wear pins. Late now so I will load a few pictures tomorrow. I think that may be a part missing as well. Oh and yeah the centre foot after a good struggle getting it off turns out to be some piping foot. Lots of wear marks on it from rubbing the other foot. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
RockyAussie Posted May 4, 2022 Report Posted May 4, 2022 @Constabulary here is a couple of pictures of the areas where I think something may be missing. Would it possible to take a picture for me to see on yours? Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Constabulary Posted May 4, 2022 Members Report Posted May 4, 2022 (edited) at your 1st picture the piece for the foot lift arm is missing - mine is missing too Will post a part link in a few minutes... EDIT: This thing here: https://www.college-sewing.co.uk/1399-97722-foot-lift-lever-link-seiko.html a small round bar from the tip of the foot lift arm goes into the oblong oval - if you know what I mean. I will compare the other picture with my machine - not sure atm... later... Edited May 4, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted May 4, 2022 Members Report Posted May 4, 2022 (edited) Pic 2: pencil points to a hinge point of the thread lever - there should be a screw inside the hole. below your pencil 2 screws are missing that hold the bar 97730 in place but I guess you removed them, right? EDIT: answered the screw question my self (pic 1) Edited May 4, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
