I just took delivery of my latest purchase
Another sewing machine. Purchased off ebay. I couldn't resist the 'bling'. Its a domestic, possibly German and uses a shuttle. I'll check it out fully later. I doubt I'll put it to use though
and it has a nice wood case
4 Singers, 1 Singer clone, 1 Tippmann Boss, 1 New Home & 1 (unknown)
Edited by fredk
  • Replies 315
  • Created
  • Last Reply
Top Posters In This Topic
You will probably like the look of the old Singer machine I put up a short while ago - a Vintage Singer 29-D-58 Industrial Leather Manual Sewing Machine it says in the listing.
Learning is a life-long journey.
@Sheilajeanne
The machine has ' Bentalls Kingston on Thames ' which was a big department store in the south of England. So far I've not found a maker's name on it
I can't decipher this on the front of the arm
@fredk Those goth boots I spoke about a looooong time ago?  I've done them.  They're lethal . They get a lot of looks at the markets. I just need to work out how to up load a pic on here  using a hand held device . I'll figure it out eventually .
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
  • 2 weeks later...
@fredk re: vintage  radios, I have a shed with my collection of valve radios  in . Along with parts, valves etc.  It was a hobby  in another  life . Some are / were in working condition, some restored,  table models and floor models ,but I have nowhere  to display  them in my house, no room  :dunno:  The one that zapped me is a Philips (I think) single valve wood bee hive cabinet. When unplugged,  it put out 95 volts ️  .
HS
Two things arrived in the post today
1. From Temu this hole punch sharpener. The outside cone to sharpen the inside edge of punches and the tool has a hollow part to help sharpen the outside edge. Comes in a protective plastic box. This should help me keep my punches sharp
2. From texasleathertools a handled stamp. He took one of my Viking eagles and made a stamp. And is it tiny! Only 12mm (1/2 inch) across the base. Made in machined brass with a steel handle. First class workmanship. It came with its own plastic protective case. Now I need to find a project I can use it on
I put some paint on the design so you could see it clearly - remember this only 12mm across the base
Edited by fredk
Workers are coming to install a completely new heating system in my flat/apartment so all my furniture has been moved about to give access to all the radiators. My spare bedroom which is my leatherwork room is chock-full of items from the other rooms. Its been like this for over a month now. The workers tried to install on the 26th May but the surveyor made a mistake so they couldn't do it. Another team are supposed to it on Thursday 30th, this week.
I've not been able to do any leatherwork since about May 20th and several projects are mid-finish. Might not be able to get back to leatherwork until about August 8th or so.
I'm having severe 'withdrawal' symptoms!  :crazy:
Edited by fredk
  • CFM
Someone knew you needed a vacation!! Go have a good time while you have the excuse, er chance.:)
Ock! My sympathies.
Try stimming with a piece of veg tanned leather. 🙂 Texture, smell all help.
Edited by SUP
I wish. I gotta hang about in case anything else needs moving
