Hey there!
I am looking into purchasing a Pfaff 145 H3 from a local seller and have ran into an issue with the machine. When manually turning the wheel in either direction, we hear a squeaking noise.
The machine seems to work fine and produces beautiful stitches so it is very odd.
A friend of the seller who is more knowledgable about machines believes it may be an issue with a bearing, as the noise is much less obvious when sewing, and also went away a little after oiling the areas near the handwwheel.
Any ideas on resolving this issue?
I would remove the top cover and see if there is a issue in that area. With that cover removed you will also be able to see if the machine was regularly maintained with oil and grease. If it looks dry or parts are worn you have to wonder how well it was cared for. If parts need to be replaced add that cost to your purchase price. If you are in Canada parts are going to be expensive. If you have any doubts about the machine pass on purchasing it there are always plenty of used machines.
A photo of the machine would help in determining possible other problem areas to look for and give also give an indication as how hard it was used and abused. If it is an ex factory / industrial / commercial setting machine I would pass unless it was dirt cheap. What are they asking for the machine and where are you located?
kgg
kgg
Im in the Usa, and the asking price is much cheaper than any used industrial walking foot I could find in my area at $500. It comes with a table (which is a bit rundown), a servo motor, a speed reducer, a few different feet, and various threads for me to test around with.
I called numerous dealers, repairs shops, friends, searched around online and wveryone i spoke to said they either didnt have any available, or only sold new ones. My two next options from this machine would be a new consew 206rb with a servo and table at $1600, or a new sailrite package at $1100-1300. Im also looking to get an overlocker, so saving the cost difference would really help me out with that.
The machine was just recently oiled a few days ago, and that helped clear up some squeaking. Its gone through two owners now. The original owner made pillows with it (im not sure if they made them commercially or just for hobby). The 2nd owner (who i am buying it off) rarely used the machine, as they did most of their sewing by hand and never got around to figuring out the proper workings of the machine. I was told they used it more around 10 times through its 2 year lifetime with them. Though, only had it oiled once or twice in the 2-year span they had it - I believe this is what has been causing squeaking.
Lifting the machine up, there was a bunch of gunk sewing oil built up around and about, but i figure i could remove the majority of it fairly easily. Besides cleaning this, the thread stand and rest peg need replacing, but thats only a 20-$30 fix. Ive attached the picutres i have available below.
Are there any videos or guides around on how to take off the top to look inside? This would be my and the owners first time trying to do this so we unfortunately have no clue.
Thank you for the help kgg!
I would remove the V-belt on the machine pulley and try again. Still squeaking? If not maybe then its the motor brake or the V-belt. You know how the motor brake works?
Removing the v belt makes it pretty much silent when turning the handwheel, however, we were told this shouldnt be a good way of cancelling out an inner bearing being the issue, as there is no load on the machine with the belt off it. I do not know how the motor brake works
If you got that machine for $500, complete with a servo motor AND a speed reducer, you got a REAL good deal!
I'd check the belt alignments, to make sure they're all running straight. A belt running on a pulley at a sideways angle can cause the noise you describe, as will a belt running too loose.  And make sure you've oiled everything in the machine powertrain - Both above and below the bed. The manual should show the oiling points.
The model number giveth, and the subclass taketh away ......... Sometimes
There are two covers. 1) at the front a flat plate that covers the housing for the all the drive mechanisms driving the needle which is held in place by two screws removing that plate allows for inspection and oiling. 2) the flat plate on the top of the machine next to the hand wheel allows for inspection and oiling / greasing of the drive bevel gears which is held in place by one screw.
A couple of links:
Manual: www.manualslib.com/manual/505004/Pfaff-145.html?page=20#manual
General instruction video: www.youtube.com/watch?v=iuzoN-I6ydI
A restoration video may help with redoing the table top: www.youtube.com/watch?v=rMerpCgK1po
Looking at the second photo I noticed the belts which appear to be made for other purposes then sewing machines. One has a tooth type profile made so the teeth can engage with the teeth of a gear to give better grip. The squeak could be coming from them as they don't appear to be seating properly in the pully's as their profiles are different then that of the pulley. This may cause a squeal as the belt rubs against the sides of the "V" pulley.  Another possible cause is the belt tensions particularly the one going to the sewing machine needs to have a little slack and appears to be bar tight in the photo. A to0 tight of a tension on the pulleys will cause eventually the bearing to wear in the motor / reducer or the sewing machine.
I would try to locate the noise by removing:
1) the belt to the sewing machine , remove the top cover by the handwheel and oil the bearing where the shaft goes through the casting to that the handwheel. That bearing maybe dry.
2) with the belt still on the servo motor and the belt to the sewing machine removed run the motor and see if there is any squeal from the reducer pulley bearing
3) with no belts attached to the servo motor run the motor to see if there is any squeal from the motor.
4) replace the belts with new proper belts and adjust the tensions as needed
The price for the machine if it is a simple fix would be a good price but if the sewing machine needs a new bearing or other parts they are going to be expensive to replace, if the bearing is gone in the reducer it is going to expensive to replace (new ~$200) and if it is the servo motor pulley bearing gone it will also be expensive (new motor ~$200) while the belt replacements are fairly cheap ($$?? as it depends on the lengths).
Also what are you planning on sewing as this may all be mute point as it may not be the best machine for your needs.
Lets know how it works out.
kgg
A couple of links:
kgg
Ok, i will try and have the seller do all of that in that order, and see if anything changes. If this doesnt work, I think I will save myself the headache of buying new parts and waiting for the service man, and just get a new machine instead.
Ive really been eying the Sailrite Lsz-1 plus package at $1195, as its portable and is said to be able to sew one to multiple layers of all the lightweight and heavyweight fabrics i will list below with no problem. I would either get this package, the upgraded Worker-B package at $1595, or the Consew 206Rb with table and motor for $1599. I have numerous tables myself and do not really need one specific to sewing, so going with the sailrite would be ideal to me if it could do everything  else I want.
Mainly, I will be sewing leather garments (goat, cow, lamb, and hopefully horse if the machine is powerful enough for multiple layers). However, I would also like to use the machine to make jeans, shirts, tees, and muslin samples of other garments if possible. Truthfully, besides leather, i am still exploring the types of fabrics I would like to use, so I would really like a somewhat universal machine that would not limit me to a set range of fabrics to work with.
After testing, it seems to sew beautifully on all the leather and denim I had (from one to multiple layers). The muslin sewed fine as well, however i only tested it at about 4-6 layers, nothing less.
I will keep yall in the know! Thanks!
The portable walking foot machines do have their place for a number of reasons but there are other considerations like you will be limited to V92 thread, the stitch length (stitches per inch) will diminish as the thickness increases and of course the resale value as compared to brand name machines like Juki. I have a LSZ-1 clone which I table mounted and setup for a single purpose in a specific location. I recommend you consider table mounting it in a standard or cutdown sewing machine table or the one that Sailrite offers as you will find it easier to feed items if the table surface is at the same height as the sewing machine bed to avoid material catching on the left corners of the base which the Sailrite comes mounted in.
kgg
To help you decide which way to go, portable walking foot or an industrial sewing machine for the items you want to sew. I would recommend you watch the video's of the Juki DU-1181N (~$1400 US w/ table and motor) and the DNU-1541S (~$1800US w/ table and motor) sewing light weight, medium weight and heavy fabrics. It really is going to come down to what you want to sew, it's thickness, the thread size you want to use and your budget.
Juki DU-1181N: www.youtube.com/watch?v=IKJuKTrjsbw&t=300s
DNU-1541S: www.youtube.com/watch?v=4JES-2I7h3o&t=3s
Buy Once, Cry Once
kgg
